Killed process
BeBe
Killed process
Post by BeBe »
Last week, MB pro stopped recording and transmitting data twice within a few days. After a restart, everything returned to normal.
Logger: logger (06.06.2020 08:01:09): killed process "2866 / sh" listening to port 5551; logger (20.06.2020 01:56:00): killed process "24180 / sh" listening to port 5551.
BB
oled (18.06.2020 05:08:50): process started.
database (18.06.2020 07:10:55): process started.
database (18.06.2020 07:10:55): Content of RAM database restored.
wnetd (18.06.2020 07:10:58): process started.
system (18.06.2020 07:10:58): start of logging process initiated.
wnetd (18.06.2020 07:10:58): send data thread started (pid:2763 tid:2764)
logger (18.06.2020 07:10:58): databases connected. Update interval 3600 seconds.
logger (18.06.2020 07:10:58): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 07:11:01): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 07:11:01): connect station 9 (System Data via Plug-in).
logger (18.06.2020 07:11:03): transmitter 1 registered as ISS
logger (18.06.2020 07:11:03): transmitter 2 registered as Wind
logger (18.06.2020 07:11:03): transmitter 3 registered as Temperature
logger (18.06.2020 07:11:03): transmitter 4 registered as Temperature
logger (18.06.2020 07:11:03): Meteostick Version 2.5.2
logger (18.06.2020 07:11:03): debug off
logger (18.06.2020 07:11:03): verbose off
logger (18.06.2020 07:11:03): output raw (8 bytes)
logger (18.06.2020 07:11:03): output raw (10 bytes)
logger (18.06.2020 07:11:03): filter on
logger (18.06.2020 07:11:03): rx threshold set to -90db
logger (18.06.2020 07:11:03): listening to transmitter 1 2 3 4
logger (18.06.2020 07:11:03): bandwidth narrow
logger (18.06.2020 07:11:03): chip authentication ok: 14
logger (18.06.2020 07:11:03): frequency band 868MHz (EU)
logger (18.06.2020 07:11:04): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 07:11:04): services paused.
database (18.06.2020 07:11:33): database sync done (60 tables, 168/2580 writes).
logger (18.06.2020 07:12:04): sensors are now providing data.
logger (18.06.2020 07:12:04): services started.
logger (18.06.2020 08:01:09): databases connected. Update interval 3600 seconds.
logger (18.06.2020 08:01:09): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 08:01:09): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 08:01:09): killed process "2866/sh" listening to port 5551.
logger (18.06.2020 08:01:39): databases connected. Update interval 3600 seconds.
logger (18.06.2020 08:01:39): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 08:01:39): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 08:01:39): killed process "2867/meteosys" listening to port 5551.
logger (18.06.2020 08:02:09): databases connected. Update interval 3600 seconds.
logger (18.06.2020 08:02:09): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 08:02:10): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 08:02:10): connect station 9 (System Data via Plug-in).
logger (18.06.2020 08:02:10): transmitter 1 registered as ISS
logger (18.06.2020 08:02:10): transmitter 2 registered as Wind
logger (18.06.2020 08:02:10): transmitter 3 registered as Temperature
logger (18.06.2020 08:02:10): transmitter 4 registered as Temperature
logger (18.06.2020 08:02:10): Meteostick Version 2.5.2
logger (18.06.2020 08:02:10): debug off
logger (18.06.2020 08:02:10): verbose off
logger (18.06.2020 08:02:10): output raw (8 bytes)
logger (18.06.2020 08:02:10): output raw (10 bytes)
logger (18.06.2020 08:02:10): filter on
logger (18.06.2020 08:02:10): rx threshold set to -90db
logger (18.06.2020 08:02:10): listening to transmitter 1 2 3 4
logger (18.06.2020 08:02:10): bandwidth narrow
logger (18.06.2020 08:02:10): chip authentication ok: 14
logger (18.06.2020 08:02:10): frequency band 868MHz (EU)
logger (18.06.2020 08:02:13): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 08:02:13): services paused.
logger (18.06.2020 08:03:11): sensors are now providing data.
logger (18.06.2020 08:03:11): services started.
logger (18.06.2020 08:22:15): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (18.06.2020 08:22:15): disconnect station 0 (Meteostick Vantage): exit
logger (18.06.2020 08:22:15): disconnect station 9 (System Data): exit
logger (18.06.2020 08:22:16): databases connected. Update interval 3600 seconds.
logger (18.06.2020 08:22:16): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 08:22:17): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 08:22:17): connect station 9 (System Data via Plug-in).
logger (18.06.2020 08:22:17): transmitter 1 registered as ISS
logger (18.06.2020 08:22:17): transmitter 2 registered as Wind
logger (18.06.2020 08:22:17): transmitter 3 registered as Temperature
logger (18.06.2020 08:22:17): transmitter 4 registered as Temperature
logger (18.06.2020 08:22:17): Meteostick Version 2.5.2
logger (18.06.2020 08:22:17): debug off
logger (18.06.2020 08:22:17): verbose off
logger (18.06.2020 08:22:17): output raw (8 bytes)
logger (18.06.2020 08:22:17): output raw (10 bytes)
logger (18.06.2020 08:22:17): filter on
logger (18.06.2020 08:22:17): rx threshold set to -90db
logger (18.06.2020 08:22:17): listening to transmitter 1 2 3 4
logger (18.06.2020 08:22:17): bandwidth narrow
logger (18.06.2020 08:22:18): chip authentication ok: 14
logger (18.06.2020 08:22:18): frequency band 868MHz (EU)
logger (18.06.2020 08:22:20): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 08:22:20): services paused.
logger (18.06.2020 08:23:19): sensors are now providing data.
logger (18.06.2020 08:23:19): services started.
logger (18.06.2020 08:42:22): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (18.06.2020 08:42:22): disconnect station 0 (Meteostick Vantage): exit
logger (18.06.2020 08:42:22): disconnect station 9 (System Data): exit
logger (18.06.2020 08:42:23): databases connected. Update interval 3600 seconds.
logger (18.06.2020 08:42:23): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 08:42:24): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 08:42:24): connect station 9 (System Data via Plug-in).
logger (18.06.2020 08:42:24): transmitter 1 registered as ISS
logger (18.06.2020 08:42:24): transmitter 2 registered as Wind
logger (18.06.2020 08:42:24): transmitter 3 registered as Temperature
logger (18.06.2020 08:42:24): transmitter 4 registered as Temperature
logger (18.06.2020 08:42:24): Meteostick Version 2.5.2
logger (18.06.2020 08:42:24): debug off
logger (18.06.2020 08:42:24): verbose off
logger (18.06.2020 08:42:24): output raw (8 bytes)
logger (18.06.2020 08:42:24): output raw (10 bytes)
logger (18.06.2020 08:42:24): filter on
logger (18.06.2020 08:42:24): rx threshold set to -90db
logger (18.06.2020 08:42:24): listening to transmitter 1 2 3 4
logger (18.06.2020 08:42:24): bandwidth narrow
logger (18.06.2020 08:42:25): chip authentication ok: 14
logger (18.06.2020 08:42:25): frequency band 868MHz (EU)
logger (18.06.2020 08:42:27): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 08:42:27): services paused.
logger (18.06.2020 08:43:26): sensors are now providing data.
logger (18.06.2020 08:43:26): services started.
logger (18.06.2020 09:02:29): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:02:29): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:02:29): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 09:02:29): killed process "12561/sh" listening to port 5551.
logger (18.06.2020 09:02:59): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:02:59): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:02:59): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 09:02:59): killed process "12563/meteosys" listening to port 5551.
logger (18.06.2020 09:03:29): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:03:29): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:03:30): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 09:03:30): connect station 9 (System Data via Plug-in).
logger (18.06.2020 09:03:30): transmitter 1 registered as ISS
logger (18.06.2020 09:03:30): transmitter 2 registered as Wind
logger (18.06.2020 09:03:30): transmitter 3 registered as Temperature
logger (18.06.2020 09:03:30): transmitter 4 registered as Temperature
logger (18.06.2020 09:03:30): Meteostick Version 2.5.2
logger (18.06.2020 09:03:30): debug off
logger (18.06.2020 09:03:30): verbose off
logger (18.06.2020 09:03:30): output raw (8 bytes)
logger (18.06.2020 09:03:30): output raw (10 bytes)
logger (18.06.2020 09:03:30): filter on
logger (18.06.2020 09:03:30): rx threshold set to -90db
logger (18.06.2020 09:03:30): listening to transmitter 1 2 3 4
logger (18.06.2020 09:03:30): bandwidth narrow
logger (18.06.2020 09:03:31): chip authentication ok: 14
logger (18.06.2020 09:03:31): frequency band 868MHz (EU)
logger (18.06.2020 09:03:33): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 09:03:33): services paused.
logger (18.06.2020 09:05:30): give up waiting for sensors after 120 secs.
logger (18.06.2020 09:05:30): services activated.
logger (18.06.2020 09:33:38): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:33:38): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:33:38): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 09:33:38): killed process "14974/sh" listening to port 5551.
logger (18.06.2020 09:34:08): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:34:08): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:34:08): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 09:34:08): killed process "14975/meteosys" listening to port 5551.
logger (18.06.2020 09:34:38): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:34:38): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:34:39): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 09:34:39): connect station 9 (System Data via Plug-in).
logger (18.06.2020 09:34:39): transmitter 1 registered as ISS
logger (18.06.2020 09:34:39): transmitter 2 registered as Wind
logger (18.06.2020 09:34:39): transmitter 3 registered as Temperature
logger (18.06.2020 09:34:39): transmitter 4 registered as Temperature
logger (18.06.2020 09:34:39): Meteostick Version 2.5.2
logger (18.06.2020 09:34:39): debug off
logger (18.06.2020 09:34:39): verbose off
logger (18.06.2020 09:34:39): output raw (8 bytes)
logger (18.06.2020 09:34:39): output raw (10 bytes)
logger (18.06.2020 09:34:39): filter on
logger (18.06.2020 09:34:39): rx threshold set to -90db
logger (18.06.2020 09:34:39): listening to transmitter 1 2 3 4
logger (18.06.2020 09:34:39): bandwidth narrow
logger (18.06.2020 09:34:40): chip authentication ok: 14
logger (18.06.2020 09:34:40): frequency band 868MHz (EU)
logger (18.06.2020 09:34:42): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 09:34:42): services paused.
logger (18.06.2020 09:35:41): sensors are now providing data.
logger (18.06.2020 09:35:41): services started.
logger (18.06.2020 10:04:49): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (18.06.2020 10:04:49): disconnect station 0 (Meteostick Vantage): exit
logger (18.06.2020 10:04:49): disconnect station 9 (System Data): exit
logger (18.06.2020 10:04:50): databases connected. Update interval 3600 seconds.
logger (18.06.2020 10:04:50): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 10:04:51): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 10:04:51): connect station 9 (System Data via Plug-in).
logger (18.06.2020 10:04:51): transmitter 1 registered as ISS
logger (18.06.2020 10:04:51): transmitter 2 registered as Wind
logger (18.06.2020 10:04:51): transmitter 3 registered as Temperature
logger (18.06.2020 10:04:51): transmitter 4 registered as Temperature
logger (18.06.2020 10:04:51): Meteostick Version 2.5.2
logger (18.06.2020 10:04:51): debug off
logger (18.06.2020 10:04:51): verbose off
logger (18.06.2020 10:04:51): output raw (8 bytes)
logger (18.06.2020 10:04:51): output raw (10 bytes)
logger (18.06.2020 10:04:51): filter on
logger (18.06.2020 10:04:51): rx threshold set to -90db
logger (18.06.2020 10:04:51): listening to transmitter 1 2 3 4
logger (18.06.2020 10:04:51): bandwidth narrow
logger (18.06.2020 10:04:52): chip authentication ok: 14
logger (18.06.2020 10:04:52): frequency band 868MHz (EU)
logger (18.06.2020 10:04:54): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 10:04:54): services paused.
logger (18.06.2020 10:05:53): sensors are now providing data.
logger (18.06.2020 10:05:53): services started.
logger (18.06.2020 10:34:57): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (18.06.2020 10:34:57): disconnect station 0 (Meteostick Vantage): exit
logger (18.06.2020 10:34:57): disconnect station 9 (System Data): exit
logger (18.06.2020 10:34:58): databases connected. Update interval 3600 seconds.
logger (18.06.2020 10:34:58): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 10:34:59): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 10:34:59): connect station 9 (System Data via Plug-in).
logger (18.06.2020 10:34:59): transmitter 1 registered as ISS
logger (18.06.2020 10:34:59): transmitter 2 registered as Wind
logger (18.06.2020 10:34:59): transmitter 3 registered as Temperature
logger (18.06.2020 10:34:59): transmitter 4 registered as Temperature
logger (18.06.2020 10:34:59): Meteostick Version 2.5.2
logger (18.06.2020 10:34:59): debug off
logger (18.06.2020 10:34:59): verbose off
logger (18.06.2020 10:34:59): output raw (8 bytes)
logger (18.06.2020 10:34:59): output raw (10 bytes)
logger (18.06.2020 10:34:59): filter on
logger (18.06.2020 10:34:59): rx threshold set to -90db
logger (18.06.2020 10:34:59): listening to transmitter 1 2 3 4
logger (18.06.2020 10:34:59): bandwidth narrow
logger (18.06.2020 10:35:00): chip authentication ok: 14
logger (18.06.2020 10:35:00): frequency band 868MHz (EU)
logger (18.06.2020 10:35:01): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 10:35:01): services paused.
logger (18.06.2020 10:36:01): sensors are now providing data.
logger (18.06.2020 10:36:01): services started.
backup (19.06.2020 00:00:09): backup media size is 28.8G (26.3G free).
backup (19.06.2020 00:00:44): backup completed: dbase-202006190000 (46.0M)
backup (20.06.2020 00:00:09): backup media size is 28.8G (26.2G free).
backup (20.06.2020 00:00:38): backup completed: dbase-202006200000 (46.0M)
logger (20.06.2020 01:56:00): databases connected. Update interval 3600 seconds.
logger (20.06.2020 01:56:00): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 01:56:00): error (125) while doing bind (port 5551): Address already in use
logger (20.06.2020 01:56:00): killed process "24180/sh" listening to port 5551.
logger (20.06.2020 01:56:29): databases connected. Update interval 3600 seconds.
logger (20.06.2020 01:56:29): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 01:56:29): error (125) while doing bind (port 5551): Address already in use
logger (20.06.2020 01:56:29): killed process "24183/meteosys" listening to port 5551.
logger (20.06.2020 01:56:59): databases connected. Update interval 3600 seconds.
logger (20.06.2020 01:56:59): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 01:57:00): connect station 0 (Meteostick Vantage via USB serial).
logger (20.06.2020 01:57:00): connect station 9 (System Data via Plug-in).
logger (20.06.2020 01:57:00): transmitter 1 registered as ISS
logger (20.06.2020 01:57:00): transmitter 2 registered as Wind
logger (20.06.2020 01:57:00): transmitter 3 registered as Temperature
logger (20.06.2020 01:57:00): transmitter 4 registered as Temperature
logger (20.06.2020 01:57:00): Meteostick Version 2.5.2
logger (20.06.2020 01:57:00): debug off
logger (20.06.2020 01:57:00): verbose off
logger (20.06.2020 01:57:00): output raw (8 bytes)
logger (20.06.2020 01:57:00): output raw (10 bytes)
logger (20.06.2020 01:57:00): filter on
logger (20.06.2020 01:57:00): rx threshold set to -90db
logger (20.06.2020 01:57:00): listening to transmitter 1 2 3 4
logger (20.06.2020 01:57:00): bandwidth narrow
logger (20.06.2020 01:57:01): chip authentication ok: 14
logger (20.06.2020 01:57:01): frequency band 868MHz (EU)
logger (20.06.2020 01:57:03): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.06.2020 01:57:03): services paused.
logger (20.06.2020 01:58:02): sensors are now providing data.
logger (20.06.2020 01:58:02): services started.
logger (20.06.2020 02:37:05): databases connected. Update interval 3600 seconds.
logger (20.06.2020 02:37:05): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 02:37:05): error (125) while doing bind (port 5551): Address already in use
logger (20.06.2020 02:37:05): killed process "5720/sh" listening to port 5551.
logger (20.06.2020 02:37:35): databases connected. Update interval 3600 seconds.
logger (20.06.2020 02:37:35): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 02:37:35): error (125) while doing bind (port 5551): Address already in use
logger (20.06.2020 02:37:35): killed process "5721/meteosys" listening to port 5551.
logger (20.06.2020 02:38:05): databases connected. Update interval 3600 seconds.
logger (20.06.2020 02:38:05): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 02:38:06): connect station 0 (Meteostick Vantage via USB serial).
logger (20.06.2020 02:38:06): connect station 9 (System Data via Plug-in).
logger (20.06.2020 02:38:06): transmitter 1 registered as ISS
logger (20.06.2020 02:38:06): transmitter 2 registered as Wind
logger (20.06.2020 02:38:06): transmitter 3 registered as Temperature
logger (20.06.2020 02:38:06): transmitter 4 registered as Temperature
logger (20.06.2020 02:38:06): Meteostick Version 2.5.2
logger (20.06.2020 02:38:06): debug off
logger (20.06.2020 02:38:06): verbose off
logger (20.06.2020 02:38:06): output raw (8 bytes)
logger (20.06.2020 02:38:06): output raw (10 bytes)
logger (20.06.2020 02:38:06): filter on
logger (20.06.2020 02:38:06): rx threshold set to -90db
logger (20.06.2020 02:38:06): listening to transmitter 1 2 3 4
logger (20.06.2020 02:38:06): bandwidth narrow
logger (20.06.2020 02:38:06): chip authentication ok: 14
logger (20.06.2020 02:38:06): frequency band 868MHz (EU)
logger (20.06.2020 02:38:09): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.06.2020 02:38:09): services paused.
logger (20.06.2020 02:39:07): sensors are now providing data.
logger (20.06.2020 02:39:07): services started.
logger (20.06.2020 02:58:12): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getlin...
logger (20.06.2020 02:58:12): disconnect station 0 (Meteostick Vantage): exit
logger (20.06.2020 02:58:12): disconnect station 9 (System Data): exit
logger (20.06.2020 02:58:14): databases connected. Update interval 3600 seconds.
logger (20.06.2020 02:58:14): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 02:58:14): connect station 0 (Meteostick Vantage via USB serial).
logger (20.06.2020 02:58:14): connect station 9 (System Data via Plug-in).
logger (20.06.2020 02:58:15): transmitter 1 registered as ISS
logger (20.06.2020 02:58:15): transmitter 2 registered as Wind
logger (20.06.2020 02:58:15): transmitter 3 registered as Temperature
logger (20.06.2020 02:58:15): transmitter 4 registered as Temperature
logger (20.06.2020 02:58:15): Meteostick Version 2.5.2
logger (20.06.2020 02:58:15): debug off
logger (20.06.2020 02:58:15): verbose off
logger (20.06.2020 02:58:15): output raw (8 bytes)
logger (20.06.2020 02:58:15): output raw (10 bytes)
logger (20.06.2020 02:58:15): filter on
logger (20.06.2020 02:58:15): rx threshold set to -90db
logger (20.06.2020 02:58:15): listening to transmitter 1 2 3 4
logger (20.06.2020 02:58:15): bandwidth narrow
logger (20.06.2020 02:58:15): chip authentication ok: 14
logger (20.06.2020 02:58:15): frequency band 868MHz (EU)
logger (20.06.2020 02:58:16): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.06.2020 02:58:16): services paused.
logger (20.06.2020 02:59:16): sensors are now providing data.
logger (20.06.2020 02:59:16): services started.
logger (20.06.2020 03:18:19): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (20.06.2020 03:18:19): disconnect station 0 (Meteostick Vantage): exit
logger (20.06.2020 03:18:19): disconnect station 9 (System Data): exit
logger (20.06.2020 03:18:20): databases connected. Update interval 3600 seconds.
logger (20.06.2020 03:18:20): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 03:18:21): connect station 0 (Meteostick Vantage via USB serial).
logger (20.06.2020 03:18:21): connect station 9 (System Data via Plug-in).
logger (20.06.2020 03:18:21): transmitter 1 registered as ISS
logger (20.06.2020 03:18:21): transmitter 2 registered as Wind
logger (20.06.2020 03:18:21): transmitter 3 registered as Temperature
logger (20.06.2020 03:18:21): transmitter 4 registered as Temperature
logger (20.06.2020 03:18:21): Meteostick Version 2.5.2
logger (20.06.2020 03:18:21): debug off
logger (20.06.2020 03:18:21): verbose off
logger (20.06.2020 03:18:21): output raw (8 bytes)
logger (20.06.2020 03:18:21): output raw (10 bytes)
logger (20.06.2020 03:18:21): filter on
logger (20.06.2020 03:18:21): rx threshold set to -90db
logger (20.06.2020 03:18:21): listening to transmitter 1 2 3 4
logger (20.06.2020 03:18:21): bandwidth narrow
logger (20.06.2020 03:18:22): chip authentication ok: 14
logger (20.06.2020 03:18:22): frequency band 868MHz (EU)
logger (20.06.2020 03:18:24): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.06.2020 03:18:24): services paused.
logger (20.06.2020 03:19:23): sensors are now providing data.
logger (20.06.2020 03:19:23): services started.
logger (20.06.2020 04:18:28): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getlin...
logger (20.06.2020 04:18:28): disconnect station 0 (Meteostick Vantage): exit
logger (20.06.2020 04:18:28): disconnect station 9 (System Data): exit
logger (20.06.2020 04:18:29): databases connected. Update interval 3600 seconds.
logger (20.06.2020 04:18:29): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 04:18:30): connect station 0 (Meteostick Vantage via USB serial).
logger (20.06.2020 04:18:30): connect station 9 (System Data via Plug-in).
logger (20.06.2020 04:18:30): transmitter 1 registered as ISS
logger (20.06.2020 04:18:30): transmitter 2 registered as Wind
logger (20.06.2020 04:18:30): transmitter 3 registered as Temperature
logger (20.06.2020 04:18:30): transmitter 4 registered as Temperature
logger (20.06.2020 04:18:30): Meteostick Version 2.5.2
logger (20.06.2020 04:18:30): debug off
logger (20.06.2020 04:18:30): verbose off
logger (20.06.2020 04:18:30): output raw (8 bytes)
logger (20.06.2020 04:18:30): output raw (10 bytes)
logger (20.06.2020 04:18:30): filter on
logger (20.06.2020 04:18:30): rx threshold set to -90db
logger (20.06.2020 04:18:30): listening to transmitter 1 2 3 4
logger (20.06.2020 04:18:30): bandwidth narrow
logger (20.06.2020 04:18:31): chip authentication ok: 14
logger (20.06.2020 04:18:31): frequency band 868MHz (EU)
logger (20.06.2020 04:18:33): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.06.2020 04:18:33): services paused.
logger (20.06.2020 04:19:32): sensors are now providing data.
logger (20.06.2020 04:19:32): services started.
logger (20.06.2020 04:49:05): child process received timeout signal (14).
logger (20.06.2020 04:49:05): disconnect station 0 (Meteostick Vantage): exit
logger (20.06.2020 04:49:05): disconnect station 9 (System Data): exit
Neco
Re: Killed process
Post by Neco »
I experienced similar issues today. Data were recorded again only after a restart.
Re: Killed process
Signal 11 is a crash of the application. From what I can see in the log, it is happing inside the routine uploading data to Meteoplug. Is that service activated on your MB?
Meteobridge somehow recovers from that crash but when some processes survive the crash these block a restart of the application. Usually MB does get around this after a while, but I would really like to understand the crash first hand.
Can you please give me a remote login? That way I can do some more tests. contact is "info(at)meteobridge.com".
