Meteohub Update 4.0 "multi station" (highly experimental)
What's hot...
darren7303
Re:Meteohub Update 4.0 "multi station" (highly experimental)
Post by darren7303 »
I am having the same problems with my WMR-200 and can confirm.
I have tried renaming the wind0 several times sucessfully but after choosing the named wind0, both for the dashboard and WDLive, neither save the wind0 with the name, but revert to a different wind0.
My wind chill is showing the internal temperature. I have tried both methods, currently use wind chill from weather station, with no changes to the value shown.
I too have a UV sensor and again it has not been recognised by the software, I have tried re-syncing the senor, even though the WMR-200 was synced ok, but with no success.
I have also tried re-loading 3.3c until version 4 is stable, but it is still showing the windchill as the internal temperature.
piombo
Post by piombo »
Station's Altitude: 500
Sea Level calculation: aus der Wetterstationshöhe berechnen
Wind Chill calculation: aus Wind und Temperatur (th0) berechnen
On Dashboard you can see the sea level pressure and the local pressure (kleinlundi.mine.nu/dashboard) and also the wrong wind chill under the outside temp.
could you please give me access to your systems? I can't reproduce this failure here. I would need ports 22 and 7777 on your router forwarded to LAN IP of Meteohub and the WAN IP of Meteohub. Please mail details to info(at)meteohub.de
Didi you install rc2? Or are you still on rc1?
darren7303
Hi Boris,
I have replied as requested, but forgot to say I am using RC2.
Darren
I just made some more bug fixes avail as rc3.
Main fixes:
- wmr200 uv sensor now being recognized
- wmr200 wind chill problem
- calibaration settings are now taken into account
Thanks for finding this!
Post by skyewright »
admin wrote:- calibaration settings are now taken into account
Confirm calibrations now working fine. Thank you. :)
(I don'use the other bits that were fixed by rc3).
Re. plug-in testing, I'm currently thinking about owperl, but real-life requires too much attention to do much about it at present...
darren7303
Hi
I can confirm that the UV sensor is being found and recognised and wind chill is being reported correctly.
Thanks for the swift fix!! :)
piombo
Post by piombo »
As usual: Great work within a short time! Thanks!
Now there is a UV-Sensor and wind chill correct calculated and windsensor ok.
Still not working is a graphic with pressure at sea level. It shows the same graph using thb0 and thb0-sea. Sea level pressure is calculated by meteohub and shown correctly in dashboard.
And as said before: great work!!!
more bugs fixed in rc4 which is ready for download now:
- "wind0 ()" selection problem solved
- sealevel pressure calculations should also work now
piombo
Post by piombo »
Hi!
Sea pressure graphs are still not working; at least not at my meteohub.
Peter.
Please some more details.
1) which weather station
2) which release candidate? rc4?
3) which settings (from station, via altitude, via temperature and altitude)?
piombo
Post by piombo »
No sea pressure level graphs
I wrote before, so I didn't want to double.
WMR200, rc4, via altitude
On rc3 I tried other settings, which didn't work neither. After changing there is always a recalculation, which takes a lot of time, so I stopped trying other settings on rc4.
made a new bug fix update (rc5), that can be downloaded by the 4.0 link at the beginning of the thread.
changes:
- fixes a bug reading wmr100 UVN800
- fixes a bug not naming extra sensor 3 of TE-923 correctly
- fixes a bug that interrupts reading data via weather station plugin
rc6 fixes a problem with wmr100 rain gauge.
CarstenKR
Post by CarstenKR »
Hmmm... So langsam werde ich doch was kribbelig, was das neue Update angeht... Haben will... :woohoo:
Wann wird denn voraussichtlich der Hinweis
Diese Version ist noc stark experimentell und enthält mich Sicherheit noch einige Bugs. Diese Version ist für ein echtes Produktionsumfeld noch nicht geeignet.
verschwinden???
Würde ja gerne mittesten und helfen damit's schneller geht, habe aber leider nur ein "echtes Produktionsumfeld" zur Verfügung. Warte also voller Spannung auf das final release...
