Offset image in much of the chart right
vecerapl
Post by vecerapl » Sat Feb 06, 2010 4:11 pm
Creating a chart for mobile, but even though the graph is 280px width, so the graph is indented in the image 20 to 30px, which is a lot. Why such offset does it do?
Is there any way to reduce the offset? Maybe gnuplot command?
PetrP
Re:Offset image in much of the chart right
Post by PetrP » Sun Feb 14, 2010 9:40 am
vecerapl
Post by vecerapl » Sun Feb 14, 2010 11:50 am
But the use of x(y)offset does not meteohub, but only if the offset and set the set offset 0, so nothing happens. I also use the values from -5 to 5 and nothing will change.
set xoffset 0
"/tmp/meteoh73n89", line 34: valid set options:  [] = choose one, {} means optional
	'angles', 'arrow', 'autoscale', 'bars', 'border', 'boxwidth',
	'clabel', 'clip', 'cntrparam', 'colorbox', 'contour', 'decimalsign',
	'dgrid3d', 'dummy', 'encoding', 'fit', 'format', 'grid',
	'hidden3d', 'historysize', 'isosamples', 'key', 'label', 'locale',
	'logscale', 'macros', '[blrt]margin', 'mapping', 'mouse', 'multiplot',
	'offsets', 'origin', 'output', 'palette', 'parametric', 'pm3d',
	'pointsize', 'polar', 'print', '[rtuv]range', 'samples', 'size',
	'style', 'surface', 'terminal', 'tics', 'ticscale', 'ticslevel',
	'timestamp', 'timefmt', 'title', 'view', 'xyplane', '[xyz]{2}data',
	'[xyz]{2}label', '[xyz]{2}range', '{no}{m}[xyz]{2}tics',
	'[xyz]{2}[md]tics', '{[xyz]{2}}zeroaxis', 'zero'
Content-type: image/png
