Re: Problem with power meter
Posted: Sun Sep 12, 2010 8:35 pm
I'm using:skyewright wrote:Any particular ones? I ask as I'm awaiting delivery of an RFXMeter (plus 3 x RFXPulse) and I have a lot of OS 433 Mhz sensors...YJB wrote:Hmm, a would be a bit careful, occasionally I'm missing the rfxmeter readings for some time, since the transmission is overlapping with other sensors on 433 Mhz.
2 * BTHR918N
1 * STR918
1 * RGR126
1 * THGR918
3 * THGR228N
and 3 * RFXmeter (2 * power and 1 * gas).
I don't think I can blame any particular sensor, it just gets a bit crowded in that band. Keep in mind that the Oregon sensors are sending all data at least twice every cycle and the RFXmeter is doing this as well. I've setup my RFXmeter for transmitting every minute (initially it was every 30 seconds, but that was a bit too much data). When looking at my raw data I see that I miss readings every now and then, but that is, in my opinion, not something to worry about.
To give you a rough idea: these were the reading counts for July:
data10: 34573
data11: 33930
data12: 34676
In a perfect world I should have received approx 44000 readings, but keep in mind that apart from missing a reading, the 1 minute window slides as well (2 -3 seconds):
20100701000602
20100701000704
20100701000806
20100701000909
20100701001011
20100701001113
Hope this explains, otherwise let me know.
