WEATHERBRIDGE Not working with WeatherLink
QC91
Post by QC91 » Mon Jan 13, 2020 12:23 am
Hi, we have the WeatherBridge on are WiFi Network, we have Davis Vantage Pro2 with data logger we have the USB going to Belkin Travel 4-Port USB 2.0 Hub at is plug into the WeatherBridge, we have logged to the WeatherBridge we can see all the data from the Vantage Pro2 but when we try to connect via WeatherLink Communication TCP/IP with Port 22222 we keep getting Device not Found, we use the IP address of the WeatherBridge, any help would be appreciated.
Re: WEATHERBRIDGE Not working with WeatherLink
Post by Mattk » Mon Jan 13, 2020 12:53 am
What are you trying to connect to, WeatherBridge or the VP2? Port 22222 typically is used for a WeatherLinkIP logger and you are using USB logger.
QC91
Post by QC91 » Mon Jan 13, 2020 1:54 am
Hi, Mattk I'm trying to connect to the VP2 via my Desktop PC we are on the same network, I wanted to use my Davis WeatherLink Software so I can save my data locally, thanks for the help
Post by Mattk » Mon Jan 13, 2020 9:46 am
Is your Weatherbridge Red or Black?
Post by wvdkuil » Mon Jan 13, 2020 11:17 am
99.9% of the times the "pass-thru" works out of the box. I always use it to test different weather-programs.
It never works with WeatherLink on a Mac as it does not support that.
This 'Device not found" message sometimes occurs when the PC and the Meteobridge are not on the same "WiFi accespoint".
F.i. when the Meteobridge is cabled to the router and the PC/laptop is on a WiFi access-point.
To check this out, connect the Meteobrtidge and the PC/laptop to the same router/switch, if possible both with a cable.
The Meteobridge should be seen the same as other devices on your network.
Set the network trust level as high as possible in windows network settings
Check if you can "ping" the Meteobridge from the PC/laptop and if you can open the Meteobridge in a browser on the same pc as weatherlink
Update Weatherlink to the latest release.
If all fails double check the ip-address and 22222 , then try another laptop.
It should work, it always does.
Support for Leuven-Template & Scripts at https://support.leuven-template.eu/
Support for the PWS_Dashboard (HWS-template) https://pwsdashboard.com/
QC91
Post by QC91 » Mon Jan 13, 2020 9:50 pm
Thank you everyone I will give it try, also this the WEATHERBRIDGE we have is white https://www.ambientweather.com/amweatherbridge.html
QC91
Post by QC91 » Sun Jan 19, 2020 10:04 pm
I directly connected to the router via ethernet but the weather link is still not working, I get "Device not found" I'm using the IP address of the Meteobridge I will send screenshots, I also did a Factory reset
Post by admin » Sun Jan 19, 2020 10:55 pm
Why don't you let the Meteobridge do the feeding of Weather Link? "WL Cloud" weather network is fine for doing this.
So you can get rid of your PC driven stuff completely.
QC91
Post by QC91 » Sun Jan 19, 2020 11:05 pm
Thank you how can I set that up?
Post by admin » Sun Jan 19, 2020 11:09 pm
galfert
Post by galfert » Wed Jan 22, 2020 2:30 am
Looks like you have a class B local network. Your subnet mask is 255.255.0.0. Although there is nothing technically wrong with using a class B subnet, some stupidly configured devices/software (Davis software in this case) may have been improperly developed so that they only support a class C network (subnet mask 255.255.255.0). Now this is just an assumption on my part. But it would be worth testing on a class C network.
Is there any reason why you have a class B network? What kind of router are you using?
MR3020 v1
GW1000
