Davis vantage forecast-rule. **solved**
Posted: Wed May 20, 2020 11:56 am
by 36260
I'm doing my second transition. NSLU --> Raspberry and now Meteobridge Nano HD. Meteohub exposes fc data (wheather icon), that seems not to be reported anymore in the live data of Meteobridge neither in templates. Instead it seems that forecast-rule replaces it. What are the values that can be taken by this variable and their meaning? Is there a way to get fc?
Thank you
Re: Davis vantage forecast-rule
Posted: Wed May 20, 2020 12:27 pm
by wvdkuil
Thank you
A list of rule# -> fc-text can be found here:
https://www.wxforum.net/index.php?topic ... 4#msg15424
The Meteobridge can also supply the corresponding text im multiple languages
https://www.meteobridge.com/wiki/index.php/Templates -> Forecast Variables
There are scripts who use the rule# to translate to an icon, I could not find one yet.
There are some scripts which translate the rule-text to an icon, this is an example as used in the console scripts.
# Determine forecast icon from Davis forecast string $vpforecast_en
function c_get_fcsticon($vpforecast_en) {
	$DC_fcsttmp = "DC_{$vpforecast_en}";  // Station forecast string
	$DC_fcsttmp = strtolower ($DC_fcsttmp);
# WARNING              DO NOT CHANGE ANY OF THESE STRING TESTS !!!
#                      TESTS and ORDER CRITICAL !!!
	if     (preg_match('/mostly clear/i',                       		$DC_fcsttmp) ) {$fcsticon = "mclr.png";}
	elseif (preg_match('/increasing clouds and warmer/i',        		$DC_fcsttmp) ||
		preg_match('/warmer. precipitation possible within 24/i', 	$DC_fcsttmp) ||
		preg_match('/increasing clouds with/i',              		$DC_fcsttmp) ||
		preg_match('/partly cloudy/i',                       		$DC_fcsttmp) )  {$fcsticon = "pcld.png";}
	elseif (preg_match('/cooler. precipitation possible within 12/i', 	$DC_fcsttmp) ||
		preg_match('/cooler. precipitation likely. windy/i', 		$DC_fcsttmp) )  {$fcsticon = "rain.png";}
	elseif (preg_match('/precipitation ending within 6/i',       		$DC_fcsttmp) ||
		preg_match('/clearing, cooler and windy/i',          		$DC_fcsttmp) ||
		preg_match('/mostly cloudy and cooler/i',            		$DC_fcsttmp) ||
		preg_match('/mostly cloudy with/i',                 		$DC_fcsttmp) ||
		preg_match('/change. possible wind shift/i',         		$DC_fcsttmp) ||
		preg_match('/likely/i',                              		$DC_fcsttmp) ||
		preg_match('/change. precipitation possible within 24/i', 	$DC_fcsttmp) ||
		preg_match('/precipitation likely possibly/i',       		$DC_fcsttmp) ||
		preg_match('/precipitation possible within 24/i',    		$DC_fcsttmp) ||
		preg_match('/precipitation possible within 48/i',    		$DC_fcsttmp) )  {$fcsticon = "mcld.png";}
	elseif (preg_match('/precipitation continuing/i',       $DC_fcsttmp) ||
		preg_match('/windy within 6/i',                 $DC_fcsttmp) ||
		preg_match('/possible within 12/i',             $DC_fcsttmp) ||
		preg_match('/possible within 6/i',              $DC_fcsttmp) ||
		preg_match('/ending in/i',                      $DC_fcsttmp) ||
		preg_match('/ending within 12/i',               $DC_fcsttmp) )	{$fcsticon = "rain.png";}
	elseif (preg_match('/partialy cloudy, Rain possible/i', $DC_fcsttmp) )  {$fcsticon = "pcldrain.png";}
	elseif (preg_match('/mostly cloudy, Rain possible/i',   $DC_fcsttmp) )	{$fcsticon = "mcldrain.png";}
	elseif (preg_match('/partialy cloudy, Snow/i',          $DC_fcsttmp) )	{$fcsticon = "pcldsnow.png";}
	elseif (preg_match('/mostly cloudy, Snow/i',            $DC_fcsttmp) )	{$fcsticon = "mcldsnow.png";}
	elseif (preg_match('/rain and/i',                       $DC_fcsttmp) )	{$fcsticon = "rainsnow.png";}
	elseif (preg_match('/clear/i',                          $DC_fcsttmp) ||
		preg_match('/sunny/i',                          $DC_fcsttmp) )  {$fcsticon = "mclr.png";}
	elseif (preg_match('/cloudy/i',                         $DC_fcsttmp) )  {$fcsticon = "mcld.png";}
	elseif (preg_match('/rain/i',                           $DC_fcsttmp) )  {$fcsticon = "rain.png";}
	elseif (preg_match('/snow/i',                           $DC_fcsttmp) )	{$fcsticon = "snow.png";}
	elseif (preg_match('/forecast/i',                       $DC_fcsttmp) )  {$fcsticon = "grid.png";} // FORECAST REQUIRES 3 HOURS OF RECENT DATA
	elseif (preg_match('/data will be reloaded/i',          $DC_fcsttmp) )  {$fcsticon = "grid.png";} // Data will be reloaded
	else { $DC_fcsttmp = "$DC_fcsttmp|grid.png|\n";          					  // forecast not found !!
#	echo '<!-- test  $vpforecast_en = '.$vpforecast_en.' - $DC_fcsttmp = '.$DC_fcsttmp.' -->'.PHP_EOL;
	return $fcsticon;
} // eo function  get_fcsticon
Posted: Wed May 20, 2020 6:12 pm
by 36260
Thanks Wim I've got everything I need to go forward.
