Meteohub Language Files
What's hot...
urosh
Re:Meteohub Language Files
Post by urosh »
I will do the translation into Slovene.
Let's see how much i will have :S
I will do my best.
Just a question - as we use characters like šđžćč i would need to know what the default charset is... UTF-8 or something else?
Cheers!
Specified content type is "text/html;charset=iso-8859-1"
new releases will have the character set as a value that can be replaced by a definition given in the language file. You will find there
iso-8859-1::
if you don't specify something else it will stay iso-8859-1. But you can also change the character set for your language file to UTF-8 like this for example:
iso-8859-1::UTF-8
This should give you all flexibility to even cope with non-western languages.
Olivier
Post by Olivier »
I will do the translation in French, i will begin next week.
I will write a message in this topic when i will have finished.
Olivier
urosh
Post by urosh »
Hello.
Here is the translation into Slovenian. There ares till some few words, that i will have to translate, but first I need to know where they stand and how they look like... So how can I upload these file to see it?
Cheers!
To see your results, put the file at "/public/graphs/" folder (the file must have extension ".lang" ) and you need Meteohub version 2.8.
That is all :-)
I just see, that line 1 still has the TEMPLATE word in it. Please replace by "Slovenian" or even better how it is named in your language. UTF-8 seems to work fine with my Browser.
urosh
Post by urosh »
Hello again.
That works just fine.
Attached is the latest translation into Slovene. I just have one more question...
i have translated all, but there is still something that was not translated like:
Linux Kernel: 2.6.21.7 266 BogoMIPS, 30 MB RAM, NSLU2 (266 MHz)
MeteoHub: Version 2.8 (c)2008 by Boris Pasternak, info@meteohub.de
Activation Code: xxxxxxxxxxxxx aktivirano
or:
Swap: 0MB od 127MB uporabljeno (0%)
System: 212MB od 402MB uporabljeno (52%)
Data: 86MB od 1322MB uporabljeno (6%)
Where can i translate this?
Cheers!
urosh
Post by urosh »
Ok... I can not change the attached file. So here is the file again...
Cheers!
urosh
Post by urosh »
Ok. I made again some little changes. This should be it now :).
I still didnt get an answer about the remaining translations - where can they be done - if?
And here the final translation into Slovene.
Cheers!
[file name=slovenian-2470a4bb8c8f26aa68b989c124b12d32.zip size=8852]http://www.meteohub.de/joomla/images/fb ... b12d32.zip[/file]
slovenian.lang has been added to the language file archives in the download section.
In future versions even more parts of the user interface will become "translateable". But I think the most important things are already done.
urosh
Post by urosh »
Ok. Great.
Tnx
sevenless
Post by sevenless »
urosh (or Boris): you might want to revise the post above (#2285) about extra headers from the system status page to censor urosh's activation code so it doesn't get "borrowed"!
urosh wrote: i have translated all, but there is still something that was not translated like:
Activation Code: xxxxxxx aktivirano
wfpost
Post by wfpost »
sevenless wrote:urosh (or Boris): you might want to revise the post above (#2285) about extra headers from the system status page to censor urosh's activation code so it doesn't get "borrowed"!
does meteohub look for a software MAC?
If it is possible at all entering a Software MAC, which I doubt it is.
urosh
Post by urosh »
Hello.
I have changed the key. But as i think no one else should be able to use the key - as far as i know it should be used only with my mac...
But anyway... tnx :)
Cheers!
yep. activation codes are machine specific.
minapija
Post by minapija »
Finally czech translation is here. But Boris, please check page Weather Networks, this page is without defined charset, so translation is not nice ;)
