Reboot = Year Rain goes to zero **solved**
droiddk
Re: Reboot = Year Rain goes to zero. * Solved *
Post by droiddk »
MeteoOudkarspel wrote:Hi,
I think the problem is also away at you.
I have booted the device once again and is now on "Jun 8". Will test.
EDIT: Better late than never :lol: issue fixed, thanks Boris!
I also tested today and it works fine. When setting new values you should be aware that
it takes up to ten minutes until these changes are reported to the Meteobridge
server in the cloud. Meteobridge reads data from there after reboot.
When you change values and do an immediate reboot the changes might not
have been uploaded to the cloud and therefore will not be avail on reboot.
droiddk
Re: Reboot = Year Rain goes to zero **solved**
Post by droiddk »
"Rain-Total Today":
Before reboot: 1.0mm
After reboot: .8mm
"Rain-Total Year":
Before reboot: 24.4mm
After reboot: 24.2mm
Where did the 0.2mm go?
I might not have been part of the data set stored every 10 minutes (or what you decided as an
update interval on station tab).
When you do a graceful reboot (with the button on system tab) data should anyhow be
uploaded before system going down. When you just pull the plug, it cannot.
droiddk
Post by droiddk »
admin wrote:I might not have been part of the data set stored every 10 minutes (or what you decided as an
Ok, this makes sense.
admin wrote: When you do a graceful reboot (with the button on system tab) data should anyhow be
This does not make sense since I was using the button on the system tab.
