License included with purchase of Pro?
skuske
Post by skuske »
Does the purchase of a Meteobridge Pro include a license, or will I have to purchase a license and the Pro hardware? I cannot find any information on this. Thanks.
Re: License included with purchase of Pro?
Yes, license is included https://www.meteobridge.com/wiki/index. ... bridge_PRO
Where to Buy?
Meteobridge PRO is available from these resellers as a turn-key solution (including license, power supply, Ethernet cable, USB converter cabel):
Succes, it is a wonderful device,
Support for Leuven-Template & Scripts at https://support.leuven-template.eu/
Support for the PWS_Dashboard (HWS-template) https://pwsdashboard.com/
skuske
Post by skuske »
Thanks! :)
galfert
Post by galfert »
FYI - You still need to pay to renew license every 2 years if you want to continue to get firmware updates. This is optional. You can keep using with old firmware, but you won't get new features nor bug fixes.
MR3020 v1
GW1000
galfert wrote:
Thu Jan 23, 2020 6:09 pm
That is for the standard MB, the query was in regard a MB Pro which does not require a license renewal
galfert
Post by galfert »
Yes I knew the inquiry was for the Pro. But I did not know that the Pro license did not require renewal. Thank you for that clarification.
MR3020 v1
GW1000
