Bart
Post by Bart »
Thanks again, great. I was looking for something like this.
Indeed, I was planning to move uploads and such that are now done by the Nano SD. To the MB RPI (which has more processor power than the Nano).
Not everything at once, of course, but gradually so that I can see what happens when.
I can also stop uploading to sites that are not used or less used. But then I don't know the load flexibility of the Nano. And I didn't know if that could be the cause of the problems.
Although I can also take the route of starting a new post thread. I'm curious about who you regard to be the new kid on the block with rhetoric you'd rather not refer to........hahahaha :lol: :lol: (just kidding. I'm not going to.
I know enough for now. Maybe after the experiments And besides...you're probably just right.
Bart
lorenz1982
Post by lorenz1982 »
Hi, after the last update, I have a problem with OS Theme.
OS Theme.jpg (135.89 KiB) Viewed 6021 times
Alternative display.jpg (112.38 KiB) Viewed 6021 times
MeteoBorgo: www.meteoborgo.it
thanks not sure how that got missed perhaps my incompetence ! but try running the update just updated
Download Update 11th August 2021
* (17:52) **Missing CSS for wind/indoor module Ref Lorenzo
* (08:41) **This Update is all related to Alternative/OS Theme display
* (08:41) *****This Is Very Important set 3 new options in setup screen *****
* (08:41) *****If you dont Alternative/OS Theme display view will not work properly !!!!! *****
* (08:41) Adds moonrise/set to clock module
* (08:41) Reduces CSS file size to 50kb !!
* (08:41) Adds script to return to previous screen when using other pages
* (08:41) Adds 5 day forecast screen via menu and adds above script
* (08:41) Adds Chart Icon link to menu
* (08:41) Adds extra indoor module when viewed in mobile screen
* (08:41) Adds return to previous screen in setup opening screen
* (08:41) Adds time updated ,precip accum,uvindex,heat index,snow accum to outlook screen view
* (08:41) Verified 100% COMPATIBILITY for PHP 8.0.9 Release
* (08:41) Corrects more typos in setup screen
lorenz1982
weatherist34 wrote: Wed Aug 11, 2021 4:54 pm thanks not sure how that got missed perhaps my incompetence ! but try running the update just updated
Thank you. Now it's OK!
dtrop1
Post by dtrop1 »
I have one Davis Airlink installed and it's inside and looks like everything is working great. Really like it.
Question, I am going to add a Outside sensor either later today or tomorrow. Will i just add it as another station and be able to see both indoor and outdoor sensors?
I see in the admin config where i specify indoor or outdoor, but will it assume the second sensor is indoors? or can we specify it as outdoor or do you need to do some programming magic?
Dennis
jmontamat
Post by jmontamat »
Good Morning, in almanac, if I click on daily charts and click to home return to almanac and backwards but not to the main screen?
rzelle-K1TTC
Post by rzelle-K1TTC »
I'm seeing the same thing with once entering Almanac then Charts Home Toggles between Almanac and Charts. While in Almanac if you click on Alt it brings you back to Home.
.. Ron
rzelle-K1TTC
I see the Alt in Almanac is actually calling the Smart TV page.
good morning josep,ron i have just addressed this pushed to github . ill update the download tomorrow because todays date is Friday the *3th :D have a good day.
rzelle-K1TTC
All Fixed.
73s
..Ron
Download Update 14th August 2021
* (07:26) **This Update is all related to Alternative/OS Theme display
* (07:26) *****This Is Very Important set 3 new options in setup screen *****
* (07:26) *****If you dont Alternative/OS Theme display view will not work properly !!!!! *****
* (07:26) Adds missing blue trend color in Alt/OS theme CSS
* (07:26) Corrects Almanac home button Ref Josep/Ron
OS Theme smooth transition from light mode to dark mode
jmontamat
Post by jmontamat »
Hi Brian, the value in Weather34 API List is missing $weather ["heat_indexmmax"] maybe in the future we should include it.
Sin título.png (11.43 KiB) Viewed 5864 times
Hi Josep
unfortunately this needs new API strings for month data also the max timestamp for month max same with windchill for colder season . in the autumn there will be a restructured API with this included and more data trend values using the delta string amongst other changes to the API . i use a custom API to try an establish any anomalies prior to requesting API changes but id rather wait till autumn as I tend to have more time to address things.
@dtrop1 sorry i meant to respond the other day , template supports one air quality sensor per brand so out of the box does not support two airlinks . supported brands is purple air,airlink,luftdaten there are preset modules for these in the setup screen to use. sorry but in short answer is no.
jmontamat
Post by jmontamat »
No problem was a detail.
I already imagine that you have to modify the Api.
dtrop1
Post by dtrop1 »
Thanks for the reply.
Bummer, but I pay attention more to outside air quality.
