FTP templates not working, although the FTP test works fine
wdg
Post by wdg »
I'm having issues FTP'ing templates to my web host. I first setup FTP using the Service Settings page and then successfully got the test_upload file to transfer to the test path directory:
However, in the Events page, when I perform a test of a template it never transfers to my webhost:
Any ideas what may be going on?
Re: FTP templates not working, although the FTP test works fine
Do you get any error message?
wdg
Post by wdg »
No errors are reported. All I see is:
Event #01 has been triggered manually
Nothing in the logs either.
wdg
Post by wdg »
When I go to Live Data I saw this message:
Data logger momentarily cannot provide data. Please try again in a minute. If it does not show up later, please also check weather station selection on "Station" tab.
I go to the Station tab and nothing alarming shows up. I decided to reboot Meteobridge and now all is working fine. I do see this in the logs:
logger (18.01.2021 11:18:49): No data hold period defined. Set to 300 secs as default.
logger (18.01.2021 11:19:28): message above repeats 2 times.
Anything I should worry about here?
looks like the logger does get stalled somehow. Could you give me remote access?
