Update 4.6p
What's hot...
Re: Update 4.6p
wfpost wrote:there seems to a problem with graphs.
When selecting actual year, the graph showing two years ahead instead of 1 year.
Good finding. This bug must have been in there for years ;-)
Will be fixed with the next update.
Sedrani
Re: Update 4.6p
Post by Sedrani »
up
YJB
Re: Update 4.6p
Post by YJB »
Sedrani wrote:Thanks for your reply.
I launched the command on my web browser and the answer of the system was "N".
My Meteohub is running the 4.6p version.
Any idea?
o
I'm out of ideas, it appears to me that Meteohub is doing it's job, so your next step would be to check with the guys who support WDL and ask them why this is not working. Maybe WDL is looking at another field as well.
Sedrani
Re: Update 4.6p
Post by Sedrani »
I've reported the problem to the WDL development team through the bug tracker platform and this is their reply:
Try using the clientraw parser (online version or the one built into the WDL configurator) to look at the icon values being sent to WDL. It's almost certainly a problem with the values being sent by Meteohub as WDL only displays what it is sent.
I verified that the icon values sent to WDL are actually only day values.
Mauro
YJB
Re: Update 4.6p
Post by YJB »
Not sure if Boris can implement this.
You can probably help him by specifying:
- Which fields in clientraw need to be changed
- What the possible values should be for day and night
Please be aware that I'm just a regular user, I'm not committing to any change or whatsoever, but my experience is with software development and the easier you make it for a developer (by giving him the required information), the more likely it is that something gets implemented.
Sedrani
Re: Update 4.6p
Post by Sedrani »
Thanks for your help.
This is the parser output of the clientraw generated at 9:58 PM and the clientraw file.
See the field n.15 (Partly Cloudy and not Partly Cloudy Night):
Parser output
Types: L = Label I = Icon K = Kts D = Degrees F = FT C = Celcius H = Baro in hpa P = Percent M = Rain in mm N = Number
Field# Label Type Contents
000 Header L 12345
001 Avg Speed K 0.8 kts = 0.92 mph = 1.48 km/h
002 Gusts K 0.0 kts = 0 mph = 0 km/h
003 WindDir D 30° (NNE)
004 Temp C 17.8 C = 64 F
005 Outside Humidity P 63 %
006 Barometer H 1020.4 hPa = 30.13 inHg
007 Daily Rain M 0.00 mm = 0 in
008 Monthly Rain M 216.00 mm = 8.5 in
009 Yearly Rain M 483.40 mm = 19.03 in
010 Rain Rate M 0.00 mm = 0 in
011 Max Rain Rate M 0.00 mm = 0 in
012 Indoor Temp C 24.9 C = 76.8 F
013 Indoor Hum P 47 %
014 Soil Temp C - C = 32 F
015 Forecast Icon I 19 (Partly Cloudy)
016 WMR968 Extra Temp C - C = 32 F
017 WMR968 Extra Hum P - %
018 WMR968 Extra Sensor N 0
019 Yesterday Rain M 0.0 mm = 0 in
020 Extra Temp Sensor 1 C - C = 32 F
021 Extra Temp Sensor 2 C - C = 32 F
022 Extra Temp Sensor 3 C - C = 32 F
023 Extra Temp Sensor 4 C - C = 32 F
024 Extra Temp Sensor 5 C - C = 32 F
025 Extra Temp Sensor 6 C - C = 32 F
026 Extra Hum Sensor 1 P - %
027 Extra Hum Sensor 2 P - %
028 Extra Hum Sensor 3 P - %
029 Hour T 22
030 Minute T 00
031 Seconds T 02
Clientraw.txt
12345 0.0 0.8 51 17.8 62 1020.5 0.00 216.00 483.40 0.00 0.00 24.9 47 - 19 - - 0 0.0 - - - - - - - - - 21 58 01 Roveredo_in_Piano-21:58 0 - 22 09 - - - - - - - 17.8 19.3 27.8 11.9 19 Increasing_clouds_with_little_temperature_change._Precipitation_possible_within_24_to_48_hours. 0 0.0 0.0 0.1 1.3 1.8 1.9 2.3 2.0 1.2 0.8 0.8 1.8 0.5 0.2 0.0 0.0 0.0 0.0 0.0 0.0 9.5 10.4 2960 22/09/2010 29.4 13.0 27.8 11.9 - 0.0 0.0 0.1 1.3 1.8 1.9 2.3 2.0 1.2 0.8 18.9 21.2 24.9 27.3 27.3 27.6 27.1 26.7 25.7 24.7 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 27.8 11.9 17.8 9.5 0 _ _ 112.5 _ 0 - - - - - - - - 24.9 22.7 - 1021.2 1019.0 2.5 _ _ - - 13.4 6.9 0.0 2010 _ 0 0 0 90 23 113 113 113 135 113 113 113 45 - - 0.0 - 46.009722 -12.62 - 87.0 27.0 - - !!C10.37Of!!
Mauro
YJB
Re: Update 4.6p
Post by YJB »
I've created a new post on this subject in the "Meteohub Application" section, since this issue is not really 4.6p related.
viewtopic.php?f=8&t=8116
