Page 72 of 102
Posted: Tue Aug 17, 2021 2:30 pm
by alexeysailman
Hurray! Thank you so much, Brian. Everything works as it should!
Posted: Wed Aug 18, 2021 7:07 am
by weatherist34
Was hoping I was not going to have any updates todo but wake up to something as usual
, ref Ecowitt lightning im not getting sucked into this brand , there is an issue with using nonzerotime for last strike in Meteobridge , the nonzerotime [lgt0total-nonzerotime:--] string does NOT produce a valid timestamp of any sort after a day or more , exactly how long I don't know ,so provide I provide this info and hopefully users can liase with Boris with their findings .Im not the person who can resolve this as Ive seen this for a few years with rain when using nonzerotime ."resolving nonzeotime is a tedious task because the outcome is not immediate you may have to wait a day or more to see if it is resolved ".. food for thought does it only reproduce an anomaly after a meteobridge reboot/firmware upgrade ? and requires a strike to resolve ..have a good day
screenshots below .
Download Update 18th August 2021
* (09:03) ** Adds fallback for lightning if nonzerotime value is not present
* (07:50) ** Update for Alt/OS theme update
* (07:50) ** Adds forecast module option
* (07:50) ** Aligns indoor module
* (07:50) ** Minor css alignment for phrase last strike
* (07:50) ** Rework of the feels like module
* (07:50) ** Ecowitt last strike does not function this is a meteobridge or hardware brand problem has the nonzerotime does not produce a timestamp it seems after 1 day or more. fallback for no timestamp data has been added.
for Ecowitt Lightning Sensor use see end of setup guide
here Setup Info Guide
- times.png (29.58 KiB) Viewed 6004 times
newer features in update
- 2.png (22.08 KiB) Viewed 6004 times
Posted: Wed Aug 18, 2021 10:12 am
by jmontamat
Good morning Brian, if the forecast description is too long, it collides with tomorrow.
Posted: Wed Aug 18, 2021 11:00 am
by weatherist34
thanks see GITHUB file ...but I really think every new idea/suggestion just brings more problems , many go unseen or impossible to plan for when compiling ideas . weather template development truly sucks at times its a chore todo the most simplest of ideas !!! there is no happy medium it just gets tedious . so please I kindly ask @all no more ideas, just take the template for what it is and if doesn't meet your requirements there are plenty of others to use ..
Posted: Wed Aug 18, 2021 11:55 am
by jmontamat
The idea of forecast in ALT mode is good, I'll adapt "str_replace (" to my needs.
Posted: Wed Aug 18, 2021 4:34 pm
by weatherist34
try the file just pushed to GITHUB might be easier to manage for you
Posted: Wed Aug 18, 2021 6:04 pm
by jmontamat
In Spanish they say "A grandes males grandes remedios "
Thanks !!!
Posted: Thu Aug 19, 2021 6:38 am
by weatherist34
Download Update 19th August 2021
* (07:31) ** Update for Alt/OS theme update
* (07:31) ** Replaces forecast phrase with Icon Ref Josep
* (07:31) ** Reworks clock sunrise/set layout
* (07:31) ** Adds fallback for GW1000(alike) lightning sensor with blank nonzerotime
forecast icons replaces phrases
- 1.png (15.67 KiB) Viewed 5916 times
- 2.png (18.35 KiB) Viewed 5916 times
with valid lightning distance
- distance.png (12.14 KiB) Viewed 5910 times
fallback for blank nonzerotime in lightning (N/A)
- 3.png (6.83 KiB) Viewed 5916 times
with valid nonzerotime in lightning
- 4.png (7.95 KiB) Viewed 5916 times
Posted: Fri Aug 20, 2021 9:17 am
by weatherist34
Download Update 20th August 2021
* (10:11) ** Update for Alt/OS theme update
* (10:11) ** Adds option to show indoor module or not in mobile view Ref Daniel
* (10:11) ** Adds forecast module to mobile view
for those with no use for indoor temperature or concerns and for those wanting forecast in mobile view .
have a great weekend..Brian
- 2.png (32.23 KiB) Viewed 5871 times
- forec.jpg (90.14 KiB) Viewed 5871 times
Posted: Sun Aug 22, 2021 8:46 am
by weatherist34
As always once the newer idea becomes stable its good to remove all the accumulated Dev code which always happens , with that comes a nice load performance result and a happy server .screenshot below of load time with ICDSOFT hosted server a result of less than 1 second == 0.8 seconds !! !!! results also depend how your server is configured .
Download Update 22nd August 2021
* (10:11) ** Fixes KTS format in average wind module
* (10:11) ** Removes all Dev code reduces load time
*Please note as of September 1st update file will only contains files updated from September 1st not March 1st..
- Screenshot at Aug 22 09-31-52.png (197.62 KiB) Viewed 5816 times
Posted: Sun Aug 22, 2021 2:55 pm
by prestwickwx
Hope all is well. The performance here looks great, too.
- Capture.PNG (147.25 KiB) Viewed 5785 times
One minor bug I noticed yesterday, during a rain storm. The pop up notification was reporting the rain rate with a suffix of mm/hour while the rain module was reporting (correctly) with a suffix of in/hour. The numerical value was correct - just wrong units.
Best wishes,
Posted: Sun Aug 22, 2021 3:06 pm
by weatherist34
Ha thanks that's what I get for having no rain for 2 months or more ! see GITHUB for fix ..amongst other minor changes.
Posted: Sun Aug 22, 2021 3:25 pm
by prestwickwx
Got it!
Posted: Sun Aug 22, 2021 4:19 pm
by weatherist34
Cool so you should end up with something like this screenshot as of last GITHUB push and download was updated to ensure it all renders in Firefox accordingly .
* (17:14) ** Update for Alt/OS theme
* (17:14) ** Missing non metric rain unit notification Ref Chuck
* (17:14) ** Adds Firefox compatibility for alignments in all modules
* (17:14) ** Adds temp day max|min to temp,dewpoint,humidity
- 2.png (211.35 KiB) Viewed 5772 times
Posted: Sun Aug 22, 2021 11:07 pm
by ToTo
When I change the units in the almanac, I can no longer switch back to the main view via Home.
