Nonzerotime after few days empty?
WS Grave
Post by WS Grave »
Goodmorning, since a few months I have a Meteobridge Pro Red with my new weatherstation (VP2).
I'm creating my own templates for my website and I would like to use the tags [rain0total-nonzerotime:--] and/or [rain0rate-nonzerotime:--] and they do work, a few days, but after those 1,2 or 3 days I see only the "--" instead of the date.
Is that how it should be or should I be able to see the last time it rained even after a few weeks or so!??
Thanks a lot for your reply 👍
Re: Nonzerotime after few days empty?
did you a get response because i cant quite make it work and get same as you .have updated to version 4 now 4.1 still same result two days later it returns - - ...
Problem is that "nonzerotime" is not made persistent over logger restarts. So when the logger process restarts because of a larger data gap or because you change something logger related on the web interface, then reference data is lost. I will think about this. A solution that survives a restart of the logger might be easy to do, one that survives a reboot is a harder challenge.
In just release update I made the "nonzerotime" selector surviving a restart of the logger process. After a process restart it will need the respective sensor to be initialized by getting some data from the station before it can report on "nonzerotime".
admin wrote:
Sun Sep 08, 2019 1:16 pm
hello boris
so let me understand lets say i update now the nonzerotime will be effective or generate a timestamp from the next rain event we get or
my last rain event here was 21st august will it detect that . sorry for the questions just been confused on this for months . brian
ok i updated 8th September 4.1-2424 and went out poured a bit of water into the cone to generate 0.2mm ,
it now generates timestamp i can edit out after a few days so lets see if it picks up the [rain0total-nonzerotime:--] as of todays timestamp 20190908155729 so lets see if it remains there in a 2 or 3 days as what use to happen it would revert back to -- .
screenshot shows with the orange dots ..brian
Screenshot at Sep 08 16-04-25.png (39.66 KiB) Viewed 552 times
hello boris unfortunately that didnt work after 3 days exactly no timestamp is returned only —
so i dont how else to return a last rainfall date with a valid timestamp
brian
Could you please post the result of
http://ip-of-my-meteobridge/cgi-bin/system.cgi?ls -la /var/run/meteohub/
admin wrote:
Wed Sep 11, 2019 4:07 pm
command: ls -la /var/run/meteohub/
drwxr-xr-x 2 root root 460 Sep 8 15:57 .
drwxr-xr-x 5 root root 640 Sep 11 17:22 ..
-rw-r--r-- 1 root root 10 Sep 11 17:22 logger.dat
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data10num
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data11num
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data12num
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data13num
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data15num
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data16num
-rw-r--r-- 1 root root 10 Sep 8 15:57 nonzerotime-rain0total
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-th0dew
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-th0heatindex
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-th0hum
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-th0temp
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-thb0dew
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-thb0hum
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-thb0press
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-thb0seapress
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-thb0temp
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-wind0avgwind
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-wind0chill
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-wind0dir
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-wind0wind
this the string used [rain0total-nonzerotime:--] in the API
Fine, so the data is there. Could you please give this command, so that we see epoch time of last rain event:
...system.cgi?cat /var/run/meteohub/nonzerotime-rain0total
it doesnt now return a timestamp at exactly 15:57 today it now returns only - -
prior to that it would return 20190908155729
the string used to call is [rain0total-nonzerotime:--]
admin wrote:
Wed Sep 11, 2019 4:28 pm
command: /cat/var/run/meteohub/nonzerotime-rain0total
/www/cgi-bin/system.cgi: line 22: /cat/var/run/meteohub/nonzerotime-rain0total: not found
It needs to be "cat /var/..." not "/cat/var/..."
command: /cat /var/run/meteohub/nonzerotime-rain0total
/www/cgi-bin/system.cgi: line 22: /cat: not found
you are nearly there... please "cat" instead of "/cat" :D
