Page 2 of 2
Re: Corrupt Historical Data after Power Reboot - TL-MR3020V3 - SW 4.0 (now 4.3)
Posted: Thu Feb 20, 2020 2:18 pm
by robweb5mm
Far Out. All I can tell you is ... out of approximately 25+ power reboots (first 7 months) with "get newest on boot", 23 Failed to restore historical data (the 2 successful restores in last 2 months), out of approximately 25 power reboots (last 11 months) using USB stick, 25 have failed. SOFT Reboots restore data OK.
MB - has a basic Setup - Connected via WiFi, Upload to WCloud (10 mins), WU (30 Sec) & FTP (30 Sec) to my website.
LAN - (Possible Non Standard) Router Dropping pings + Blocking ARP Scans + QOS priority config for MB.
Have a happy week Boris. Thank you.
Posted: Sun Feb 23, 2020 11:47 am
by stevem
For what it is worth I have an mr3020v1. I’ve this week been developing a new web page using the meteobridge template facility. The device has been running for over 2 years. It has been rebooted on several occasions and suffered 3 or 4 power failures. I was surprised to find the oldest data associated with the alltime selector was only 5 months ago. My device seemingly lost its history last September. I’ve always had the update service and update latest on boot. I can’t tell you anything more.
Steve
Posted: Sat Mar 07, 2020 1:10 pm
Just released update should solve it for WR902AC V3. I did some other improvements, so issues on the other platforms might be resolved as well.
Posted: Fri Mar 13, 2020 9:16 pm
by robweb5mm
Thanks Boris, .... Since changing from "USB Boot" to "Get Newest on Boot" in the last 2 months, the MR3020 V3 restored correctly on 5/5 occasions. Now the question is, does using "USB Boot" still mash your data restores?
Thanks all ... Rob
Posted: Fri Apr 17, 2020 2:38 am
by robweb5mm
After getting corrupt data restores after reboots on the TL-MR3020, I'm now using SW V4.3 with "Get Newest on Boot" selected and the later MB Software now restores the data fine. I'm reluctant to change back to "Boot from USB"
Could anyone else that has a TL-MR3020 and has "Boot from USB" selected, please let me know if you've had any problems with corrupt data, especially after power reboots?
Appreciate your help ... Rob
Re: Corrupt Historical Data after Power Reboot (Using USB 4 Boot) - TL-MR3020V3 - SW 4.3)
Posted: Sun Jul 05, 2020 8:05 pm
by robweb5mm
Hi Boris,
I can confirm that backup data is being restored correctly on "power reboots" when set to "get newest on boot".
I can also confirm backup data is corrupt on "power reboots" every time when set to "boot from USB" .
Thanks ... Rob
Posted: Tue Mar 16, 2021 4:06 am
by vortexya
I am having a very similar issue but I have admin set to "get latest on reboot " I am on SW v4.4.
After using a weatherflow SWS for the last few years I upgraded to a Tempest and the sensor mappings became misconfigured so I did a hard reset,
The sensors were then mapped correctly for the Tempest and began reporting, Unfortunately the historical data that was loaded came from yesterday (after I had installed the tempest so the only data loaded was for the previous few hours)
Is there some way I can retrieve the data from a week ago or another previous point. ?
I had saved a config file from a few months back but when loaded it again caused the sensor mapping confusion.
Scratching my head here .
Cheers
Gary
Posted: Sun Mar 21, 2021 5:26 am
by robweb5mm
Corrupt Historical Data after Power Reboot (Using USB to Boot) - TL-MR3020V3 - SW 4.3)
Hi Boris,
Are you able to confirm that data is now restored without errors when booting from USB please.
Thanks a lot. Rob.
Posted: Fri Mar 26, 2021 10:12 am
didn't test.
Posted: Sat Aug 14, 2021 1:20 pm
by robweb5mm
Hi Boris,
Are you able to confirm that data is now restored without errors when booting from USB please. I hope you're going well?
Thanks a lot. Rob.
Posted: Sun Aug 15, 2021 11:13 am
I did no new testing on this.
Posted: Tue Oct 04, 2022 8:12 am
by dehatter
Good morning Boris.
This is not an enormous issue as I have taken remedial action to correct it myself, but sending this just to let you know.
After the server issue several weeks ago, I decided to install a USB stick on my TL-MR3020V3 and change the boot setting to 'try USB first'.
I can confirm that when rebooting the device, either from a soft reboot in 'administration' or a hard power cycle, historical data for the current month is lost, except for lightning data, rain rate (hourly), and solar radiation. These fields have data in them, but do not match known historical information.
Annual and All-Time data is not affected - only the current month - with the exception of total rain fall. I believe it pulls this information from 'your' server as it was off by the amount of accumulated rain since I made the change.
So... there is definitely an issue with storing historical data on a USB stick. I had no issues when it was set to 'newest on boot', so I have changed the setting back to that as is it is a real PITA to fix it, and I will remove the USB stick tomorrow.
Platform: TL-MR3020V3 (no USB hub)
RAM: 60592 kB total, 17860 kB free (70% used)
SW Version: Meteobridge 5.5 (Sep 24 2022, build 4321), FW 1.3
Uptime: 0 hours, 54 minutes (booted from USB) Buffer: 1 items (0%)
Thank you for all you do.
Tom
