OWL CM119 and rfxsensor not show in meteohub
This is intended for discussion and information about the rfxcom receiver module
Re: OWL CM119 and rfxsensor not show in meteohub
Yes, thanks. That is interesting, as record length is above 0x10. Meteohub does ignore that so far.
I will be back soon.
So, beta version is now running on your server.
power is reported in Watts, energy in kW/h.
jperillo
Post by jperillo »
Thank you so much !
You are a genius ! :D
jperillo
Post by jperillo »
I have two more question :)
1. Is it be possible to send to wdl the power ?
2. Is it possible to graph the power and energy ?
Thank you for your support.
1) no
2) yes, as with all other logged data.
jperillo
Post by jperillo »
I try to do a graph with my power comsumption but I receive a message asking me "No Data gnuplot execution failed" :?
I try different type of data but I receive ever the same message.
without seeing your definition on sensors page and without seeing your graph definition no one will be able to help you fixing your setup bug.
jperillo
Post by jperillo »
jperillo
Post by jperillo »
jperillo
Post by jperillo »
From an previous update, I don't receive any info from my OWL sensor.
And I have an another strange behaviour, the UVN 800 goes up after 3 uvi ( he go up of 8 uvi today on the Oregon display )
Can you help me another time, please ?
Thank you
I have difficulties in understand what the problem exactly is.
1) Do you receive data from your OWL or don't you?
2) What is wrong with the UVI? does it display in Meteohub lower values than the console?
Please explain a bit more in detail and with a bit more context.
jperillo
Post by jperillo »
Point 1 : No data displayed on meteohub. I can receive data on my pc with the rfxtrx
The attachment Capture.PNG is no longer available
Ponit 2 : uvi goes normal ( like the wmr200 ) to 3 and upper 3 meteohub display nothing, On my WMR200 I can see uv upper 3 uvi.
For your information I had to multiply by 10 the uvi info into meteohub to have the good uvi, like this
The attachment Capture2.PNG is no longer available
PS : Sorry for my english :(
Could you please give me access on ports 22 and 7777. This will help a lot to get it fixed.
Please email credentials to "info(at)meteohub.de".
Thanks for giving me access. I did some changes in the code. Please do a test drive and check if issues are gone now.
There is still a lot of logging in "meteohub log" according to rfxtrx, this will be removed when changes go into
next offical Meteohub release.
jperillo
Post by jperillo »
Thank you, I think it works well.
