Error Meteoplug Cloud (Live)
BeBe
Post by BeBe »
Meteoplug Cloud and Meteoplug Cloud (Live) fails.
I made a reboot, but no solution
Schermafbeelding 2019-09-14 om 09.58.57.jpg (98.48 KiB) Viewed 836 times
Logger:
backup (14.09.2019 00:00:37): backup completed: dbase-201909140000 (34.5M)
logger (14.09.2019 04:00:55): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day <...
logger (14.09.2019 04:00:55): disconnect station 0 (Meteostick Vantage): exit
logger (14.09.2019 04:00:55): disconnect station 9 (System Data): exit
logger (14.09.2019 04:00:57): databases connected. Update interval 3600 seconds.
logger (14.09.2019 04:00:57): data logger (version 5.1b, build 13124) started.
logger (14.09.2019 04:00:57): connect station 0 (Meteostick Vantage via USB serial).
logger (14.09.2019 04:00:57): connect station 9 (System Data via Plug-in).
logger (14.09.2019 04:00:59): transmitter 1 registered as ISS
logger (14.09.2019 04:00:59): transmitter 2 registered as Wind
logger (14.09.2019 04:00:59): transmitter 3 registered as Temperature
logger (14.09.2019 04:00:59): transmitter 4 registered as Temperature
logger (14.09.2019 04:00:59): Meteostick Version 2.5.2
logger (14.09.2019 04:00:59): debug off
logger (14.09.2019 04:00:59): verbose off
logger (14.09.2019 04:00:59): output raw (8 bytes)
logger (14.09.2019 04:00:59): output raw (10 bytes)
logger (14.09.2019 04:00:59): filter on
logger (14.09.2019 04:00:59): rx threshold set to -90db
logger (14.09.2019 04:00:59): listening to transmitter 1 2 3 4
logger (14.09.2019 04:00:59): bandwidth narrow
logger (14.09.2019 04:01:00): chip authentication ok: 14
logger (14.09.2019 04:01:00): frequency band 868MHz (EU)
logger (14.09.2019 04:01:01): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.09.2019 04:01:01): services paused.
logger (14.09.2019 04:02:01): sensors are now providing data.
logger (14.09.2019 04:02:01): services started.
logger (14.09.2019 05:01:03): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfil...
logger (14.09.2019 05:01:03): disconnect station 0 (Meteostick Vantage): exit
logger (14.09.2019 05:01:03): disconnect station 9 (System Data): exit
logger (14.09.2019 05:01:04): databases connected. Update interval 3600 seconds.
logger (14.09.2019 05:01:04): data logger (version 5.1b, build 13124) started.
logger (14.09.2019 05:01:05): connect station 0 (Meteostick Vantage via USB serial).
logger (14.09.2019 05:01:05): connect station 9 (System Data via Plug-in).
logger (14.09.2019 05:01:07): transmitter 1 registered as ISS
logger (14.09.2019 05:01:07): transmitter 2 registered as Wind
logger (14.09.2019 05:01:07): transmitter 3 registered as Temperature
logger (14.09.2019 05:01:07): transmitter 4 registered as Temperature
logger (14.09.2019 05:01:07): Meteostick Version 2.5.2
logger (14.09.2019 05:01:07): debug off
logger (14.09.2019 05:01:07): verbose off
logger (14.09.2019 05:01:07): output raw (8 bytes)
logger (14.09.2019 05:01:07): output raw (10 bytes)
logger (14.09.2019 05:01:07): filter on
logger (14.09.2019 05:01:07): rx threshold set to -90db
logger (14.09.2019 05:01:07): listening to transmitter 1 2 3 4
logger (14.09.2019 05:01:07): bandwidth narrow
logger (14.09.2019 05:01:08): chip authentication ok: 14
logger (14.09.2019 05:01:08): frequency band 868MHz (EU)
logger (14.09.2019 05:01:09): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.09.2019 05:01:09): services paused.
logger (14.09.2019 05:02:09): sensors are now providing data.
logger (14.09.2019 05:02:09): services started.
logger (14.09.2019 05:21:11): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfil...
logger (14.09.2019 05:21:11): disconnect station 0 (Meteostick Vantage): exit
logger (14.09.2019 05:21:11): disconnect station 9 (System Data): exit
logger (14.09.2019 05:21:12): databases connected. Update interval 3600 seconds.
logger (14.09.2019 05:21:12): data logger (version 5.1b, build 13124) started.
logger (14.09.2019 05:21:13): connect station 0 (Meteostick Vantage via USB serial).
logger (14.09.2019 05:21:13): connect station 9 (System Data via Plug-in).
logger (14.09.2019 05:21:15): transmitter 1 registered as ISS
logger (14.09.2019 05:21:15): transmitter 2 registered as Wind
logger (14.09.2019 05:21:15): transmitter 3 registered as Temperature
logger (14.09.2019 05:21:15): transmitter 4 registered as Temperature
logger (14.09.2019 05:21:15): Meteostick Version 2.5.2
logger (14.09.2019 05:21:15): debug off
logger (14.09.2019 05:21:15): verbose off
logger (14.09.2019 05:21:15): output raw (8 bytes)
logger (14.09.2019 05:21:15): output raw (10 bytes)
logger (14.09.2019 05:21:15): filter on
logger (14.09.2019 05:21:15): rx threshold set to -90db
logger (14.09.2019 05:21:15): listening to transmitter 1 2 3 4
logger (14.09.2019 05:21:15): bandwidth narrow
logger (14.09.2019 05:21:15): chip authentication ok: 14
logger (14.09.2019 05:21:15): frequency band 868MHz (EU)
logger (14.09.2019 05:21:16): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.09.2019 05:21:16): services paused.
logger (14.09.2019 05:22:16): sensors are now providing data.
logger (14.09.2019 05:22:16): services started.
logger (14.09.2019 05:41:18): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getline < inetupload_getline < inetuploa...
logger (14.09.2019 05:41:18): disconnect station 0 (Meteostick Vantage): exit
logger (14.09.2019 05:41:18): disconnect station 9 (System Data): exit
logger (14.09.2019 05:41:19): databases connected. Update interval 3600 seconds.
logger (14.09.2019 05:41:19): data logger (version 5.1b, build 13124) started.
logger (14.09.2019 05:41:20): connect station 0 (Meteostick Vantage via USB serial).
logger (14.09.2019 05:41:20): connect station 9 (System Data via Plug-in).
logger (14.09.2019 05:41:22): transmitter 1 registered as ISS
logger (14.09.2019 05:41:22): transmitter 2 registered as Wind
logger (14.09.2019 05:41:22): transmitter 3 registered as Temperature
logger (14.09.2019 05:41:22): transmitter 4 registered as Temperature
logger (14.09.2019 05:41:22): Meteostick Version 2.5.2
logger (14.09.2019 05:41:22): debug off
logger (14.09.2019 05:41:22): verbose off
logger (14.09.2019 05:41:22): output raw (8 bytes)
logger (14.09.2019 05:41:22): output raw (10 bytes)
logger (14.09.2019 05:41:22): filter on
logger (14.09.2019 05:41:22): rx threshold set to -90db
logger (14.09.2019 05:41:22): listening to transmitter 1 2 3 4
logger (14.09.2019 05:41:22): bandwidth narrow
logger (14.09.2019 05:41:23): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.09.2019 05:41:23): services paused.
logger (14.09.2019 05:41:23): chip authentication ok: 14
logger (14.09.2019 05:41:23): frequency band 868MHz (EU)
logger (14.09.2019 05:42:23): sensors are now providing data.
logger (14.09.2019 05:42:23): services started.
logger (14.09.2019 06:01:25): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfil...
logger (14.09.2019 06:01:25): disconnect station 0 (Meteostick Vantage): exit
logger (14.09.2019 06:01:25): disconnect station 9 (System Data): exit
logger (14.09.2019 06:01:26): databases connected. Update interval 3600 seconds.
logger (14.09.2019 06:01:26): data logger (version 5.1b, build 13124) started.
logger (14.09.2019 06:01:27): connect station 0 (Meteostick Vantage via USB serial).
logger (14.09.2019 06:01:27): connect station 9 (System Data via Plug-in).
logger (14.09.2019 06:01:29): transmitter 1 registered as ISS
logger (14.09.2019 06:01:29): transmitter 2 registered as Wind
logger (14.09.2019 06:01:29): transmitter 3 registered as Temperature
logger (14.09.2019 06:01:29): transmitter 4 registered as Temperature
logger (14.09.2019 06:01:29): Meteostick Version 2.5.2
logger (14.09.2019 06:01:29): debug off
logger (14.09.2019 06:01:29): verbose off
logger (14.09.2019 06:01:29): output raw (8 bytes)
logger (14.09.2019 06:01:29): output raw (10 bytes)
logger (14.09.2019 06:01:29): filter on
logger (14.09.2019 06:01:29): rx threshold set to -90db
logger (14.09.2019 06:01:29): listening to transmitter 1 2 3 4
logger (14.09.2019 06:01:29): bandwidth narrow
logger (14.09.2019 06:01:29): chip authentication ok: 14
logger (14.09.2019 06:01:29): frequency band 868MHz (EU)
logger (14.09.2019 06:01:30): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.09.2019 06:01:30): services paused.
logger (14.09.2019 06:02:30): sensors are now providing data.
logger (14.09.2019 06:02:30): services started.
logger (14.09.2019 06:32:01): child process received timeout signal (14).
logger (14.09.2019 06:32:01): disconnect station 0 (Meteostick Vantage): exit
logger (14.09.2019 06:32:01): disconnect station 9 (System Data): exit
BeBe
Re: Error Meteoplug Cloud (Live)
Post by BeBe »
It's ok again, but I am curious what the cause was. Is it a bug or something else?
Server was down.
cphMichael
Post by cphMichael »
Can I use the Meteoplug Cloud to backup my weather data - and Restore the weather data if my Meteobridge Pro crashes?
Michael
http://frederiksberg-vejret.dk
