MB keeps losing contact with Loggers.
Re: MB keeps losing contact with Loggers
davidmc36 wrote: Sun Apr 14, 2024 2:12 am I assume I should leave the Version Control to remain on 5.7 to retain the alterations you did?
As long as I keep your Meteobridge in the beta program, you will automatically get the newest beta code during reboot, the manual settings of version is ignored. This allows to try changes without have all the user out there impacted. When we have found a solution in code I will make this public available and then I will remove your Meteobridge from beta stage and you will need to set to "newest" in order to still have the new code loaded on reboot.
Is there a reason you sticked to outdated 5.7 so far?
As the WiFi logger with IP .46 is the only one making trouble I think this has a HW/SW problem. I would recommend to contact the guy who is promoting those on wxforum.net. May be he can explain what the logger is doing here and how to debug it.
Another thought. Why do you have all these loggers? One Davis WLL or a Meteostick or MB PRO2 (when stations have good RF strength) will make all three loggers obsolete. It does no longer need 3 consoles/loggers to get data from 3 Davis stations. That need has gone long ago.
davidmc36
Post by davidmc36 »
admin wrote: Sun Apr 14, 2024 9:23 am
I was searching for ideas and saw a somewhat similar case where holding to 5.7 solved the issue.....or at least gave some idea as to the solution. Just a shot in the dark.
davidmc36
Post by davidmc36 »
admin wrote: Sun Apr 14, 2024 1:47 pm Why do you have all these loggers?
In the winter I cover my main ISS to keep out ice and switch rain data to the one close to mains power for the heated cone. I need to keep the rest of data flowing from main ISS as it is only one with Solar/UV. I happen to have a few consoles as I like them throughout the house and I have a few loggers as I had been doing some Beta with Wojtek.
Meteostick would be good option if other hardware wears out.
davidmc36
Post by davidmc36 »
admin wrote: Sun Apr 14, 2024 1:47 pm..... HW/SW problem. ....
Looking at devices, the .46 is on different FW. I do remember noticing that and it seemed to not accept any different and I never went back to it.
Let me see if I can upgrade or there may be another unit here still.
In the meantime, I will move the consoles back to the locations they were in yesterday and see if all remains connected. So far the last near day is one of the longest stretches of continuous data in a while.
I just modified the code so that in case of a socket reconnect caused by the logger Meteobridge does no repeat the initialization sequence on the Vantage. It now assumes that logger/Vantage is still on standard operation mode.
I will now release this code update, and make it public and end your beta status.
davidmc36
Re: MB keeps losing contact with Loggers. **solved**
Post by davidmc36 »
Thank you very much for the awesome support.
D
davidmc36
Post by davidmc36 »
admin wrote: Sun Apr 14, 2024 1:47 pm....Why do you have all these loggers?....
Oh, and the third is for a more accurate indoor temperature from a console with no backlight on. :wink:
davidmc36
Post by davidmc36 »
It failed again.
     logger (15.04.2024 02:00:09): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (15.04.2024 02:00:09): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (15.04.2024 02:00:09): station 0 (Vantage), firmware version request sent.
logger (15.04.2024 02:00:09): station 0 (Vantage), firmware version 3.62 (supports LOOP2)
logger (15.04.2024 02:00:09): station 0 (Vantage), no reading of Vantage's internal logger.
logger (15.04.2024 02:00:10): station 2 (Vantage), gettime request sent.
logger (15.04.2024 02:00:10): station 2 (Vantage), no Vantage time offset.
logger (15.04.2024 02:00:10): station 2 (Vantage), eeprom request sent.
logger (15.04.2024 02:00:10): station 2 (Vantage), rain collector size 0.01 inch per tick.
logger (15.04.2024 02:00:10): station 2 (Vantage), transmitter 1 active as station type #3 "Temp/Hum" mapped to "th1".
logger (15.04.2024 02:00:10): station 2 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (15.04.2024 02:00:10): station 2 (Vantage), transmitter 3 active as station type #0 "ISS".
logger (15.04.2024 02:00:10): station 2 (Vantage), firmware version request sent.
logger (15.04.2024 02:00:11): station 2 (Vantage), firmware version 3.80 (supports LOOP2)
logger (15.04.2024 02:00:11): station 2 (Vantage), no reading of Vantage's internal logger.
logger (15.04.2024 02:00:13): sensors are now providing data.
logger (15.04.2024 02:00:13): services started.
logger (15.04.2024 02:00:19): station 1 (Vantage), gettime request sent.
logger (15.04.2024 02:00:19): station 1 (Vantage), no Vantage time offset.
logger (15.04.2024 02:00:19): station 1 (Vantage), eeprom request sent.
logger (15.04.2024 02:00:19): station 1 (Vantage), rain collector size 0.01 inch per tick.
logger (15.04.2024 02:00:19): station 1 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (15.04.2024 02:00:19): station 1 (Vantage), transmitter 3 active as station type #0 "ISS".
logger (15.04.2024 02:00:19): station 1 (Vantage), firmware version request sent.
logger (15.04.2024 02:00:19): station 1 (Vantage), firmware version 3.88 (supports LOOP2)
logger (15.04.2024 02:00:19): station 1 (Vantage), no reading of Vantage's internal logger.
logger (15.04.2024 20:15:28): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:16:33): message above repeats 23 times.
logger (15.04.2024 20:16:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:16:33): disconnect station 0 (Vantage): socket reconnect failed
logger (15.04.2024 20:16:34): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:17:01): message above repeats 10 times.
logger (15.04.2024 20:17:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:17:03): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:17:32): message above repeats 8 times.
logger (15.04.2024 20:17:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:17:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:18:01): message above repeats 10 times.
logger (15.04.2024 20:18:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:18:06): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:18:28): message above repeats 7 times.
logger (15.04.2024 20:18:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:18:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:19:01): message above repeats 11 times.
logger (15.04.2024 20:19:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:19:03): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:19:29): message above repeats 10 times.
logger (15.04.2024 20:19:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:19:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:20:02): message above repeats 12 times.
logger (15.04.2024 20:20:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:20:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:20:30): message above repeats 9 times.
logger (15.04.2024 20:20:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:20:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:21:01): message above repeats 9 times.
logger (15.04.2024 20:21:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:21:03): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:21:30): message above repeats 8 times.
logger (15.04.2024 20:21:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:21:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:22:02): message above repeats 11 times.
logger (15.04.2024 20:22:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:22:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:22:32): message above repeats 8 times.
logger (15.04.2024 20:22:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:22:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:23:01): message above repeats 10 times.
logger (15.04.2024 20:23:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:23:04): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:23:32): message above repeats 8 times.
logger (15.04.2024 20:23:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:23:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:24:01): message above repeats 10 times.
logger (15.04.2024 20:24:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:24:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:24:29): message above repeats 9 times.
logger (15.04.2024 20:24:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:24:34): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:25:01): message above repeats 11 times.
logger (15.04.2024 20:25:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:25:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:25:29): message above repeats 7 times.
logger (15.04.2024 20:25:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:25:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:26:01): message above repeats 10 times.
logger (15.04.2024 20:26:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:26:03): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:26:28): message above repeats 8 times.
logger (15.04.2024 20:26:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:26:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:27:01): message above repeats 10 times.
logger (15.04.2024 20:27:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:27:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:27:28): message above repeats 7 times.
logger (15.04.2024 20:27:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:27:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:28:01): message above repeats 10 times.
logger (15.04.2024 20:28:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:28:04): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:28:29): message above repeats 7 times.
logger (15.04.2024 20:28:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:28:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:29:01): message above repeats 10 times.
logger (15.04.2024 20:29:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:29:05): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:29:30): message above repeats 10 times.
logger (15.04.2024 20:29:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:29:35): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:30:01): message above repeats 11 times.
logger (15.04.2024 20:30:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:30:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:30:29): message above repeats 8 times.
logger (15.04.2024 20:30:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:30:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:31:03): message above repeats 10 times.
logger (15.04.2024 20:31:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:31:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:31:29): message above repeats 7 times.
logger (15.04.2024 20:31:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:31:34): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:32:01): message above repeats 10 times.
logger (15.04.2024 20:32:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:32:06): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:32:28): message above repeats 7 times.
logger (15.04.2024 20:32:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:32:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:33:01): message above repeats 11 times.
logger (15.04.2024 20:33:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:33:04): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:33:32): message above repeats 8 times.
logger (15.04.2024 20:33:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:33:38): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:34:01): message above repeats 9 times.
logger (15.04.2024 20:34:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:34:04): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:34:30): message above repeats 9 times.
logger (15.04.2024 20:34:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:34:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:35:01): message above repeats 10 times.
logger (15.04.2024 20:35:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:35:04): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:35:29): message above repeats 8 times.
logger (15.04.2024 20:35:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:35:34): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:36:01): message above repeats 10 times.
logger (15.04.2024 20:36:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:36:05): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:36:29): message above repeats 7 times.
logger (15.04.2024 20:36:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:36:34): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:37:01): message above repeats 10 times.
logger (15.04.2024 20:37:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:37:06): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:37:31): message above repeats 7 times.
logger (15.04.2024 20:37:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:37:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:38:01): message above repeats 8 times.
logger (15.04.2024 20:38:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:38:03): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:38:28): message above repeats 7 times.
logger (15.04.2024 20:38:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:38:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:39:01): message above repeats 9 times.
logger (15.04.2024 20:39:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:39:03): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:39:25): message above repeats 6 times.
logger (15.04.2024 20:39:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:39:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:40:01): message above repeats 11 times.
logger (15.04.2024 20:40:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:40:03): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:40:28): message above repeats 8 times.
logger (15.04.2024 20:40:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:40:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:41:01): message above repeats 8 times.
logger (15.04.2024 20:41:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:41:03): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:41:28): message above repeats 7 times.
logger (15.04.2024 20:41:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:41:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:42:01): message above repeats 9 times.
logger (15.04.2024 20:42:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:42:05): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:42:30): message above repeats 7 times.
logger (15.04.2024 20:42:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:42:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:43:01): message above repeats 11 times.
logger (15.04.2024 20:43:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:43:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:43:28): message above repeats 6 times.
logger (15.04.2024 20:43:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:43:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:44:03): message above repeats 11 times.
logger (15.04.2024 20:44:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:44:05): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:44:31): message above repeats 7 times.
logger (15.04.2024 20:44:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:44:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:45:01): message above repeats 12 times.
logger (15.04.2024 20:45:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:45:04): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:45:29): message above repeats 8 times.
logger (15.04.2024 20:45:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:45:34): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:46:01): message above repeats 9 times.
logger (15.04.2024 20:46:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:46:05): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:46:32): message above repeats 8 times.
logger (15.04.2024 20:46:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:46:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:47:02): message above repeats 10 times.
logger (15.04.2024 20:47:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:47:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:47:32): message above repeats 7 times.
logger (15.04.2024 20:47:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:47:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:48:02): message above repeats 9 times.
logger (15.04.2024 20:48:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:48:03): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:48:29): message above repeats 7 times.
logger (15.04.2024 20:48:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:48:35): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:49:01): message above repeats 10 times.
logger (15.04.2024 20:49:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:49:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:49:32): message above repeats 7 times.
logger (15.04.2024 20:49:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:49:35): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:50:01): message above repeats 12 times.
logger (15.04.2024 20:50:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:50:05): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:50:32): message above repeats 9 times.
logger (15.04.2024 20:50:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:50:33): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:51:02): message above repeats 10 times.
logger (15.04.2024 20:51:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:51:06): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:51:24): message above repeats 5 times.
logger (15.04.2024 20:51:24): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:51:29): message above repeats 90 times.
logger (15.04.2024 20:51:29): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:51:29): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:51:32): message above repeats 57 times.
logger (15.04.2024 20:51:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:51:33): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:51:35): message above repeats 54 times.
logger (15.04.2024 20:51:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:51:36): message above repeats 1 time.
logger (15.04.2024 20:51:36): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:51:41): message above repeats 98 times.
logger (15.04.2024 20:51:41): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:51:41): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:51:48): message above repeats 126 times.
logger (15.04.2024 20:51:48): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:51:48): message above repeats 1 time.
logger (15.04.2024 20:51:48): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:51:53): message above repeats 98 times.
logger (15.04.2024 20:51:53): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:51:53): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:51:58): message above repeats 98 times.
logger (15.04.2024 20:51:58): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:51:58): message above repeats 1 time.
logger (15.04.2024 20:51:58): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:01): message above repeats 52 times.
logger (15.04.2024 20:52:01): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:01): message above repeats 1 time.
logger (15.04.2024 20:52:01): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:02): message above repeats 18 times.
logger (15.04.2024 20:52:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:52:03): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:03): message above repeats 3 times.
logger (15.04.2024 20:52:03): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:08): message above repeats 93 times.
logger (15.04.2024 20:52:09): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:09): message above repeats 1 time.
logger (15.04.2024 20:52:09): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:14): message above repeats 98 times.
logger (15.04.2024 20:52:14): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:14): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:21): message above repeats 126 times.
logger (15.04.2024 20:52:21): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:21): message above repeats 1 time.
logger (15.04.2024 20:52:21): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:26): message above repeats 98 times.
logger (15.04.2024 20:52:26): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:26): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:31): message above repeats 95 times.
logger (15.04.2024 20:52:31): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:31): message above repeats 1 time.
logger (15.04.2024 20:52:31): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:32): message above repeats 28 times.
logger (15.04.2024 20:52:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:52:33): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:34): message above repeats 39 times.
logger (15.04.2024 20:52:35): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:35): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:36): message above repeats 32 times.
logger (15.04.2024 20:52:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:37): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:40): message above repeats 70 times.
logger (15.04.2024 20:52:41): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:41): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:42): message above repeats 27 times.
logger (15.04.2024 20:52:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:42): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:47): message above repeats 98 times.
logger (15.04.2024 20:52:48): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:48): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:51): message above repeats 70 times.
logger (15.04.2024 20:52:52): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:52): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:53): message above repeats 27 times.
logger (15.04.2024 20:52:53): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:53): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:52:58): message above repeats 98 times.
logger (15.04.2024 20:52:58): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:52:58): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:00): message above repeats 45 times.
logger (15.04.2024 20:53:01): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:53:01): message above repeats 2 times.
logger (15.04.2024 20:53:01): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:02): message above repeats 24 times.
logger (15.04.2024 20:53:03): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:53:03): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:53:08): message above repeats 97 times.
logger (15.04.2024 20:53:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:53:08): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:13): message above repeats 98 times.
logger (15.04.2024 20:53:14): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:53:14): message above repeats 1 time.
logger (15.04.2024 20:53:14): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:19): message above repeats 98 times.
logger (15.04.2024 20:53:19): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:53:19): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:26): message above repeats 126 times.
logger (15.04.2024 20:53:26): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:53:26): message above repeats 1 time.
logger (15.04.2024 20:53:26): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:31): message above repeats 97 times.
logger (15.04.2024 20:53:31): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:53:31): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:32): message above repeats 28 times.
logger (15.04.2024 20:53:33): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:53:33): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:40): message above repeats 141 times.
logger (15.04.2024 20:53:40): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:53:40): message above repeats 1 time.
logger (15.04.2024 20:53:40): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:45): message above repeats 98 times.
logger (15.04.2024 20:53:45): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:53:45): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:50): message above repeats 98 times.
logger (15.04.2024 20:53:50): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:53:51): message above repeats 1 time.
logger (15.04.2024 20:53:51): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:53:56): message above repeats 98 times.
logger (15.04.2024 20:53:56): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:53:56): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:54:00): message above repeats 95 times.
logger (15.04.2024 20:54:01): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:54:01): message above repeats 3 times.
logger (15.04.2024 20:54:01): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:54:02): message above repeats 22 times.
logger (15.04.2024 20:54:03): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (15.04.2024 20:54:03): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:54:07): message above repeats 85 times.
logger (15.04.2024 20:54:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:54:09): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:54:13): message above repeats 91 times.
logger (15.04.2024 20:54:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:54:13): message above repeats 1 time.
logger (15.04.2024 20:54:13): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:54:18): message above repeats 98 times.
logger (15.04.2024 20:54:19): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.04.2024 20:54:19): error while doing accept on socket 5558 (22): Invalid argument
logger (15.04.2024 20:54:21): message above repeats 47 times.
davidmc36
Post by davidmc36 »
I found a FW file and it now appears to have same version as the other logger; 2.42 instead of 2.42c
See how that works.
D
davidmc36
Post by davidmc36 »
No good. Same failure mode.
D :(
Can you please run
http://ip-of-your-meteobridge/cgi-bin/system.cgi?netstat%20-pa
and post the reply?
Currently I do not see a flooding of CLOSE_WAIT sockets when inspecting your system.
davidmc36
Post by davidmc36 »
This us the output.
D
command: netstat -pa
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      2233/wsdd2
tcp        0      0 0.0.0.0:netbios-ssn     0.0.0.0:*               LISTEN      1284/smbd
tcp        0      0 0.0.0.0:22222           0.0.0.0:*               LISTEN      1729/loggerd
tcp        0      0 0.0.0.0:5551            0.0.0.0:*               LISTEN      1729/loggerd
tcp        0      0 0.0.0.0:22223           0.0.0.0:*               LISTEN      1729/loggerd
tcp        0      0 0.0.0.0:5552            0.0.0.0:*               LISTEN      1729/loggerd
tcp        0      0 0.0.0.0:22224           0.0.0.0:*               LISTEN      1729/loggerd
tcp        0      0 0.0.0.0:www             0.0.0.0:*               LISTEN      700/uhttpd
tcp        0      0 0.0.0.0:5553            0.0.0.0:*               LISTEN      1729/loggerd
tcp        0      0 0.0.0.0:5554            0.0.0.0:*               LISTEN      1729/loggerd
tcp        0      0 0.0.0.0:5556            0.0.0.0:*               LISTEN      1729/loggerd
tcp        0      0 0.0.0.0:5557            0.0.0.0:*               LISTEN      1729/loggerd
tcp        0      0 192.168.2.59:domain     0.0.0.0:*               LISTEN      496/dnsmasq
tcp        0      0 localhost:domain        0.0.0.0:*               LISTEN      496/dnsmasq
tcp        0      0 0.0.0.0:3702            0.0.0.0:*               LISTEN      2233/wsdd2
tcp        0      0 0.0.0.0:5558            0.0.0.0:*               LISTEN      1729/loggerd
tcp        0      0 0.0.0.0:ssh             0.0.0.0:*               LISTEN      537/dropbear
tcp        0      0 0.0.0.0:5559            0.0.0.0:*               LISTEN      1729/loggerd
tcp        0      0 0.0.0.0:microsoft-ds    0.0.0.0:*               LISTEN      1284/smbd
tcp        0      0 192.168.2.59:60256      192.168.2.58:22222      ESTABLISHED 1729/loggerd
tcp        0      0 192.168.2.59:56536      104.26.13.205:www       TIME_WAIT   -
tcp        0      0 192.168.2.59:54080      ec2-34-232-250-77.compute-1.amazonaws.com:www TIME_WAIT   -
tcp        0      0 192.168.2.59:www        192.168.2.55:51936      ESTABLISHED 700/uhttpd
tcp        0      0 localhost:ssh           localhost:46000         ESTABLISHED 24714/dropbear
tcp        0      0 192.168.2.59:54110      ec2-34-232-250-77.compute-1.amazonaws.com:www TIME_WAIT   -
tcp        0      0 192.168.2.59:www        192.168.2.55:51934      ESTABLISHED 700/uhttpd
tcp        0      0 192.168.2.59:50764      ec2-52-22-134-222.compute-1.amazonaws.com:www TIME_WAIT   -
tcp        0      0 192.168.2.59:52530      ec2-54-159-105-134.compute-1.amazonaws.com:www TIME_WAIT   -
tcp        0      0 192.168.2.59:42754      gollum.meteobridge.com:www ESTABLISHED 2842/ssh
tcp        0      0 192.168.2.59:37420      192.168.2.90:22222      ESTABLISHED 1729/loggerd
tcp        0      0 192.168.2.59:54086      ec2-34-232-250-77.compute-1.amazonaws.com:www TIME_WAIT   -
tcp        0      0 192.168.2.59:54100      ec2-34-232-250-77.compute-1.amazonaws.com:www TIME_WAIT   -
tcp        0      0 192.168.2.59:55602      192.168.2.46:22222      ESTABLISHED 1729/loggerd
tcp        0      0 192.168.2.59:50796      ec2-52-22-134-222.compute-1.amazonaws.com:www TIME_WAIT   -
tcp        0      0 localhost:46000         localhost:ssh           ESTABLISHED 2842/ssh
tcp        0      0 :::netbios-ssn          :::*                    LISTEN      1284/smbd
tcp        0      0 :::5355                 :::*                    LISTEN      2233/wsdd2
tcp        0      0 :::www                  :::*                    LISTEN      700/uhttpd
tcp        0      0 fe80::ba27:ebff:febe:2e39:domain :::*                    LISTEN      496/dnsmasq
tcp        0      0 localhost:domain        :::*                    LISTEN      496/dnsmasq
tcp        0      0 :::ssh                  :::*                    LISTEN      537/dropbear
tcp        0      0 :::3702                 :::*                    LISTEN      2233/wsdd2
tcp        0      0 :::microsoft-ds         :::*                    LISTEN      1284/smbd
udp        0      0 192.168.2.59:domain     0.0.0.0:*                           496/dnsmasq
udp        0      0 localhost:domain        0.0.0.0:*                           496/dnsmasq
udp        0      0 0.0.0.0:3702            0.0.0.0:*                           2233/wsdd2
udp        0      0 192.168.2.255:netbios-ns 0.0.0.0:*                           1285/nmbd
udp        0      0 192.168.2.59:netbios-ns 0.0.0.0:*                           1285/nmbd
udp        0      0 0.0.0.0:netbios-ns      0.0.0.0:*                           1285/nmbd
udp        0      0 192.168.2.255:netbios-dgm 0.0.0.0:*                           1285/nmbd
udp        0      0 192.168.2.59:netbios-dgm 0.0.0.0:*                           1285/nmbd
udp        0      0 0.0.0.0:netbios-dgm     0.0.0.0:*                           1285/nmbd
udp        0      0 0.0.0.0:mdns            0.0.0.0:*                           747/avahi-daemon: r
udp        0      0 0.0.0.0:5355            0.0.0.0:*                           2233/wsdd2
udp        0      0 fe80::ba27:ebff:febe:2e39:domain :::*                                496/dnsmasq
udp        0      0 localhost:domain        :::*                                496/dnsmasq
udp        0      0 :::3702                 :::*                                2233/wsdd2
udp        0      0 :::mdns                 :::*                                747/avahi-daemon: r
udp        0      0 :::5355                 :::*                                2233/wsdd2
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags       Type       State         I-Node PID/Program name    Path
unix  2      [ ACC ]     STREAM     LISTENING       4124 222/ubusd           /var/run/ubus.sock
unix  13     [ ]         DGRAM                      4166 399/logd            /dev/log
unix  2      [ ]         DGRAM                      4441 1425/smbd           /var/lock/msg.sock/1425
unix  2      [ ]         DGRAM                      5250 1285/nmbd           /var/lock/msg.sock/1285
unix  2      [ ]         DGRAM                       385 605/wpa_supplicant  /var/run/wpa_supplicant/global
unix  2      [ ACC ]     STREAM     LISTENING       5267 1285/nmbd           /var/run/samba/nmbd/unexpected
unix  2      [ ACC ]     STREAM     LISTENING       1428 747/avahi-daemon: r /var/run/avahi-daemon/socket
unix  2      [ ]         DGRAM                      5277 1424/smbd           /var/lock/msg.sock/1424
unix  2      [ ]         DGRAM                      3764 604/hostapd         /var/run/hostapd/global
unix  2      [ ACC ]     STREAM     LISTENING       3794 723/dbus-daemon     /var/run/dbus/system_bus_socket
unix  2      [ ]         DGRAM                      4051 1284/smbd           /var/lock/msg.sock/1284
unix  2      [ ]         DGRAM                      3833 647/netifd
unix  3      [ ]         STREAM     CONNECTED        386 222/ubusd           /var/run/ubus.sock
unix  3      [ ]         STREAM     CONNECTED       3767 604/hostapd
unix  2      [ ]         DGRAM                      4041 1284/smbd
unix  2      [ ]         DGRAM                      9359 2233/wsdd2
unix  2      [ ]         DGRAM                      3763 604/hostapd
unix  3      [ ]         STREAM     CONNECTED       4178 222/ubusd           /var/run/ubus.sock
unix  2      [ ]         DGRAM                      1423 747/avahi-daemon: r
unix  3      [ ]         STREAM     CONNECTED        390 605/wpa_supplicant
unix  3      [ ]         STREAM     CONNECTED       1355 723/dbus-daemon
unix  3      [ ]         STREAM     CONNECTED        391 222/ubusd           /var/run/ubus.sock
unix  3      [ ]         STREAM     CONNECTED       1354 723/dbus-daemon
unix  2      [ ]         DGRAM                       397 647/netifd
unix  2      [ ]         DGRAM                       361 496/dnsmasq
unix  2      [ ]         DGRAM                       364 496/dnsmasq
unix  2      [ ]         DGRAM                       370 537/dropbear
unix  2      [ ]         DGRAM                       384 605/wpa_supplicant
unix  3      [ ]         STREAM     CONNECTED       1229 1/procd
unix  3      [ ]         STREAM     CONNECTED        400 222/ubusd           /var/run/ubus.sock
unix  3      [ ]         STREAM     CONNECTED       4127 222/ubusd           /var/run/ubus.sock
unix  3      [ ]         STREAM     CONNECTED        399 647/netifd
unix  2      [ ]         DGRAM                      1233 1/procd
unix  3      [ ]         STREAM     CONNECTED        360 496/dnsmasq
unix  3      [ ]         STREAM     CONNECTED       4198 222/ubusd           /var/run/ubus.sock
unix  3      [ ]         STREAM     CONNECTED       1431 723/dbus-daemon     /var/run/dbus/system_bus_socket
unix  2      [ ]         DGRAM                      5247 1285/nmbd
unix  3      [ ]         STREAM     CONNECTED       1430 747/avahi-daemon: r
unix  3      [ ]         STREAM     CONNECTED       1310 431/rpcd
unix  3      [ ]         STREAM     CONNECTED        416 222/ubusd           /var/run/ubus.sock
unix  2      [ ]         DGRAM                      4126 222/ubusd
unix  3      [ ]         STREAM     CONNECTED       4168 399/logd
unix  3      [ ]         STREAM     CONNECTED       4169 222/ubusd           /var/run/ubus.sock
unix  3      [ ]         STREAM     CONNECTED       4278 700/uhttpd
davidmc36
Post by davidmc36 »
admin wrote: Wed Apr 17, 2024 11:15 pm Can you please run
and post the reply?
After the failure this morning I relocated the .46 again to same room as router and MB.
Is there a theory about actual connection issue?
The previous running while in Beta,
was done with all units co-located in same room.
D
davidmc36
Post by davidmc36 »
davidmc36 wrote: Thu Apr 18, 2024 2:49 am
and post the reply?
The Beta tests you did
D
