rzelle-K1TTC
Post by rzelle-K1TTC »
OK I ran setup added elevation and utc offset values and all is well after saving. I don't know how those 2 values went missing. :-)
73s
..Ron
Brian/Ron,
I just updated and set the elevation and UV/Solar choice and everything looks OK.
Brian - I have noticed that the "Use Operating System Automatic Theme (Dark/Light Mode if supported)" in Setup is not Sticky. It reverts to yes each time you open the Setup.
Take care,
Bart
Post by Bart »
You may think I'm in grave danger. But that's okay. It's still going well here. My Davis is about 4.6 meters below sea level. That's -15.1 ft. Before I update. Is a minus sign ok in this new field? I don't want to go blank. The clouds don't come any closer and the sun not warmer. :shock:
Bart
Bart wrote: Tue Nov 16, 2021 6:21 pm Hello,
Bart
Hello Bart I just tried it at -20 feet returned no problems but then again I didn't have any issues originally and I couldn't reproduce the error unless I locked permissions but I don't think that was the issue kind of leaning towards conflict in PHP 7 because all sites I tried were PHP 8 but I can't confirm this .
@Chuck corrected the return value expected , though if you choose NO/YES that's what is stored in the settings file just a minor missing piece of code that returns the stored value in the setup screen only.(does that make sense?? :-) )
Bart Download was just updated with some minor fixes/workarounds
Change Log 16th November 2021
* (19:37) * Contains all features/fixes from Oct 1st to Nov 16th
* (19:37) * Important new options below require to be set
* (19:37) * Corrects theme display setup option returned value (Ref Chuck)
* (19:37) * Workaround elevation setup option not sticking *PHP 7.X ?? (Ref Ron)
* (19:37) * Adds requested numerical bearing in compass (Ref Ryan)
* (19:37) * Adds new setup screen option to set elevation (Ref Josep)
* (19:37) * Adds new setup screen option to set 9th position module (Ref Lorenzo)
Doing backups will preserve your chart data and settings in the event of any problems.
When new setup options are added ensure the settings file(console-settings)
is not locked with file permissions on your server !!.
good night and have a good week ahead Im off again for a week or so tomorrow afternoon..Brian
weatherist34 wrote: Tue Nov 16, 2021 6:46 pm
Bart
All fixed. Makes perfect sense :D
Take care,
lorenz1982
Post by lorenz1982 »
Hello.
Just a little thing.
Low radiation and moderate radiation have the same color.
MeteoBorgo: www.meteoborgo.it
The Value Definitions are a great addition. :D
lorenz1982 wrote: Wed Nov 17, 2021 4:27 pm Hello.
Lorenzo
threshold is 1-600 yellow 600 to 799 orange , 800+ to red im not aware of an official solar radiation color scale to use .
@chuck glad you like it I had some minor teething issue with purple air but should be ok now , note the CO2 was removed I have a bunch emails last few weeks all indications its stuck on 25 , whilst not a template issue but hardware so I switched the position reading to show PM10.
Still yet to install mine still need to route a power cable under the lawn ..anyway that's it from me for a few weeks got a plane to catch ..take care all
Change Log 17th November 2021
* (15:52) * Contains all features/fixes from Oct 1st to Nov 17th
* (15:52) * Important new options below require to be set
* (15:52) * Important please double check the elevation is stored in setup
* (15:52) * Corrects Purple Air falling trend arrow Ref Luke
* (14:22) * Adds clear description to top left hand module values
* (14:22) * Formats to single digit rain today if rain today is 0 (Ref Ryan)
* (14:22) * Adds requested numerical bearing in compass (Ref Ryan)
* (14:22) * Adds new setup screen option to set elevation (Ref Josep)
* (14:22) * Adds new setup screen option to set 9th position (Ref Lorenzo)
** Important please double check the elevation is stored in setup screen
and the new UV/Solar/Clock option is set.
any problems.
is not locked with file permissions on your server.
@all
the OS Theme with chart view template should now resemble this(screenshot below) , note the the top left values have been reworked to cater for description .use this to compare with your own to see if you have latest version . have a great week..Brian (ps yes the earthquake tremor today was strong and shook building but not significant to cause damage but a friendly reminder I live near an active fault line :-( )
Yes, I noticed the VOC change. No problem its still in the chart - mine has not had any issues with the 25 reading, seems to be working fine.
Take care,
jmontamat
Post by jmontamat »
Good morning, overflow in the alt theme.
Sin título.png (14.17 KiB) Viewed 6660 times
jmontamat wrote: Thu Nov 18, 2021 10:45 am Good morning, overflow in the alt theme.
Hello Josep
I didn't have enough to time to complete this yesterday but ALT theme will be removed as the OS themes will show identical max,min,avg data as shown below . But not sure when I can get this finished need to do the air quality modules but below shows what it will look like . so Im not going to fix that issue you raised . This layout is based on numerous requests over the last few weeks to show max,min,avg alongside graph display dashboard layout and this layout will have the option to set the module positions like in main dashboard.as above don't have time at present and neither do I have a reliable internet connection so not going to take the risk of failed uploads.
below shows the max.min.avg data boxes layout alongside the graphs.
jmontamat
Post by jmontamat »
well i like :D
jmontamat wrote: Thu Nov 18, 2021 2:33 pm well i like :D
I thought you might :-) im listening just takes time to find the balance and a position that doesn't screw the design... and a reliable internet .. so progress purple air done just need to do luftdaten,airlink ..and I didnt forget mmHG :-)
woolfg
Post by woolfg »
Hi Brian
Posted in error
