Page 2 of 2
Re: meteocam to weathercloud
Posted: Thu Apr 16, 2026 9:55 am
by LudwigD
I’ ll also open a ticket on weathercloud about this.
Hopefully they will believe there is something wrong on their side ….
LD
Posted: Tue Apr 21, 2026 5:46 pm
by alexvanuxem
hi,
it changed now i get 90% succes rate, I also changed the script,
could you check on your side, with the older scripts?
cheers
Alex
Posted: Thu Apr 23, 2026 8:54 am
by LudwigD
At the moment I have a success rate of 94% (40 % before), with an upload time of five minutes.
I haven't changed anything in my script! This makes the images of the timelapse much smoother.
In the meantime, no response from Weathercloud on my ticket (a week old)...
Greetings,
LD
Posted: Thu Apr 23, 2026 10:01 am
by LudwigD
To be correct, I just received this mail:
Thank you very much for using Weathercloud and for upgrading to the Premium plan.
Following our investigation, we have confirmed that the issue originates on our side.
We have implemented corrective changes to resolve the problem.
If the issue persists after these updates, please let us know so we can continue the investigation.
LD
Posted: Thu Apr 23, 2026 5:26 pm
by alexvanuxem
I made a new script on the basis of this https://meshka.eu/Ecowitt/dokuwiki/doku ... owitt_hp10
and the do a curl ftp to weathercloud.
It takes image directly from the hp10 and and puts on the weather data.
I believe you use ecowitt as a main station, I use Davis Vantage Pro 2, so i changed it display data of the davis.
I got the same email, I only have failures on 00, 15, 30, 45 minutes past the hour, I mailed them my error log.
You can view my cam here also https://app.weathercloud.net/d2773795103#profile
I find the overlay better than the one meteobridge provides. I also added a smart weather conditions line.
If you want I cvan send you it.
Many thanks for the push to WC!
Grtz
Alex
Posted: Fri Apr 24, 2026 12:05 pm
by LudwigD
At the moment I 'm having an upload succes rate of 98 %.
The few one's who didn't came through were at 00, 15 (2x) and 40 minutes.
My station is a simple CCL Electronics W100 system, which I want to upgrade in the future with a Davis Vue ISS system.
For the moment, I will leave everything as it is.
https://app.weathercloud.net/p1177361959
Thanks for Your offer, I'll see later on.
btw, very nice website !
Greetings,
LD
