WL CLoud network support in Version 4.2
superduty
Post by superduty »
admin wrote:
Sat Oct 26, 2019 7:42 am
As some of the Meteobridge users here in the forum are deep into IT, I try to mention at least what kind of change I did. Please ignore when it is not making sense to you.
I fully recognize that and appreciate it. I was trying to be funny. I am always impressed by the level of knowledge many folks here have with regards to IT and how all this stuff actually works.
Again, thank you for your dedication and super quick responses to issues.
gand
Post by gand »
Hi
I don't know if this is the right place, but now I try otherwise Admin must advise.
I've installed upload to Weatherlink via Meteobridge and it works really well. I also installed the IOS Davis Weatherlink App and it works fine too. The only thing that seems strange is Windgust, which seems pretty high!!
Are there any others who have installed the Davis IOS App and have problems with Wind Gust?
Any good advice where to start looking for this issue?
Rgds
Gert
lightmaster
Post by lightmaster »
gand wrote:
Sat Oct 26, 2019 11:09 am
Hi
Rgds
Gert
That's not normal for you?? :lol:
I'll install the app on my iPad tomorrow and see how it looks for me. Question: How does it look on their website?
gand
Post by gand »
Hi
Screenshot for the Summary. Strange Windgust as well
Gert
2019-10-26 (1).png (104.44 KiB) Viewed 1840 times
meteolive57290
Post by meteolive57290 »
:D :D
actually it's not bad
no worries from my side about the corresponding bulletin_summary and app mobile IOS version 2.1.6 (217)
https://www.weatherlink.com/embeddableP ... d1/summary
which version of the application do you use ?
Bug does only affect Davis consoles with old firmware that does not support LOOP2 packets. It should be fixed with just released update.
gand
Post by gand »
Hi
I have rebooted to the latest version and it's much better now, but still to high (or maybe there is an explanation)
In the summary I have 21.9 m/s gust. I can't recognise that figure from Meteobridge.
Rgds
Gert
2019-10-26 (2).png (97.55 KiB) Viewed 1821 times
2019-10-26 (3).png (113.38 KiB) Viewed 1823 times
Should be fine with just released fix.
@gand: Did update your MB and it now shows a 10 min gust around 1-2 m/s on WL.
gand
Post by gand »
Hi Boris
Thanks for your hard work, seems to work perfect now.
BTW, as soon as I'm close to the weatherstation (300 km away), I'll upgrade the firmware.
Rgds
Gert
gand
Post by gand »
Hi
Hi
I have a question regarding rain. In the Weatherlink Bulletin the current rainfall shows 2.6 mm. If I look at the graph/data it shows 2.2mm (11 marks). In the data part there are also only 11 marks, each with 0.2mm. My console shows 2.6mm. Same thing with the Davis IOS app.
Is this a failure from the upload from MB or is it a bug in WL?
Any ideas?
I have upgraded the console to FM 3.80 using Loop2 packets.
Screenshots attached.
Rgds
Gert
2019-11-22 (1).png (107.94 KiB) Viewed 1504 times
meteolive57290
Hello
i have another problem on my side with my WWL device and the recording of the rain live ... most certainly a bug in reading the code that manages WLL precipitation!
3.4 mm recorded by my station against the 310.6 mm for the WWL :?: :?:
rain-live WWL
rain-live WWL
on the other hand no problem for my MB-pro and the report properly recorded and reported for example on the template WD34
http://valdefench57sgz.franceserv.com/pws/index.php
What kind of rain data does the Meteonbridge show, when it reads data from the WLL?
lightmaster
Here is the monthly and yearly rain data from my NanoSD:
This is what WL.com has for rain:
On WL.com, the table's monthly rain and the charts monthly rain don't agree, and neither match the MB's data. Yearly rain with WL.com doesn't match MB.
gand
Post by gand »
hI
For my part MB and WL match pretty good, only a couple of mm for yearly rain. Graphs and records(WL) for rain don't not match MB. Wind and temp match MB. Pretty odd.
I'm using
Meteobridge 4.2 (Nov 18 2019, build 2666), FW 1.3
TL-MR3020V3 (no USB hub)
Rgds
Gert
meteolive57290
admin wrote:
Fri Nov 29, 2019 12:45 am
@Boris
MB is monitoring with WL-IP from my main station
for me no worries in recording rain
it's my WWLive (application and web) that records completely inconsistent reports
while if I take my station singularly everything is correctly recorded
here is the answer I received from Davis (after my first report that goes back to May and the replacement of the device)
rain_WWL
rain_WWL
response Davis
response Davis
