It is with much sadness that a long term contributor to this template passed away this month(15th April) .. Josep aka forum user "jmontamat" , Josep had been contributing to this template from 2015 at the very beginning, his suggestions, constructive feedback , often providing code to portray his ideas and picking up errors . He will be missed very much and I know he was suffering with multiple sclerosis for many years the template often kept him occupied , my mother was confined to a wheelchair for mobility for the last 15 years of her life(multiple sclerosis) so I fully related to Josep's situation and can understand why he put so much time and effort into his hobby .
RIP Josep thanks for everything ...may god bring you comfort and peace ...next version will have a simple honourable mention in the revision ..Aurora MKII (rev Josep May 2023) ,Aurora MKII (rev Josep June 2023) and so on..
Brian
very sad :?
rest in peace
Churchtownweather
Post by Churchtownweather »
Very sad news RIP
Thanks for everything
Brian
MAY 2023 Simple update
https://www.mediafire.com/file/i35p0jq7 ... 3.zip/file
1.rework of a gauges layout in theme 6 all compiled in CSS no jQuery or ready made stuff .
2.adds requested console forecast notification for Davis hardware owners
3.recompiled GDPR cookie script requires setup option to disable or use.
4.aligns all gauges to use identical CSS .
5.wind data compiled in one module
6.rain module option compiled to use 2 options with or without gauge
7.adds seperate requested rain rate gauge .
8.numerous other minor fixes
todo complete new Davis replica theme of new Davis console (August 2023).
live demo https://singaporeweather.info/weather34-full-layout.php
SIMPLE-UPDATE-WEATHER34-June-2023
https://www.mediafire.com/file/otd5tlmg ... 3.zip/file
1.PHP 8.2.5 Verified
2.fix duplicate davis console forecast notification
3.css increased module size in theme 6
todo new Davis console layout theme to replicate new Davis 6313 – WeatherLink Console (ps probably the most anti solution to use your own weather station website, local marina(surf club) just installed a new Davis weather station after the last one finally gave up the ghost after 13 years to my horror there is no feasible or simple add on solution to share your data to your personal website apart from some long winded weather link which basically is nothing more than a iframe hack..apart from that it looks good in the clubhouse far more visibly friendly than the original console but limititations ...ps Boris Vantage meteostick is a work around !!! :D ) .
have a nice day..Brian
Screenshot at May 22.png (218.12 KiB) Viewed 38256 times
Screenshot at May 22 08-15-20.png (197.12 KiB) Viewed 38254 times
The new theme already looks very nice, I'm looking forward to the next updates.
Many greetings
Torsten
hello Torsten more to come later in the year ...have answered your email with a possible solution..
for those curious the wind module is color coded based on wind intensity .some examples below
lorenz1982
Post by lorenz1982 »
Good morning.
I have this alignment problem on both windows and iOS.
Screenshot 2023-05-23 091504.png (155.33 KiB) Viewed 38198 times
MeteoBorgo: www.meteoborgo.it
fixed this morning
just re download the update and run..sorry no solutions for windows :-)
live example https://singaporeweather.info/weather34-full-layout.php
Screenshot at May 23 10-43-54.png (56.64 KiB) Viewed 38195 times
lorenz1982
Thanks, now it's correct on windows too.
xxvincixx
Post by xxvincixx »
weatherist34 wrote: Tue May 23, 2023 9:47 am fixed this morning
hi brian,it would be possible to set the white color inside for better readability?? thanks
Acquisisci schermata Web_23-5-2023_184620_meteoroccamezzomonreale.altervista.org.jpeg
Acquisisci schermata Web_23-5-2023_184620_meteoroccamezzomonreale.altervista.org.jpeg (189.52 KiB) Viewed 38167 times
Good morning
sorry about that my oversight all corrected ..updated simple update
SIMPLE-UPDATE-WEATHER34-JUNE-2023-R2
https://www.mediafire.com/file/r2rnz5g8 ... 2.zip/file
xxvincixx
Post by xxvincixx »
weatherist34 wrote: Wed May 24, 2023 6:47 am Good morning
thanks brian ;)
brian is it possible to add the maximum rain rate had in the day? exemple: max rate 58 mm/h @10:54
Acquisisci schermata Web_24-5-2023_173252_meteoroccamezzomonreale.altervista.org.jpeg
Acquisisci schermata Web_24-5-2023_173252_meteoroccamezzomonreale.altervista.org.jpeg (192.02 KiB) Viewed 38129 times
alexeysailman
Post by alexeysailman »
Hi, Brian!
A couple of releases ago, the height of template No. 6 and 5 was less. Well, that's just what you need. I noticed that you stretched the height in the last one. If you use a monitor with a resolution of 1920x1080 to view and zoom in on the entire screen (so that the entire screen is filled), then part of it just falls off the screen. It is clear that these are my individual wishes, but are there any plans to "fit" at least part of the templates for full HD resolution? I'm not talking about everything, but No. 4 would be perfect as such. In my opinion, it is ideal: it is well read at a distance, it is not loaded enough, in black, even at night "from sleep" everything is clear.
xxvincixx wrote: Wed May 24, 2023 5:16 pm
thanks brian ;)
good morning yes it is possible but requires additional API data , only Boris can apply this so wait a few weeks til I recompile an API UPDATE for Boris to apply .
Alex think what your seeing is normal I don't have an overlap at foot of screen I use a MacBook AIR .I can simply reduce the modules to 190px(original) height currently there set at 200px as some highlighted empty spacing at the foot of template 6 ..anyway next update ill reduce it to original ..
