Problem - Data upload stopped (connection with Internet fail
Re:Problem - Data upload stopped (connection with Internet f
I would propose to use static IPs to get around this DHCP problem. See instructions here (ignore when values flip after having pressed "save", just reboot to see changes effective): http://www.meteohub.de/joomla/index.php ... 6&catid=23
Please don't use 192.168.1.77 as an IP you manually type into the IP input field. Reason is that regardless what IP Meteohub gets via DHCP or manually it automatically assigns a second additional IP fixed to 192.168.1.77 to give you a way to login even if you can't remember your static IP or DHCP failed. This will conflict with giving the same IP manually.
Joe200
Post by Joe200 »
admin wrote:I would propose to use static IPs to get around this DHCP problem. See instructions here (ignore when values flip after having pressed "save", just reboot to see changes effective): http://www.meteohub.de/joomla/index.php ... 6&catid=23
So, I must follow the steps in that link that you gave me. But I'm confused about one thing in the text in bold:
It says "set appropriate IP".
So what IP must I write on that field, if you say to not use 192.168.1.77?
:unsure:
take the IP of your router or PC and change the last digit block to a value between 1 and 254 that is not used in your sub net. What results is a fine static IP for Meteohub.
Joe200
Post by Joe200 »
So, you are saying to change the last block of meteohub IP to a value betweem 1 and 254 that is not used by another machine or equipment?
And If I do that, meteohub will stay forever with that IP, even when reboot?
yes, exactly
Joe200
Post by Joe200 »
Ok. I'll do that.
Later, I'll tell something (if it works or if the problem continues - I hope not...).
Thanks for all your help,
Joe200 :)
