MB reporting way too much rain **solved**
doncurtis
Post by doncurtis »
I recently replaced my poor WS-1090 with a Davis Vantage Vue plus Davis Weatherlink Live.
MB is working just fine until we had a thunderstorm early this morning. All 3 sites MB sends data to show a very rapid 1.8 inches of rain. MB live Data page shows 1.78 inches of rain at the rate of 81 inchrs/hr.
My Vue console shows 0.07 inches of rain and the Weatherlink Live sent 0.07" to weatherlink.com
I checked my station setup in MB, it shows 0.2mm resolution from the ISS and a rain multiplier of 1.00
So...the Weatherlink Live and Vue Console are reporting correctly, MB isn't.
Don
Don
Re: MB reporting way too much rain
And the MB is reading rainfall form the same rain gauge as WeatherLink?
Also cabled or RF?
doncurtis
Post by doncurtis »
Yes. MB is getting all its data from the Weatherlink Live. And the Weatherlink Live gets all its data on outdoor conditions from my Vantage Vue ISS as does my Vantage Vue console.
Don
Don
galfert
Post by galfert »
Seems that the same problem is being reported in the Meteobridge Pro sub
viewtopic.php?f=61&t=14255
MR3020 v1
GW1000
Also recall there being some discussion re funny rainfall amounts related to WeatherLink Live ?
galfert
Post by galfert »
Mattk wrote:
Thu Jul 18, 2019 6:06 am
I haven't seen that. Maybe you are confusing it with the "funny" rainfall with some Acurite Access devices?
https://www.wxforum.net/index.php?topic=37107.0
* FYI - for those uninformed, do not think that the Access is supported by the Meteobridge. I say this because I almost regret bringing up and mentioning this device on this Meteobridge forum.
MR3020 v1
GW1000
doncurtis
Post by doncurtis »
Yes, what Gus showed in his post is similar to what I am seeing.
My weatherlink live reports only to weatherlink.com
My Vue console only reads my ISS
MB reports to WU, AWEKAS and CWOP.
AWEKAS, WU & CWOP all showed 1.8" rain
Vue console and weatherlink.com showed 0.07"rain
Since I live, literally in the desert, getting 1.8" of rain in 15 to 20 minutes just isn't going to happen.
I too have MB weatherlink live set for 0.2mm resolution
Don
Don
galfert
Post by galfert »
Maybe there is a problem when setting the WLL to mm instead of inches. Perhaps the Meteobridge is interpreting those 0.2 mm as 0.2 inches.
MR3020 v1
GW1000
gus wrote:
Thu Jul 18, 2019 3:30 pm
http://www.wxforum.net/index.php?topic= ... #msg385387
No I don't believe I am confused? Maybe you can confirm if there is any connection?
galfert
Post by galfert »
Mattk,
OK yep I concur. I don't think they are related issues.
It seems to me that the problem with the WLL is with the WLL itself if the WLL app has the same issue. Which means that it probably doesn't make sense for a Meteobridge fix....as the issue is from the WLL itself.
MR3020 v1
GW1000
doncurtis
Post by doncurtis »
No... This issue I am seeing can't be with the WLL unless it is the WLL improperly reporting values to the query from MB but reporting proper values to weatherlink.com.
My Vue console reports correct values, it gets those values from the ISS
My WLL reports the correct values to weatherlink.com and likewise gets those values from the ISS
I presume the Davis WLL app (Android) simply reads the data on weatherlink.com as the app is not bluetooth connected or local IP connected to the physical WLL when I am away from home.. Yet the app still works.
MB queries the WLL and reports bad (but consistent) values to the networks it sends the data to.
Which sounds to me, like MB is mis-interepting the query reply it receives from the WLL.
Don
Don
doncurtis
Post by doncurtis »
This morning, again.. Short thunderstorm this morning, my console reporting.0.02" of rain. MB reporting 0.5" of rain to WU. WLL reporting to weatherlink.com 0.02" rain.
Having seen the entire rainfall... 0.02" would be correct. Lasted about 15 minutes, normal thundershower, moderate rainfall for just a few minutes.
Problem is with MB not WLL. MB is misinterpreting what WLL is providing by about 25x for this storm.
Don
doncurtis wrote:
Sat Jul 20, 2019 4:09 pm
what is showing in live data screen of meteobridge , I'm dubious when anyone throws wunderground into the equation however you may be on to something .
doncurtis
Post by doncurtis »
Here is the live data page from today:
As you can see.. A whole lot more rain today according to MB than really occurred
Don
doncurtis
Post by doncurtis »
Here is another shot showing what MB reported to CWOP
Don
