nslu2 crash for hot temperature
moretto
Post by moretto » Thu Aug 07, 2008 5:09 pm
I solved the problem of crash nslu2 with hot temperature.The defect is the'quartz of 30.00 mhz.Simple detach from the circuit with a welder
and move near port usb1 metal.
I hope to be helpful.
binbags
Re:nslu2 crash for hot temperature
Post by binbags » Thu Aug 07, 2008 6:13 pm
Hi
How did you decide that it was the crystal that was the problem? By using "freezer" spray?
Inerested, as my nslu2 lives in the loft of the house and this can get quite warm up there.
moretto
Post by moretto » Thu Aug 07, 2008 9:04 pm
To see if the quartz 30 MHZ is defective , just bring (at 0,5 cm) a common solder for electronics (hot). after about 20-30 second nslu2 hangs, or crash.
bsparks
Post by bsparks » Tue Aug 12, 2008 1:27 pm
Hmmmm. Very interesting, and something I will have to keep in mind if my NSLU2 starts acting up.
moretto
Post by moretto » Tue Aug 12, 2008 7:49 pm
After the modification or replacement of quartz my nslu2 not 'ever more locked!!!!
binbags
Post by binbags » Tue Aug 12, 2008 8:51 pm
Hi Moretto
Question 1
Had your NSLU2 gone faulty before you used the soldering iron?
Question 2
Did the fault correct itself after the unit cooled down?
Question 3
What lead you to suspect the crystal unit?
It's just nice to have an autopsy of what you did.
regards and well done.:woohoo: :woohoo: :woohoo:
binbags
moretto
Post by moretto » Wed Aug 13, 2008 6:05 pm
sorry but I did not understand the questions.
I solved everything chilling the 30mhz quartz, welding quartz metal on metal of usb2 port.
first my nslu2 always hangs just did little hot, now is in operative for two months without problems.
Scarlett
Re: nslu2 crash for hot temperature
Post by Scarlett » Sat Oct 11, 2014 11:16 am
An important thing about flash memory to use with Meteohub and NSLU2 is "wear leveling". The USB sticks of major brands are known to do this quite fine (some OCZ sticks allow for definition of separate areas to be used when parts of the flash storage might fail). As I don't think, that SD memory cards are also doing this to that extent, you would have the risk of memory failures after a while.
Download high quality free-braindumps.net dumps to prepare and pass SAP with oracle certification dumps certification.
