Question on mapping sensors. **solved**
grwkak
Re: Question on mapping sensors
Post by grwkak »
Tested again:
Migrated rain2!0total (old data and sensor) into rain2!1total (new data and sensor) - using overwrite.
Does not seem to work - my graph of rainfall using rain2!1total does not show the older data.
Is this because the 2 sensors start and stop at different times that don't overlap - rain2!0total ends a few weeks ago - rain2!1total begins shortly after rain2!0total ends - no overlap in dates?
Guy
strange. can you give me remote access to your Meteobridge?
grwkak
Post by grwkak »
Just emailed using my Gmail account.
Guy
Re: Question on mapping sensors. **solved**
Thanks, I found the bug. Should be fine with just released update.
grwkak
Post by grwkak »
Yep seems to work now - unfortunately, by using overwrite I lost the recent rain data and just got the old data. Lesson learned, don't think I can restore.
Guy
Overwrite is not expected to delete anything, just overwriting existing data. Used SQL statement also tells me that it is working this way.
grwkak
Post by grwkak »
That may be what happened - the old sensor contained no recent data, the new one did. So it may have overwritten the more recent data with zeros or nulls, something like that (inspection of data shows no data to display). Either way it does not display in a chart. What I was trying to do is combine the 2 sensor datasets. Where the old one ended the new would begin - I think not selecting overwrite would do that.
Guy
grwkak
Post by grwkak »
Update - need to look closer. Inspecting the data shows its there - not graphing though.
Guy
Thanks, the reconstruction of the database with new data inserted may not have worked. I just fixed a bug related to this.
You can fix this after the fact with "Reconstruct" button on "Database - Administration" tab.
grwkak
Post by grwkak »
Will give this a try. Its graphing daily data that seems to be the issue.
Guy
grwkak
Post by grwkak »
Bingo - seems to be working.
Guy
