Problem logging on with WIFI
jrusling
Re: Problem logging on with WIFI
Post by jrusling »
The servers seem to be still down. It is interesting that I can get to the meteobridge landing page through WIFI when I could not get to it once the software was loaded. Here is the status from the bottom of the landing page. I have always used the following address to access it http://192.168.1.112. I will look at the manual to see the requirements for the USB stick and will give that a try once the servers are back up.
IFCONFIG:
br-lan Link encap:Ethernet HWaddr F8:1A:67:87:3A:F7
inet addr:192.168.168.111 Bcast:192.168.168.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eth0 Link encap:Ethernet HWaddr F8:1A:67:87:3A:F7
collisions:0 txqueuelen:1000
Interrupt:4
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:58 errors:0 dropped:0 overruns:0 frame:0
TX packets:58 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5447 (5.3 KiB) TX bytes:5447 (5.3 KiB)
wlan0 Link encap:Ethernet HWaddr F8:1A:67:87:3A:F7
inet addr:192.168.1.112 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:40355 errors:0 dropped:388 overruns:0 frame:0
TX packets:1692 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:32
RX bytes:9000706 (8.5 MiB) TX bytes:160785 (157.0 KiB)
RESOLV.CONF:
search lan
nameserver 127.0.0.1
ROUTE:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.1.1 0.0.0.0 UG 0 0 0 wlan0
192.168.1.0 * 255.255.255.0 U 0 0 0 wlan0
192.168.168.0 * 255.255.255.0 U 0 0 0 br-lan
NSLOOKUP:
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost
Address 1: 2607:5300:100::38
Address 2: 198.50.144.56 tau.meteobridge.com
This tells me that Meteobridge is connected fine to your WLAN.
DNS seems to be resolved fine. So I guess that when you wait a bit,
this screen will disappear once Meteobridge application stack is loaded.
jrusling
Post by jrusling »
I have let it wait for over 10 hours and it stays on the landing page. I am going to try a complete reset. If that does not work is there some place where I can download the necessary software to put on the USB stick and get it to work that way. I have a TP-LINK MR3020.
Please install newer firmware, you are still on 1.1. There is no downloadable image to be installed on a USB stick.
jrusling
Post by jrusling »
Thanks for all of your help. A full reset let it come back up. I then installed the latest firmware and after getting everything set back up everything seems to be working fine.
Thanks again for your patience and help.
