What's wrong with my rain?
WH-1080 weather station is also known as Watson W-8681, WX-2008, National Geographic 265 NE, Elecsa 6975 and 6976.
Wölkchen
Re:What's wrong with my rain?
Post by Wölkchen » Mon Mar 02, 2009 6:30 pm
Hallo skyewright
We have had rain again these night. The difference was only 0,2mm. The total rain wars 3,3mm.
My station has show my 3,3mm, WD has show my 3,1mm rain.
You are secure it isn't the offste setting?
Regrads Wölkchen
Post by skyewright » Mon Mar 02, 2009 7:36 pm
Wölkchen wrote:We have had rain again these night. The difference was only 0,2mm. The total rain wars 3,3mm.
Do you have an offset set anywhere?
If the correct rain is getting into Meteohub's records, then that same figure ought to get into WD.
Wölkchen
Post by Wölkchen » Mon Mar 02, 2009 8:45 pm
Yes, you are right. But it is not so.:S
My Station shows me 3.3 mm,meteohub shows me 3.3 mm,WDL shows me 3.3 mm to ,but WD shows me 3.1 mm.:X
I can not set the rain in meteohub, but WD.
Post by skyewright » Mon Mar 02, 2009 11:37 pm
Wölkchen wrote:Yes, you are right. But it is not so.:S
The only reason I can think of for that is the original one, i.e. that for some reason WD is not 'seeing' the rain0 sensor often enough when it does the "most recent sensor" request every 3 seconds.
It's difficult to test that theory without seeing the sort of 'debug' data that my WD produces but that yours does not seem to. :(
Here's something to try. If you use these URLs in your browser (replace 192.168.0.78 with your Meteohub local IP), what do you get?
http://192.168.0.78/meteolog.cgi?mode=data
http://192.168.0.78/meteolog.cgi?mode=d ... 0302170100
Wölkchen
Post by Wölkchen » Tue Mar 03, 2009 6:58 pm
Here I am again;)
I hope I do not pester:dry:
I have hunted for a period with rain.
And I have found that:
20090301223414 rain0 0.0 168.3
20090301223414 th0 8.4 86 6.2
20090301223414 thb0 20.9 48 9.5 977.2 1006.6 -1
20090301223414 wind0 270 0.3 0.0 8.4
20090301223428 rain0 0.0 168.3
20090301223428 th0 8.4 86 6.2
20090301223428 thb0 20.9 48 9.5 977.2 1006.6 -1
20090301223428 wind0 270 0.3 0.0 8.4
20090301223442 rain0 0.3 168.6 -1
20090301223442 th0 8.4 86 6.2
20090301223442 thb0 20.9 48 9.5 977.2 1006.6 -1
20090301223442 wind0 270 0.0 0.0 8.4
20090301223456 rain0 0.3 168.6
20090301223456 th0 8.4 86 6.2
20090301223456 thb0 20.9 48 9.5 977.2 1006.6 -1
20090301223456 wind0 270 0.0 0.0 8.4
20090301223510 rain0 0.3 168.6
20090301223510 th0 8.4 86 6.2
20090301223510 thb0 20.9 48 9.5 977.2 1006.6 -1
20090301223510 wind0 270 0.0 0.0 8.4
20090301223524 rain0 0.3 168.6
20090301223524 th0 8.4 86 6.2
20090301223524 thb0 20.9 48 9.5 977.3 1006.7 -1
20090301223524 wind0 270 0.0 0.0 8.4
20090301223538 rain0 0.3 168.6
20090301223538 th0 8.4 86 6.2
20090301223538 thb0 20.9 48 9.5 977.3 1006.7 -1
20090301223538 wind0 270 0.0 0.0 8.4
20090301223552 rain0 0.3 168.6
20090301223552 th0 8.4 86 6.2
20090301223552 thb0 20.9 48 9.5 977.3 1006.7 -1
20090301223552 wind0 270 0.0 0.0 8.4
20090301223606 rain0 0.3 168.6
20090301223606 th0 8.4 86 6.2
20090301223606 thb0 20.9 48 9.5 977.3 1006.7 -1
20090301223606 wind0 270 0.0 0.0 8.4
20090301223621 rain0 0.3 168.6
20090301223621 th0 8.4 86 6.2
20090301223621 thb0 20.8 48 9.4 977.3 1006.7 -1
20090301223621 wind0 0 0.3 0.0 8.4
20090301223635 rain0 0.3 168.6
20090301223635 th0 8.4 86 6.2
20090301223635 thb0 20.8 48 9.4 977.3 1006.7 -1
20090301223635 wind0 0 0.3 0.0 8.4
20090301223649 rain0 0.3 168.6
20090301223649 th0 8.4 86 6.2
20090301223649 thb0 20.8 48 9.4 977.3 1006.7 -1
20090301223649 wind0 0 0.3 0.0 8.4
20090301223703 rain0 0.0 168.6
20090301223703 th0 8.4 86 6.2
20090301223703 thb0 20.8 48 9.4 977.4 1006.8 -1
20090301223703 wind0 0 0.0 0.0 8.4
20090301223717 rain0 0.0 168.6
20090301223717 th0 8.4 86 6.2
Is this interesting?
Wölkchen
Post by skyewright » Tue Mar 03, 2009 7:31 pm
Wölkchen wrote:Here I am again;)
<SNIP>
Yes. It shows what I suspected.
The sensor readings arrive in groups, all with the same timestamp, and rain is always the first.
Given the approach that WD has adopted to read from Meteohub, and especially the way that rain is handled, that is very inconvenient. :(
Every few (5?) seconds, WD asks for the "latest sensor reading".
The way your sensor readings are recorded means that there is a very, very small time in which rain0 is ever the "latest sensor reading".
Once a minute, WD also asks for "all the sensor readings in the last minute", so in theory that's okay and is the reason why you don't also have a problem with th0 and thb0 but unfortunately WD only check rain readings in the "latest sensor reading" section.
There is a good reason for only checking rain in one place but it's probably too complex for my explanation to translate well!
All would be well if rainfall were checked in "all the sensor readings in the last minute" instead of in "latest sensor reading". I have previously suggested that to the WD developer. Maybe it's time I suggested it again...
I hope that makes at least a little sense when translated! :)
Post by admin » Tue Mar 03, 2009 7:45 pm
I can't believe this line:
The "-1" should not be there.
Wölkchen
Post by Wölkchen » Tue Mar 03, 2009 8:25 pm
Hallo skyewright
Hallo admin
I have understood everything,and I can follow your explanation. So it's a programming problem, and only from Wd to change.
If you have contact with WD, that would be very nice of you,the problem there to explain.
I thank you for all your patience would be glad to hear from you.I was very pleased with someone from Scotland to be allowed to speak.
Thanks for everything:)
Greeting Wölkchen
Hallo admin
What is wrong with the value -1:S
If not for the other WH-1080 generated?
Greeting Wölkchen
Post by skyewright » Tue Mar 03, 2009 8:48 pm
admin wrote:I can't believe this line:
Maybe just a copy => paste => edit error, with the -1 somehow slipped from the -1 at the end of the thb0 lines?
Post by skyewright » Tue Mar 03, 2009 8:52 pm
Wölkchen wrote:So it's a programming problem, and only from Wd to change.
Yes.
I'll try, when I get the opportunity.
Happy to help. :)
I hope I can help further by getting this solved for you, and others.
Wölkchen
Post by Wölkchen » Wed Mar 04, 2009 3:51 pm
Could it be that here is the error?
I have now meteohub in the attitudinal=> weatherstation => Holding period of live data,the value changed.
After that,I was able to observe,that the rainfall in Dashboard was wrong.
What kind of value would be correct, for my station?
Wölkchen
Post by skyewright » Wed Mar 04, 2009 5:52 pm
Wölkchen wrote:I have now meteohub in the attitudinal=> weatherstation => Holding period of live data,the value changed.
I do not believe that that is relevant to the problem of WD not seeing your rainfall as it happens.
I believe that the setting you mention sets how long Meteohub itself considers a reading to be valid as 'live' data if a sensor stops reporting.
