How best to troubleshoot intermittent data capture problems
mclancy10006
Post by mclancy10006 » Tue Aug 04, 2015 4:26 am
I have lots of issues with the Meteostick not getting data from my Davis Vantage Pro 2 ISS for small chunks of the day. This most obvious with rain fall totals. If I look at the Vantage console unit for the last 2 days of heavy rain I see for example an inch more rain on the console than the PWSweather site. When I was looking on the meteobridge system console when data was not available it seems like the signal was lost. I have move things around a number of times to different locations in the house and at present I am about 25 feet from where the ISS is outside. About as close as I can get.
If you look at my station history http://www.pwsweather.com/obs/TPA33629.html you can see all kinds of gaps. I have adjusted the upload times to a lower frequency but that didn't seem to change the behavior of the Meteostick to data upload process having gaps either.
How best to troubleshoot this?
-Mark
Re: How best to troubleshoot intermittent data capture probl
Post by admin » Tue Aug 04, 2015 10:49 pm
1) Select a suitable RF clip level. If signal levels are at -75db, please set RF threshold to -85db
2) Use a USB cradle (a USB extension cable will also do) to bring the Meteostick a bit away from the Meteobridge HW and the other RF noise generators around.
3) Use latest Meteostick firmware. You can use "Update Firmware" button on "system" tab.
mclancy10006
Post by mclancy10006 » Sat Aug 08, 2015 10:41 pm
1) When it works I get -60 to -67db. I was set for -95DB, I changed to -80db and will watch it. When it is not working I only see the internal temp sensor data.
2) I am using a USB cradle and 1m cable. The meteostick is away from the tp-link hub as much as possible
3) I am on 2.3b1 on the stick and 2.5 on the tp link bridge
08.08.2015 16:13:38): Historical data loaded (23 records).
logger (08.08.2015 16:13:38): data logger (version 5.0i, build 6790) started.
logger (08.08.2015 16:13:38): connect station 0 (Meteostick Vantage via USB serial).
logger (08.08.2015 16:13:38): transmitter 1 registered as ISS
logger (08.08.2015 16:13:38): Meteostick Version 2.3b1
logger (08.08.2015 16:13:38): debug off
logger (08.08.2015 16:13:38): verbose off
logger (08.08.2015 16:13:39): output raw (8 bytes)
logger (08.08.2015 16:13:39): output raw (10 bytes)
logger (08.08.2015 16:13:39): filter on
logger (08.08.2015 16:13:39): rx threshold set to -80db
logger (08.08.2015 16:13:39): listening to transmitter 1
logger (08.08.2015 16:13:39): chip authentication ok: 14
logger (08.08.2015 16:13:39): frequency band 915MHz (US)
Platform: TP-LINK TL-MR3020 (no USB hub)
RAM: 29364 kB total, 3936 kB free (86% used)
SW Version: Meteobridge 2.5 (Jul 31 2015, build 6790), FW 1.4
Uptime: 1 hours, 27 minutes Buffer Usage: 0 items (0%)
Sensor Signal Metric Data Imperial Data
Indoor 1m 95.8% 25.0°C 30% 1014.1hPa (1013.2hPa) 77.0°F 30% 29.95inHg (29.92inHg)
Rain 5s -62db rate 0.0mm/h rate 0.00in/h
Outdoor 8s -60db 28.2°C 87% (dew 25.8°C, heat 33.8°C) 82.8°F 87% (dew 78.4°F, heat 92.9°F)
Wind 2s -67db 1.4m/s (avg 0.7m/s) 251° WSW 3.1mph (avg 1.6mph) 251° WSW
Post by admin » Sun Aug 09, 2015 8:51 am
95,8% reception rate is very good, update interval also looks fine.
mclancy10006
Post by mclancy10006 » Thu Aug 13, 2015 2:26 am
OK so far so good with no data capture gaps.
-Mark
vade64
Re: How best to troubleshoot intermittent data capture problems
Post by vade64 » Tue Aug 01, 2017 6:44 pm
I am having a similar problem with intermittent data capture on my DIR-505 connected to an Acurite Smarthub. Acurite supports uploading data to Weather Underground directly/natively. When I log in to my WU account online, all data is there with no gaps. Therefore, I know that the Smarthub device is not experiencing issues with connectivity between it and the weather station (Acu-Rite 5-in-1 station). My suspicion is that the meteobridge it losing connectivy to the service that it should be posting to. I have it set up to feed to both PWSWeather as well as CWOP. They both show successful posting once I reboot the Meteobridge but fail at some point after. I have my MB set to post every 5 minutes and retry indefinitely. Am I missing something?
