actual_rain0_rate_mm **solved**
mrkmhlr
Re: actual_rain0_rate_mm **solved**
Post by mrkmhlr »
Vantage Pro 2 Plus via TCP/IP.
mrkmhlr
Post by mrkmhlr »
I don't think my system is actually updating to 5.0a. Under maintenance when I check for an update it sees 5.0a, I click update and I get a message saying the update was installed. However when the system reboots, System Info says I am running 5.0 (Build 1561). I have tried doing the auto install 3 times, and I still see5.0 (Build 1561).
mrkmhlr
Post by mrkmhlr »
One last thing. I was using a Meteostick, but I saw this problem last week and I decided to stop logging on the Meteostick and go back to using the Vantage console (with WeatherLink IP). However now I am getting the same results. The Meteostick station is still in the Meteohub, just stopped.
mrkmhlr wrote:I don't think my system is actually updating to 5.0a. Under maintenance when I check for an update it sees 5.0a, I click update and I get a message saying the update was installed. However when the system reboots, System Info says I am running 5.0 (Build 1561). I have tried doing the auto install 3 times, and I still see5.0 (Build 1561).
Please read here: viewtopic.php?f=14&t=9985
5.0a is not avail for Shevaplug and alikes. Will be part of next update again.
mrkmhlr
Post by mrkmhlr »
When will that be? What do I do in the meantime?
mrkmhlr
Post by mrkmhlr »
Any updates on when this will be fixed for the DC01?
