Page 2 of 2
Re: [rain0total-sum24h] no longer working
Posted: Mon Nov 17, 2025 2:13 pm
by hakkisk
It seems to be addressing a discrepancy on the RPi platform (1.3 / 1.4).
Until an hour ago (between 12:00 - 13:00), it was giving me the exact information, without the last hour (24h minus 1h). Now it's fine ...
PS: I just now noticed that 24h is less than 12h ... :-D
<div class="col">
#if#{*[m]%2=0*}#then#1hod <h4cpu>[rain0total-sum1h.1:--]</h4cpu> mm#else#3hod <h4cpu>[rain0total-sum3h.1:--]</h4cpu> mm#fi#
</div>
<div class="col">
#if#{*[m]%2=0*}#then#12hod <h4cpu>[rain0total-sum12h.1:--]</h4cpu> mm#else#24hod <h4cpu>[rain0total-sum24h.1:--]</h4cpu> mm#fi#
</div>
New reports. Time 14:00 and around 14:51. Note, 24h is still 18.5mm !!!
Posted: Fri Nov 28, 2025 3:43 am
by Mattk
Also observed something similar which appears to be missing 1h but just have not been able to put my finger on just where?
At 3pm each day I run a .mail template which has a rain component as follows which has appeared fine (I thought) until yesterday when the output was clearly incorrect and at the time was raining between 1:30pm to just after 4pm
Rainfall
24 hours to 9am: {*[rain0total-sum30h]-[rain0total-sum6h]*1} mm
6 hours to 3pm : [rain0total-sum6h.1:---] mm
Today(From Midnight): [rain0total-daysum.1:---] mm
Output @3pm yesterday was and clearly the (minus)-22.8mm is incorrect considering there was definatley no rain prior to 1:30pm? 24 hours to 9am should have been 0.0mm. 6 hours to 3pm Today(from midnight) are as expected. Based on the recorded 1 minute data the expression {*[rain0total-sum30h]-[rain0total-sum6h]*1} should have evaluated sum30h of 25.2 and sum6h 25.2 hence 25.2-25.2 => 0.0 which was the rainfall for the 24 hours to 9am.
So actual rainfall for the hour (13:01-14:00) was 2.4mm and for the hour 14:01 to 15:00 (3pm) was 22.8mm hence in line with the -22.8mm in the below output which says to me the 24 hours to 9am expression was evaluated as sum30h 0.0 and sum6h as 22.8mm being only for 1 hour immediately preceding 3pm or what other values combine to create a minus rainfall for the exact rain total for the 1 hour?
3pm Observations at 15:00:00 on 27/11/2025
Rainfall
24 hours to 9am: -22.8 mm
6 hours to 3pm : 25.2 mm
Today(From Midnight): 25.0 mm
Running this same Event manually at varying times between 3-4pm output the following. Minus -0.8mm is for the period 15:00 to 15:13
3pm Observations at 15:13:00 on 27/11/2025
Rainfall
24 hours to 9am: -0.8 mm
6 hours to 3pm : 26.0 mm
Today(From Midnight): 26.0 mm
Minus -1.0mm is rain for the period 15:00 to 15:32
3pm Observations at 15:32:00 on 27/11/2025
Rainfall
24 hours to 9am: -1.0 mm
6 hours to 3pm : 26.2 mm
Today(From Midnight): 26.2 mm
The following two manual Events are 2 minutes before and 2 minutes after 4pm. Minus -1.2mm is the actual rain from 15:00 to 15:58, the 16:02 version is the sort of result expected
3pm Observations at 15:58:00 on 27/11/2025
Rainfall
24 hours to 9am: -1.2 mm
6 hours to 3pm : 26.4 mm
Today(From Midnight): 26.4 mm
3pm Observations at 16:02:00 on 27/11/2025
Rainfall
24 hours to 9am: 0.0 mm
Also note the 9am & 3pm times are hardwired as text as the Event is action daily @3pm hence also reflected in the manual test activation but something odd here but just unable to pick it?
