UMTS and Meteohub ? *Solved*
Hardware topics that do not fit in one of the other categories
paolo_ver
Post by paolo_ver » Sun Nov 23, 2008 10:18 pm
Hi from Verona, Italy!:cheer:
I've a remote nexus-tfa station that i would to use with Meteohub...but there is no dsl or telephone connection at the station location...only umts is available...:angry:
it is possible to use a umts-phone connected by USB on meteohub-hardware to upload data on the internet ? I have to buy a umts-router to do this kind of connection with NSLU2? (because not enough usb port?) and with other hardware (ebox - minipc etcc...) may i use this simply method against the expensive umts-router solution? :unsure:
Thanks in advance!!:cheer:
Paolo.
Casappa
Re:UMTS and Meteohub ?
Post by Casappa » Mon Nov 24, 2008 12:38 am
Forse e' meglio che provi con un router gprs che con un telefono usb umts.
English:
I think a gprs router it is better then usb cell phone.
Alberto.
paolo_ver
Post by paolo_ver » Tue Nov 25, 2008 10:32 pm
Ciao,
grazie, però mi sembra che la spesa lieviterebbe alquanto, conosci qualche router di quel tipo a prezzo abbordabile ?
Paolo.
English:
Thank you, but i think that ia an expensive solution, do you know any router at a "not so expensive" cost ?
Paolo.
paolo_ver
Post by paolo_ver » Tue Dec 23, 2008 11:49 pm
I have resolv the question buying a umts-router ...the things are working very well!!!!:laugh:
Re:UMTS and Meteohub ? *Solved*
Post by admin » Wed Dec 24, 2008 12:44 am
Great to hear that it works. Direct UMTS support by means of USB Huawei modems is still in the works. I have an experimental version included into 3.3 but this doesn't really do the trick. I hope I can improve on this during the next updates. Having an UMTS router will be the better solution, anyway.
paolo_ver
Post by paolo_ver » Wed Dec 24, 2008 9:24 pm
Yes, the router is working very well and with a volume based rate I don't spend too much (just 9 euro at month) I'm very happy with this solution! :)
Now I have again the problem of loosing communication from the temp/hum sensor...but I'll update another thread!
Hi! ;)
paolo_ver
Post by paolo_ver » Thu Mar 12, 2009 8:28 pm
Update: I found that an Web'n'walk box III based of the globesurfer II from Option is a great solution!!
www.meteocorne.altervista.org
Hi!:)
joaoj
Post by joaoj » Fri Dec 11, 2009 10:38 am
hi Paolo
can you tell me what is the model of modem umts that you use
Thanks in advance
