after loading fw 3.7 released August 25, 2018 does not load camera ftp **solved**
jmontamat
Post by jmontamat »
I use a local foscam
External Picture URL: 192.168.1.55:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2
correctly generates aircam.jpg but does not load ftp.
in fw 3.6 works well.
I guess the problem is in:
adds support for HTTPS URLs for grabbing web cam pictures.
Platform: TL-MR3020 (plus USB hub)
RAM: 29364 kB total, 3312 kB free (88% used)
SW Version: Meteobridge 3.7 (Aug 26 2018, build 12309), FW 1.4
Josep.
Sin título.png (17.78 KiB) Viewed 2720 times
dgunnell
Re: after loading fw 3.7 released August 25, 2018 does not load camera ftp
Post by dgunnell »
Same problem it broke in that release!
dgunnell
Post by dgunnell »
Does not upload to wunderground either!
Version 3.7
released August 27, 2018
fixes a freshly introduced bug that prevents web cam pictures to be uploaded to the Meteobridge server.
Support for Leuven-Template & Scripts at https://support.leuven-template.eu/
Support for the PWS_Dashboard (HWS-template) https://pwsdashboard.com/
dgunnell
Post by dgunnell »
I have Meteobridge 3.7 (Aug 26 2018, build 819), FW 1.1 tried to reboot with update on reboot set and still says Aug 26 build 819.
Andyk1
Post by Andyk1 »
Same. Multiple reboots and I am still getting.
Platform: TL-WR902AC (no USB hub)
RAM: 60056 kB total, 21352 kB free (64% used)
SW Version: Meteobridge 3.7 (Aug 26 2018, build 819), FW 1.1
Uptime: 4 hours, 23 minutes Buffer: 2 items (0%)
Not updating to Aug 27 2018 version.
Cam uploads/updates still failing.
Andy
fixed with todays release.
jmontamat
Re: after loading fw 3.7 released August 25, 2018 does not load camera ftp **solved**
Post by jmontamat »
Is this the latest version? I do not load another ... it does not work.
Platform:TL-MR3020   (plus USB hub)RAM:29364 kB total, 3372 kB free (88% used)SW Version:Meteobridge 3.7 (Aug 26 2018, build 12313), FW 1.4Uptime:0 hours, 5 minutes    Buffer: 0 items (0%)
nope, it is from August 27. I deployed it again, just to make sure the upload went fine.
jmontamat
Post by jmontamat »
Yes now !!!
TL-MR3020   (plus USB hub)RAM:29364 kB total, 2424 kB free (91% used)SW Version:Meteobridge 3.7 (Aug 27 2018, build 12317), FW 1.4Uptime:0 hours, 4 minutes    Buffer: 0 items (0%)
Work fine  tnx.
dgunnell
Post by dgunnell »
Confirmed update took place and web camera image upload to wunderground working again!
Andyk1
Post by Andyk1 »
Still not working as of 6:09am 8/28/2018. Had to go back to 3.6 on the TL-AC920
Do I need to change my http:// to https:// as I am reading this correctly?
dgunnell
Post by dgunnell »
Here is what my camera URL setting looks like:
http://Your IP Address:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=Your UserID&pwd=Your Password
Andyk1 wrote:
Tue Aug 28, 2018 1:12 pm
When it is automatically rerouted by your cam to a HTTPS URL then you need to use the final HTTPS address to avoid a hidden protocol change which makes Meteobridge to decide falsely if the non-ssl or ssl-enabled wget should be used for data transfer form the cam.
pb2rdf
Post by pb2rdf »
just did a test with latest runlevel.
Did a reboot.
Login meteobridge via webinterface.
Meteobridge Weather Cam option was again selected on "none"
And no upload of a weathercam image.
Have to enable it again.
After enable the image is uploaded every minute to my local ftp server.
Still a big, I'm afraid.
Somehow the selection to enable upload in the Weather Station tab is not proper saved in the config file of meteobridge, I assume.
See also my message :
viewtopic.php?f=61&t=12633#p25867
regards, Peter
