Update 4.9d
What's hot...
Update 4.9d
Post by admin » Fri Jan 27, 2012 4:58 pm
Hot fix for the bug introduced with 4.9c which resulted in dropping TH sensors on "sensors" page when using certain weather station types.
4.9d can be installed the usual way.
Aussie101
Re: Update 4.9d
Post by Aussie101 » Mon Feb 06, 2012 12:38 pm
Just had sensors saying no data for 4h
This is a new install based on the 4.9 image updated to 4.9d after install
Sensors page says
error receive data from socket 127.0.0.1:5555: Resource temporarily unavailable
Warning: Data logging has been halted
I'm updating to 4.9e now.
Re: Update 4.9d
Post by admin » Mon Feb 06, 2012 1:19 pm
what type of weather station do you use?
Aussie101
Re: Update 4.9d
Post by Aussie101 » Mon Feb 06, 2012 1:22 pm
admin wrote:what type of weather station do you use?
I have a WMR968 and I'm testing a Vantage Vue with serial USB FTDI adapter
Seems that the Vantage usbserial is no longer coming up since the update. Are there any kernel changes?
Aussie101
Re: Update 4.9d
Post by Aussie101 » Mon Feb 06, 2012 1:33 pm
See viewtopic.php?f=18&t=6933#p11520
Came up as ttyUSB0 on connection under 4.9d but errors with
Feb  6 22:00:05 meteohub kernel: usb 2-2: new full speed USB device using ohci_hcd and address 34
Feb  6 22:00:05 meteohub kernel: usb 2-2: device descriptor read/64, error -62
Feb  6 22:00:05 meteohub kernel: usb 2-2: new full speed USB device using ohci_hcd and address 35
Feb  6 22:00:06 meteohub kernel: usb 2-2: device descriptor read/64, error -62
Feb  6 22:00:06 meteohub kernel: usb 2-2: new full speed USB device using ohci_hcd and address 36
Feb  6 22:00:06 meteohub kernel: usb 2-2: device not accepting address 36, error -62
Feb  6 22:00:06 meteohub last message repeated 3 times
Feb  6 22:00:06 meteohub kernel: usb 2-2: new full speed USB device using ohci_hcd and address 37
Feb  6 22:00:07 meteohub kernel: usb 2-2: device not accepting address 37, error -62
Since update to 4.9e (this may not be the fault of 4.8e, I have only connected the Vantage today)
Serial USB adapter is FTDI Sparkfun FTDI Basic breakout 3.3v DEV-098373
Re: Update 4.9d
Post by admin » Mon Feb 06, 2012 1:43 pm
can you please send me the USB section of the "dmesg" log on "Log Files" page.
What Meteohub HW are you using? or output of "lsusb" when working on the linux shell.
one more thought... the vantage serial logger does deliver full +/- 12v signals,
or are you working with a home brew data logger directly connecting to the consoles
20 pin header as discussed on "wxforum.net"?
Aussie101
Re: Update 4.9d
Post by Aussie101 » Mon Feb 06, 2012 2:02 pm
admin wrote:Hi,
Homebrew, as above. Sparkfun FTDI adapter as described on wxforum.
Hardware is Alix.3d
USB Serial worked on initial plugin under 4.9d:
Feb  5 19:49:47 meteohub kernel: usb 2-2: new full speed USB device using ohci_hcd and address 2
Feb  5 19:49:47 meteohub kernel: usb 2-2: configuration #1 chosen from 1 choice
Feb  5 19:49:47 meteohub kernel: ftdi_sio 2-2:1.0: FTDI USB Serial Device converter detected
Feb  5 19:49:47 meteohub kernel: drivers/usb/serial/ftdi_sio.c: Detected FT232RL
Feb  5 19:49:47 meteohub kernel: usb 2-2: FTDI USB Serial Device converter now attached to ttyUSB0
dmesg today after 4.9e:
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
ehci_hcd 0000:00:0f.5: EHCI Host Controller
ehci_hcd 0000:00:0f.5: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:0f.5: irq 10, io mem 0xefffd000
SCSI subsystem initialized
ehci_hcd 0000:00:0f.5: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 4 ports detected
ohci_hcd 0000:00:0f.4: OHCI Host Controller
ohci_hcd 0000:00:0f.4: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:0f.4: irq 10, io mem 0xefffe000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 4 ports detected
usb 2-2: new full speed USB device using ohci_hcd and address 4
usb 2-2: device not accepting address 4, error -62
usb 2-2: new full speed USB device using ohci_hcd and address 5
usb 2-2: device not accepting address 5, error -62
lsusb:
Bus 001 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
lsusb -v
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x0000
  idProduct          0x0000
  bcdDevice            2.06
  iManufacturer           3 Linux 2.6.24-etchnhalf.1-486 ehci_hcd
  iProduct                2 EHCI Host Controller
  iSerial                 1 0000:00:0f.5
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
  wHubCharacteristic 0x0009
    Per-port power switching
    Per-port overcurrent protection
    TT think time 8 FS bits
  bPwrOn2PwrGood       10 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0100 power
   Port 2: 0000.0100 power
   Port 3: 0000.0100 power
   Port 4: 0000.0100 power
Device Status:     0x0003
  Self Powered
  Remote Wakeup Enabled
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bDeviceProtocol         0 Full speed hub
  bMaxPacketSize0        64
  idVendor           0x0000
  idProduct          0x0000
  bcdDevice            2.06
  iManufacturer           3 Linux 2.6.24-etchnhalf.1-486 ohci_hcd
  iProduct                2 OHCI Host Controller
  iSerial                 1 0000:00:0f.4
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0002  1x 2 bytes
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
  wHubCharacteristic 0x0002
    No power switching (usb 1.0)
    Ganged overcurrent protection
  bPwrOn2PwrGood        3 * 2 milli seconds
 Hub Port Status:
   Port 2: 0000.0101 power connect
  Self Powered
Doesn't look good :(
Re: Update 4.9d
Post by admin » Mon Feb 06, 2012 2:55 pm
There have not been any changes to the usb serial drivers between the versions.
So my guess is, that the adapter has somehow stopped operation or is not
properbly connected on the USB side or does not get power.
As long as no product/verndor IDs are shown via lsusb, Meteohub has no chance to setup a usb serial channel.
Aussie101
Re: Update 4.9d
Post by Aussie101 » Mon Feb 06, 2012 2:57 pm
Ok, thanks Admin, I see that.
Will investigate the other side.
Cheers.
