Error when flashing SheevaPlug
Re:Error when flashing SheevaPlug
Post by skyewright »
ON1DQD wrote:I cant see my postings if i reply to this topic,
Page 2 of this topic displays very strangely. Maybe as if no "Cascading Style Sheet"?
The page I'm writing this reply on is suffering the same problem.
Maybe it's due to some unusual content somewhere in the topic?
It seems that the Preview button isn't working. I'll try using Submit but I can't be sure it will work! If you see this then maybe it would be an idea to start a new topic?
Later: The Submit worked, and now I'm editing the item it looks just fine. Very strange...
ON1DQD
Post by ON1DQD »
Hi all,
I like to report that the problem is sloved and was due to the new Vendor-Product ID that is used in the SheevPlug produced after date 30/Jul/2009.
Thanks to Boris who put me in the right direction at plugcomputer.org forum.
!!! THANKS BORIS !!!
interface ft2232
ft2232_layout sheevaplug
ft2232_vid_pid 0x0403 0x6010
#ft2232_vid_pid 0x9e88 0x9e8f
#ft2232_device_desc "SheevaPlug JTAGKey FT2232D B"
jtag_khz 2000
Make the above change to the file: sheevaplug.cfg located in:
\\meteoplug-installer\\scripts-linux\\openocd\\config\\interface
MeteoPlug is running REAL fast compared to the NSLU2;)
Regards / Grüß,
Geert - ON1DQD
I made the meteoplug-installer script a bit more intelligent so that it recognizes the kind of USB interface and uses a matching config file. There is no more manual patching required.
Here is a link to the updated archive:
http://www.meteohub.de/joomla/index.php ... &Itemid=29
