Easy going back from 5.0e to 5.0d
What's hot...
Post by admin » Thu Feb 12, 2015 11:13 pm
As 5.0e does scramble your settings file I just provided an update "5.0d2"
which you can easily install via "update (auto)" when being on 5.0e.
This update brings you back to 5.0d and will also bring back your settings
file to the state it had before going to 5.0e.
If it does not work for you, please email to "info(at)meteohub.de".
Sorry, this glitch shouldn't have happened.
Da Version 5.0e leider die Konfigurationsdatei zerstört, habe ich ein
Reparatur-Upadte 5.0d2 eingestellt, dass einfach per "update (auto)"
eingespielt werden kann und den alten Zustand von "5.0d" wieder
herstellt, inklusive vorheriger Einstellungsdatei. Danach sollte wieder
Alles gut sein.+
Falls es nicht tut, bitte email an "info(at)meteohub.de".
Tut mir leid, dieser Fehler hätte nicht passieren dürfen.
Napajedlaci.cz
Re: Easy going back from 5.0e to 5.0d
Post by Napajedlaci.cz » Wed Feb 18, 2015 6:10 am
I have problem with NTP with Raspberry pi. What this log mean?
2015.02.17 02:54:56 log file cleared by user
17 Feb 04:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 05:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 06:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 07:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 08:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 09:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 10:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 11:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 12:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 13:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 14:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 15:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 16:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 17:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 18:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 19:44:14 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 21:37:36 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
17 Feb 22:38:37 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
18 Feb 00:02:46 ntpd[2357]: frequency file /var/spool/ntp.drift.TEMP: Permission denied
18 Feb 05:02:12 ntpd[2273]: ntpd exiting on signal 15
Napajedlaci.cz is very good weather station in Czech republic neer town Zlin.
