Leaf Wetness / Soil Moisture Station data to Wunderground
BrentonSpear
Post by BrentonSpear » Mon Mar 06, 2017 6:39 am
I have a TL-WR3040 in place uploading data to Wunderground successfully.
My hardware consists of the following:
  • Davis Vantage Pro 2 Plus - FARS installed
    Leaf Wetness / Soil Station with 1 Soil Moisture sensor and 1 leaf wetness sensor - These are both plugged into the #1 position on the station.
    Envoy8x
The Pro2 Plus data is all uploading correctly but the soil moisture ('humidity') sensor does not show up on Wunderground.
In the 'Live Data' tab it shows:
Soil #30 3 sec -17.8°C 20cbar -0.0°F 20cbar
Soil #32 43 sec -17.8°C 0cbar -0.0°F 0cbar
Soil #33 43 sec -17.8°C 0cbar -0.0°F 0cbar
Leaf #36 43 sec 0.0°C 0wet 32.0°F 0wet
Soil #30 is the correct value I want to upload to Wunderground.
Soil #32 & Soil #33 are not related to any sensors I have attached - I am not sure why they are reporting.
Leaf #36 is my leaf wetness sensor and is working correctly but not uploading (showing up) to Wunderground.
My question is, how do I make sure that Soil #30 and Leaf #36 is uploaded to the correct values in Wunderground?
BrentonSpear
Re: Leaf Wetness / Soil Moisture Station data to Wundergroun
Post by BrentonSpear » Mon Mar 06, 2017 7:17 am
I have just done some more testing of the leaf soil station and found that the indoor console and the envoy8x is correctly picking up both the leaf wetness and soil moisture (humidity) sensors from the leaf / soil station.
Seems that the data is not being correctly transferred from the envoy8x to meteobridge.
Im still not sure why 2 of the soil moisture sensors are showing up in MB when nothing is connected to them.
This is what I currently see:
Soil #30 3 sec -17.8°C 44cbar -0.0°F 44cbar
Soil #32 27 sec -17.8°C 0cbar -0.0°F 0cbar
Soil #33 27 sec -17.8°C 0cbar -0.0°F 0cbar
Leaf #36 27 sec 0.0°C 0wet 32.0°F 0wet
Soil #30 is correctly reporting
Soil #32 has nothing connected to it
Soil #33 has nothing connected to it
Leaf #36 is the first leaf wetness connection in the station leaf soil station and is not reporting anything but my inside console is showing the right values.
BrentonSpear
Post by BrentonSpear » Tue Mar 07, 2017 10:38 pm
Anyone have any advice for me on this?
BrentonSpear
Post by BrentonSpear » Sun Mar 12, 2017 12:05 am
With further testing it seems that the MB is only able to read one of the sensors at a time. Either the leaf wetness or the soil moisture.
UrbanPoser
Post by UrbanPoser » Tue May 09, 2017 5:02 am
I'm also seeing the extraneous sensor data on channels that don't exist. This only started happening once I added a soil temp/moisture station. However, they appear to be "secondary sensors", and don't affect my graph templates, so they don't bother me as much. But I am as curious as you why these extra values are showing up at all.
below is a snapshot of my live data. All sensors in bold are extraneous, and do not correspond to any actual sensors.
Live Data
Sensor Signal Metric Data Imperial Data
Outdoor 17 sec 3.6°C 84% (dew 1.2°C, heat 3.6°C) 38.5°F 84% (dew 34.2°F, heat 38.5°F)
Outdoor T #1 18 sec 12.2°C 54.0°F
Outdoor T #2 18 sec 12.8°C 55.0°F
Outdoor T #3 18 sec 12.2°C 54.0°F
Outdoor #1 18 sec 12.2°C 0% (dew 12.2°C, heat 12.2°C) 54.0°F 0% (dew 54.0°F, heat 54.0°F)
Outdoor #2 18 sec 12.8°C 0% (dew 12.8°C, heat 12.8°C) 55.0°F 0% (dew 55.0°F, heat 55.0°F)
Outdoor #3 18 sec 12.2°C 0% (dew 12.2°C, heat 12.2°C) 54.0°F 0% (dew 54.0°F, heat 54.0°F)
Soil #10 18 sec 13.3°C 4cbar 55.9°F 4cbar
Soil #11 18 sec 12.2°C 0cbar 54.0°F 0cbar
UV 18 sec 0.0uvindex 0.0uvindex
Solar 18 sec 0W/qm 0W/qm
Wind 2 sec 0.0m/s (avg 0.0m/s) 323° NW 0.0mph (avg 0.0mph) 323° NW
Rain 18 sec rate 0.0mm/h rate 0.00in/h
Indoor 29 sec 17.6°C 48% 1014.1hPa (1010.4hPa) 63.7°F 48% 29.95inHg (29.84inHg)
Post by admin » Wed May 10, 2017 2:16 am
Looks to me like sporadically coming in data from an neighbor ISS. Just ignore and you are fine.
