File system meteobridge pro
meteoharderwijk
Post by meteoharderwijk »
I have an internal usb failure but I don’t have any backup
What file system is use for the internal usb stik? fat32 or another
If I know I can try to repair the stick.
Thanks in advance.
Re: File system meteobridge pro
How old is the MB? Original USB stick?
I doubt that you will be able to fix it that way, as Meteobridge (to be precise, the underlying OpenWRT) does a filesystem check on boot.
However, it is an EXT4 located on the raw device (no partitions defined).
meteoharderwijk
The Meteobridge is from March 2016, after 3 month the first USB stick was broke.
The unit was repaired and there was an Intense USB stick in it.
I ordered an ATP usb stick
with extFS for Mac OS I can mount the USB stick and I have copy everything.
I tried another USB stick but there was a problem with the database.
I saw the history of al my data.
I select to force reconstruct at restart. but then the database was empty.
is there external software to rebuild the database?
meteoharderwijk wrote:
Sun Aug 11, 2019 12:18 pm
Sorry, nope.
