Meteohub Update 3.0
What's hot...
CarstenKR
Re:Meteohub Update 3.0
Post by CarstenKR »
admin wrote:Yep, it is a bug in the dashboard 1.7. Will bring an update tonight.
hmmm - thank's for your quick support! But in my opinion, this updates is not really helpfully... The problem exist furthermore... :S
urosh
Post by urosh »
Hello.
As you can check at my station:
http://vreme.jausovec.com/myweb/uploads/dashboard1.html
there is no problem anymore... It was fixed. I would also need to translate it into my language - so Boris - where can this be found? The background is translated and working well, just the dashboard not (yet).
Regards, Uros
CarstenKR
Post by CarstenKR »
@urosh: Yes, I see... But I see something more: Your dashboard is version 1.8, my dashboard is 1.7! :blink:
What's wrong? My Version? The Update? :woohoo:
urosh
Post by urosh »
hello.
Have you upgraded your box to version 3.0a? After upgrade my is working well. Maybe you should try in your browser to do crtl+F5 (refresh the whole page).
Maybe this helps...
Cheers!
Chill
Post by Chill »
urosh wrote:Hello.
Regards, Uros
Have you checked Dashboard selection language?
Chill
CarstenKR
Post by CarstenKR »
Yes, first I upgrade to 3.0, then to 3.0a.
All language settings are correct = "Deutsch".
I do not use & check my dashboard online, but about the system menu (Dashboard -> Display & Save).
Edit 1: The update to 3.0a is not shown in the system info! But i do this job correctly and get no error message...
Edit 2: Sorry - Am I really the only one with this problem??? :blink: :woohoo:
close your browser and try again.
CarstenKR
Post by CarstenKR »
admin wrote:close your browser and try again.
Yes - ok... First lesson PC technology. Would be rather too simply, maybe! :S
I've restarted the MeteoHub and the PC, cleared the IE-cache and have used other browsers like FireFox, try to upload the update to 3.0a again and again. It also makes no difference from which PC I try to do this. I only get suaheli on the dashboard.
The usual help yourselves jobs seems to be for the back... Some other proposals?
