Low battery warning. **solved**
Post by 36260 »
I'm running a Davis VP2 with a repeater with Nano SD. In Meteobridge documentation, I noticed there are lotbat sensors. I'm wondering whether there is a way to report low battery conditions either on the station or the repeater.
Thank you
Davis VP2 + Solar - Nano SD
MS72@MH
Re: Low battery warning
Post by MS72@MH »
please take a look at the 'History' tab. The sensor should be logged automatically.
On the tab 'Service' you can try to create a one-time alert to send an email. Set 'Raise' to something like this: [thb3lowbat-act:0]==1
36260
Post by 36260 »
MS72@MH wrote:
Tue Oct 13, 2020 1:51 pm
Thank you very much for your answer. Indeed, I'm aware of this tab. But I'm afraid lowbat is related to a specific sensor not to the station itself nor the repeater. I recently experienced a battery shortage on the repeater and none of lowbat sensors reported a 1 value.
Battery status of a repeater is not monitored by Meteobridge.
36260
Post by 36260 »
Thanks. What about the station itself?
Do you mean the console? Meteobridge PRO red does not connect to the console, so it cannot say anything about it.
36260
Post by 36260 »
No I'm referring to the VP2 ISS station, where all the sensors are
Re: Low battery warning **solved**
sensors will get lowbat indicators when this comes true.
36260
Re: Low battery warning. **solved**
Post by 36260 »
Thank you
