Rain and Wind data realtime
metchab
Post by metchab »
hopefully my english is good enough
i am new here, i have MeteoBridge Pro and i read a lot to find out a way to bring rain (by starting) and Wind in realtime to my Homeautomation system (Loxone)
Due Loxone limitation http commands to fetch this data from MBP are time limited by 10 seconds shortest. For awing controls i need the the values as soon as they are detected
under services i did not find a way to solve this
In the i moment i use Ambient Weather WH14xx (16 seconds refresh rate is too long) quick transmission ist possible i planing with Davis vantage Pro2 oder Lufft WS, both have very shorter refresh rate
thank you for help
ruzzi.f@gmail.com
Re: Rain and Wind data realtime
Post by ruzzi.f@gmail.com »
hi
i have same need and i used the http get service
ruzzi.f@gmail.com
i am updatind data every 5 seconds
metchab
Post by metchab »
hi,
you use http get from Loxone?
what version you use? in actual version http is time limited by 10 sec
