WARNING: incompatible MR3020 V1.9 routers out there! **solved**
Re: WARNING: incompatible MR3020 routers out there! RISK OF BRICK **solved**
License for unlimited use is 65 Euros. Conversion between USD and Euro is done by paypal. I don't think you need me pointing to money conversion pages, your google will do fine on that ;-) License includes 2 years of free updates. After that additional 2 years of update service is 19 Euros. But this service is optional, just in case you are keen to have the updates. You can decide any time in the future to go for it, when new features arise which are worth the money from your point of view. Details on licensing can be found here: http://meteobridge.com/wiki/index.php/License_Terms
Now please have this thread focused again on the MR3020 hardware topics again. :D
Andyk1
Re: WARNING: incompatible MR3020 V1.9 routers out there! **solved**
Post by Andyk1 »
Since I registered my new TL-WR902AC instead of this TL-MR3020(UN)1.9 it no longer is usable on MB. I attempted to flash it back to use as a repeater or a bridge but it will not flash to anything other than a "openwrt-15.05.1-ar71xx-generic-tl-mr3020-v1-squashfs-factory.bin" which is nothing more than Luci and mostly unusable as a router. Does anyone have a copy of the original as TP-LINK no longer lists the firmware for this device. I attemped to flash it to any version but just won't accept any firmware. I tried searching but could find no way to flash it back. Any help would be appreciated.
V1 firmware is available on TP-Link web pages: https://static.tp-link.com/res/down/sof ... 150921.zip
Andyk1
Post by Andyk1 »
Tried that one. Won't install. Can't remember the exact message but said something like not a compatible file name or something. No matter, hard bricked trying a tftp method and need a ttl cable compatable with win 10 drivers. Anyway... thanks anyway.
mariomarconi
Post by mariomarconi »
I flashed the following mr3020 v1.9 with http://connect.meteobridge.com/files/me ... 0-v1.5.bin but now it doesn't work. What can I do now?
These routers are supported for sure. Must be something else that went wrong when flashing this.
