Alix3D3 meteohub with weatherlink ip davis vue?
somiedo
Post by somiedo » Fri Feb 14, 2014 8:44 pm
Hello, good evening. I need help please.
I have a vue davis meteorological station and WeatherLink IP, also I have meteohub with Alix 3D3. Is there any way to connect my davis vue with meteohub Alix 3D3? I've tried everything. But I do not get it to work.
What I have tried is to connect my Alix 3D3 meteohub the internet router and one of these ports also connect the WeatherLink Ip davis vue. When I set my meteohub in the meteorological station, I put the IP that has davis vue in my router, but I can not be connected. What am I doing wrong? I need help, thank you very much.
Best regards from Spain.
somiedo
Re: Alix3D3 meteohub with weatherlink ip davis vue?
Post by admin » Fri Feb 14, 2014 10:39 pm
Should work. I would recommend to configure the router in a way that it provides a fixed IP
to the MAC of the WLIP. Doing that you avoid the risk that the router assigns a new IP to the
WLIP and Meteohub then cannot reach it anymore.
somiedo
Post by somiedo » Sat Feb 15, 2014 2:29 pm
This is the screenshot of the settings to meteohub davis vue:
The ipa 192.168.1.35 is the IP that my router gives the weather station davis vue. What is wrong?
captura 1 meteohub peq.jpg (164.75 KiB) Viewed 2459 times
Post by admin » Mon Feb 17, 2014 11:45 pm
Don't choose "TCP/IP Meteohub" but "TCP/IP". The option you selected indicates that
the Meteohub should daisy-chain via TCP/IP to another Meteohub that has a weather station
connected.
