Aurora 2026 Rev-4.4Q Release
Re: Aurora 2026 Rev1 Release
Simple Update Aurora-Rev1K Sunday 8th Feb https://www.mediafire.com/file/ps000yry ... K.zip/file
Master Download Aurora-2026-Rev1K https://www.mediafire.com/file/j9gwh2kb ... K.zip/file
will keep going through the ipad models and iphones '
new setup options
see below
@paul file permissions does the Feb.csv exist in the 2026 folder ??
is the path correct in meteobridge ? guessing you still run other versions of template ?
sorry been a long time since I viewed your web setup
pwilman
Post by pwilman »
Thanks so much for making the updates. I have updated my site which was very straight forward as usual. All the bugs I found seem to have been sorted - thank you so much. I will continue to have a play over the weekend and see if I find anything else.
Update of feb.csv sorted. It was me....I had the file path wrong in meteobridge. All updating now.
Paul
pwilman
Post by pwilman »
Couple of quick things:
1) on an iPhone 16 when viewing in portrait and you click on AQ or airport or webcam etc the window open below the screen you are viewing. To start with I thought they weren’t opening. It’s only when I scrolled down that I saw them.
2) URL to the indoor chart is wrong as when you click on it you get URL not found message
Will post anything else I find.
Paul
pwilman wrote: Fri Feb 06, 2026 9:40 pm Brian,
Paul
good morning Paul
1. fixed thanks and still working on various iPhones amazing how they all differ still trying to find one for all solution but slowly getting there
2. thanks fixed
will push a simple update late Saturday
thanks for the feedback much appreciated .
Screenshot at Feb 07 09-26-33.png (272.62 KiB) Viewed 1672 times
brian
davidmc36
Post by davidmc36 »
Have been distracted with some other hobbies. Looks like much development has occurred. I hope to acquire some assistance.
TIA viewtopic.php?p=53619#p53619
alexvanuxem
Post by alexvanuxem »
Thanks for the 2026 update.
I get a lot of errors concerning the preload.php file in weather34charts with ccolor variable.
[Sat Feb 07 17:53:12.538088 2026] [proxy_fcgi:error] [pid 1165038:tid 1165044] [client 84.197.91.132:0] AH01071: Got error 'PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 145; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 180', referer: https://www.sint-katelijne-waver-meteo. ... s-year.php
[Sat Feb 07 17:53:12.538200 2026] [proxy_fcgi:error] [pid 1165038:tid 1165044] [client 84.197.91.132:0] AH01071: Got error '; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 202; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 240; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 276; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 313', referer: https://www.sint-katelijne-waver-meteo. ... s-year.php
[Sat Feb 07 17:53:12.538272 2026] [proxy_fcgi:error] [pid 1165038:tid 1165044] [client 84.197.91.132:0] AH01071: Got error '; PHP message: PHP Warning: Undefined variable $position8 in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/yearbarometermodulechart2.php on line 20; PHP message: PHP Warning: Undefined variable $position8 in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/yearbarometermodulechart2.php on line 25', referer: https://www.sint-katelijne-waver-meteo. ... s-year.php
[Sat Feb 07 17:53:12.544851 2026] [proxy_fcgi:error] [pid 1165038:tid 1165086] [client 84.197.91.132:0] AH01071: Got error 'PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 145; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 180', referer: https://www.sint-katelijne-waver-meteo. ... s-year.php
[Sat Feb 07 17:53:12.544956 2026] [proxy_fcgi:error] [pid 1165038:tid 1165086] [client 84.197.91.132:0] AH01071: Got error '; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 202; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 240; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 276; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 313', referer: https://www.sint-katelijne-waver-meteo. ... s-year.php
[Sat Feb 07 17:53:12.552742 2026] [proxy_fcgi:error] [pid 1165038:tid 1165041] [client 84.197.91.132:0] AH01071: Got error 'PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 145; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 180', referer: https://www.sint-katelijne-waver-meteo. ... s-year.php
[Sat Feb 07 17:53:12.552867 2026] [proxy_fcgi:error] [pid 1165038:tid 1165041] [client 84.197.91.132:0] AH01071: Got error '; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 202; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 240; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 276; PHP message: PHP Warning: Undefined variable $ccolor in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/aurora/weather34charts/preload.php on line 313', referer: https://www.sint-katelijne-waver-meteo. ... s-year.php
Can you investigate please?
cheers Alex
Simple Update Rev1F https://www.mediafire.com/file/34hzcke8 ... F.zip/file
Master Download REV1F https://www.mediafire.com/file/dngavu18 ... F.zip/file
mostly minor fixes and IOS device alignments ..ongoing
@alex not seeing this unless any the others are seeing it could be localised anomaly. your website crashed on loading unfortunately here kept returning a 500 error .
https://www.sint-katelijne-waver-meteo. ... 4-2026.php
davidmc36
Post by davidmc36 »
I get errors like that on my messed up site Admin Panel. Maybe not exact....but start with Undefined Variable
davidmc36 wrote: Sat Feb 07, 2026 7:43 pm I get errors like that on my messed up site Admin Panel. Maybe not exact....but start with Undefined Variable
i don't see the undefined errors locally , the ones listed in his post refer to this in screenshot below but it's
there in Rev1F release .
please provide a url or output of undefined values i can then take a look and look/compare locally
please note from your other post , I don't do personal email support anymore any issues feel free to drop them here I'll do my best to respond with solutions. this time of year is a good time for resolving issues has I'm a warm weather man these days so feb/march being coldest months here in Istanbul i tend to do this stuff this time of year rest of the year outdoor life takes over. brian
davidmc36
Re: Aurora 2026 Rev1F Release
Post by davidmc36 »
There seems to be less now but is still there on my admin interface seems WU API related:
Warning: Undefined array key "errors" in /home/morewoodweather/www/www/Aurora/console-setup.php on line 2565
Warning: Trying to access array offset on null in /home/morewoodweather/www/www/Aurora/console-setup.php on line 2565
https://www.morewoodweather.ca/Aurora/index.php
2565     <input name="wuapikey" type="text" id="wuapikey" value="<?php echo $wuapikey; ?>"
Re: Aurora 2026 Rev1M Release
Simple Update Aurora-Rev1M Sunday 8th Feb https://www.mediafire.com/file/jpv14lxq ... M.zip/file
Master Download Aurora-2026-Rev1M https://www.mediafire.com/file/n2icmtyw ... M.zip/file
1.corrects some undefined variables in preload ref Alex.
2.adds Davis Woodsmoke module in setup screen ,choose either purple air or davis airlink woodsmoke.
3.more refinements for IOS devices ipads ..*ongoing
4.corrects earthquake magnitude value
5.aligns webcam image module
6.improved colour saturation compatibility for HD screens
7.fixed Davis Hardware Envoy 8x icon position
pwilman
Re: Aurora 2026 Rev1K Release
Post by pwilman »
Updated to the latest version this morning and am continuing to road test. Couple of things:
1) when you click on the forecast icon on the side bar, the box that open up misses the top of the the first 2 graphs.
2) on the main screen there are inconsistencies with how the max and min data are presented in the various cells. Sometimes there is an : other times not. Sometimes a space after the : sometimes not
3) When I save from the config page I get the following error:
Warning: Undefined array key "stationName" in /customers/8/4/1/paulwilman.com/httpd.www/W34/console-setup.php on line 270 Warning: Undefined array key "theme" in /customers/8/4/1/paulwilman.com/httpd.www/W34/console-setup.php on line 271 Fatal error: Uncaught Error: Call to undefined function exec() in /customers/8/4/1/paulwilman.com/httpd.www/W34/console-setup.php:325 Stack trace: #0 {main} thrown in /customers/8/4/1/paulwilman.com/httpd.www/W34/console-setup.php on line 325
pwilman wrote: Sun Feb 08, 2026 2:34 pm Brian,
Hello Paul thanks
1.some of these pop up modules need rewriting to work better in pop up area ..will look at it next weekend
2.are you OCD :-) just kidding will take a look
3. Fixed had missing station name box so been added back to setup screen . theme error redundant output so removed as template has no theme layouts apart from default.
1.simple update fixes some undefined stuff but *note these undefined errors do not affect template performance or anything visually .
2.minor adjustment to pop up areas.
3.removed unused jQuery scripts .
4.added back in station name option in setup screen .
thats it until next weekend ..thanks for the feedback and patience..brian
pwilman
Post by pwilman »
Thanks for making the updates......in regards my OCD - you should try living with me!!!!!
All looking goood
Paul
pwilman
Post by pwilman »
Latest update seems to throw up an error for me in reference to line 5 of settings.php which seems to be about the variable "theme". It kicks in when you go into the setup screen. I added in the station name and clicked save. The error then appeared when you go into the main webpage.
I have reverted back to the previous verion (K) and everything is back to normal.
Paul
