Why has graph uploads suddenly stopped uploading?
yellowsnow
Re:Why has graph uploads suddenly stopped uploading?
Post by yellowsnow »
I have copied the meteohub runtime environment onto a Kingston USB flash memory drive, 4gb following the steps in 1.1.3 of the manual. I have used the Windows XP method.
I have then started meteohub, however I cannot access the meteohub application. It would appear that my router and network drive are just identifying the unit as a linksys unit Host Name: LKG288307.
So it appears I have missed a step(s)?
Bill Myers
Did you use DiskImage for USB stick preparation?
Did you select "physical disk" mode?
yellowsnow
SUCCESS! All systems are up and running again.
Thank you for all your assistance in helping me resolve this issue.
I did use DiskImage but I was not sure of the mode.
I just finished redoing the stick and I am now in.
Obviously I didn't select the "Physical Drive" mode.
So my next step is to see if I can get the allsensor file and weather display files to upload.
I'll let you know. Thank you.
Bill Myers
