Raspberry Pi Zero W
Volker S
Raspberry Pi Zero W
Post by Volker S » Tue Feb 06, 2018 3:23 pm
Is the Raspberry Pi Zero W compatible with meteohub? Because it has the same CPU as Raspberry Pi B/B+ (Link) I think I could use it.
-volker-
Re: Raspberry Pi Zero W
Post by admin » Fri Feb 09, 2018 4:25 pm
We don't have a port for it.
Volker S
Post by Volker S » Fri Feb 09, 2018 6:14 pm
What port do you mean?
The Pi Zero W has WLAN and USB. What is missing?
-volker-
Post by Mattk » Fri Feb 09, 2018 11:49 pm
I think that refers to software/firmware porting?
Volker S
Post by Volker S » Wed Feb 14, 2018 11:47 am
Can you explain it in a short way? Has that been tried?
-volker-
Post by admin » Wed Mar 28, 2018 10:33 pm
As Meteohub is designed as a headless unit, a device without LAN is not fitting. How should one insert the credentials for WiFi?
Would need complicated Access Point operation in the beginning and then switching over to a WiFi client... much hassle... for what? Just for saying it also supports this device type? I don't really see the benefit.
When you want it really small and less power hungry, you can go with Meteobridge.
