HTTP event question **solved**
mpriest
Post by mpriest »
Hello ,
I am using this http event url:
http://www.webcamwassenaar.nl/wxdata/re ... d]kn&gust=[wind0wind-max6=kn.0:--]kn&richting=[wind0dir]
With this php:
<?php
$U = $_GET['epoch'];
$wind = $_GET['wind'];
$gust = $_GET['gust'];
$richting = $_GET['richting'];
$values = array($U,$wind, $gust, $richting);
$result = json_encode($values);
file_put_contents("datawaswind.txt",$result);
The response in the resulting txt file is :
[null,"[wind0wind]kn","1kn","[wind0dir]"]
What's wrong ? who knows?
ConligWX
Re: HTTP event question
Post by ConligWX »
the correct way of calling a sensor is:
sensor-selector=converter.decimals:replacement
"converter", "decimals" and "replacement" can be omitted, "sensor" and "type"(selector) are mandatory.
While "sensor" tells what sensor and what piece of information of the sensor to use, "selector" decides data from what time period should be taken into account and "converter" does convert data into measurement units the user likes most. "Decimals" decides about precision the result should be shown in and "replacement" gives the string to be returned when there is no data for defined sensor available.
so
[wind0dir] should be something like: [wind0dir-act]
https://www.meteobridge.com/wiki/index.php/Templates
Look at "Selectors"
