lorenz1982
Post by lorenz1982 »
It works fine now.
MeteoBorgo: www.meteoborgo.it
josecmorales
Post by josecmorales »
Love Aurora, I hope the Spanish translation will appear soon.
A question, Why do I have to enter the API in the dashboard if the MB reads the data directly?
@climaguayana
davidmc36
Post by davidmc36 »
I entered my WU API for it to generate forecasts. I thought there was somewhere to select it to display the WU instead of Davis text but don/t see it now. Anyway, my Dashboard has the WU forecast on it.
WessexWeather
Post by WessexWeather »
I’ve used Brian’s templates before so I’m delighted to see they’ve made their way into Meteobridge itself.
I have a couple of questions: -
1. In the System-Administration tab within the Meteobridge Admin there are two buttons, Download Aurora Master File and Download Aurora Simple Update File. I realised these enable running of Aurora locally but is there any documentation on how to use them/where to put the files etc? Can these be run on a web server for example?
2. Is there a way to populate historical data into Aurora from, say, a MySQL database? I have records back to 2009 and it would be great to have them all within Aurora.
Many thanks.
Simon
davidmc36
Post by davidmc36 »
The Aurora template is how I have been running my site for a while. I have it on an ICD Soft server.
Something broke though when I was fooling around and when I tried to re-do it with the Aurora Master file, my charts don't work.
I can't seem to find the original version. I dont remember hiw it all worked now, getting the template onto my site. All my data is visible on the cloud dashboard though.
davidmc36
Post by davidmc36 »
davidmc36 wrote: Sat Jul 19, 2025 11:47 am How about the little data banner that appears when you open the Webcam. Can it be removed?
It covers the timestamp on my sun image.
And I don't need it for the other image as I have the overlay done already.
TIA
D
Any chance to visit this aspect? The temp/wind overlay in the upper RH corner is a bit useless really.
Hello long time no posts :-)
Ive contacted Boris recently to see if anything needs fixing or updating .
Im around till mid december to help out if any template fixes or anomalies need attention. Sorry I can not do personal modifications but happy to fix genuine issues.
So far Ive updated or fixed these
1.Fixed MENU overlap when using iPhone Pro Max phones or IOS26 .can only test on iPhone 16 Pro Max but I assume it is same on all Pro Max VERSIONS due to larger screen capability. Fixed layout view when iPhone is horizontal. see below.
2.Fixed air quality data modules when value is Zero or data not present .see below
3.adjusted Webcam large image view where temperature/wind overlaps .see below
4.updated version description to November 2025.
5.minor adjustment for Apple Watch Ultra1/ 2/3 versions .should be fine on S10/11 or lower series.
6.Minor changes to support upcoming PHP 8.5 release .
7.fixed where Celsius does not switch to Fahrenheit in some menu layouts
If you have any genuine issues not personal modifications feel free to raise them and drop em here where possible please provide a screenshot .
Thank you for the emails and compliments but as before and in responses I am involved in other projects these days so time is taken up but do contact Boris and if its a genuine template issue Im happy to respond without causing chaos and confusion.
brian.
Good to hear from you, everything OK so far?
The changes are probably only planned for the next update, because they are not yet included in Simple Update?
ToTo wrote: Tue Oct 28, 2025 5:42 pm Hi Brian,
hello all is well here apart from the earthquakes every other week since April fortunately not significant but strong enough to move the buildings.last week a 6.1 week before 5.something strong but short anything over 15 seconds is very very disturbing and damaging.
simple updates i always provide Boris a simple update file but i no longer have any meteobridge hardware so i don’t know how it works these days.
brian
davidmc36
Post by davidmc36 »
weatherist34 wrote: Tue Oct 28, 2025 11:09 am 3.adjusted Webcam large image view where temperature/wind overlaps .see below...
I was advocating for it's removal. We can do all that on the Webcam tab. If someone else has some hard-coded aspect in the top middle......same boat as I was in.......
(or optional for somebody who wants super simple solution??)
davidmc36 wrote: Sat Nov 01, 2025 2:29 pm
hello
i can make it optional via setup screen a simple yes or no under the webcam url section if that’s of any use. do consider those that don’t use built in meteobridge solution.
davidmc36
Post by davidmc36 »
A switch would be a fabulous addition. I could hav sworn I saw one on the admin interface at one time.
yamahabest
Post by yamahabest »
One thing I have noticed, any pop-up dialog is shown half-way the page.
This is showing the close button is where one would expect it (on top of the page).
This is showing the actual pop-up dialog (after scrolling down).
hello
ive adjusted it and ran it through Apple XCODE simulator looks like that is better or what is expected when using iphone .
..brian
davidmc36 wrote: Sun Nov 02, 2025 2:07 am A switch would be a fabulous addition. I could hav sworn I saw one on the admin interface at one time.
Hello
simple option added to setup screen ..brian
