Page 13 of 14
Re: Aurora 2026 Rev-4.4Q Release
Posted: Tue Sep 22, 2026 6:56 pm
by alexvanuxem
HI all,
I will ask again, but in a same previous question, i got no answer:
Is the simple upodater enough to go from 4.3X july 2026 to the new one?
or do i need to do intermediate steps, or use the masyter everytime i miss a update?
thx
alex
Posted: Wed Sep 23, 2026 3:46 pm
by weatherist34
alexvanuxem wrote: Tue Sep 22, 2026 6:56 pm
HI all,
thx
alex
Hello perhaps I forgot or just missed it pleased find a big simple update
Big-Update-Alex.zip
containing all files updated since March 11th
https://www.mediafire.com/file/8k3bdnms ... x.zip/file
for anyone else in similar scenario or missed updates contains all updated files since March 11th no need to use if your on 4.4Q (September 2026) update
have a nice evening ..Brian
- alex-u.jpg (557 KiB) Viewed 945 times
Posted: Wed Sep 23, 2026 5:55 pm
by alexvanuxem
thank you!!!
Posted: Fri Oct 09, 2026 3:58 pm
by LOBWX
Not sure if I have all the events needed?
HTTP 00:15 https:/pws.4betts2.com/weather34-chart-end-of-day.php
HTTP every 10 minutes https://pws.4betts2.com/mbridge/mb-lightning.php?d=[lgt0energy-act:--] [lgt0dist-act:--] [lgt0dist-age:--] [lgt0total-daysum.0:--] [lgt0total-monthsum.0:--] [lgt0total-yearsum.0:--] [lgt0total-sum10.0:--]
HTTP every 5 minutes https://pws.4betts2.com/mbdbfiles/stationcron.php
HTTP every 2 minutes https://pws.4betts2.com/chartstoday.php
HTTP every 10 minutes https://pws.4betts2.com/mbridge/mb.php
All my charts for Month and Year stopped updating? Daily charts are fine.
~Bob~
Posted: Fri Oct 09, 2026 7:31 pm
by LOBWX
Found the issue... Typo my bad...
HTTPS://
***Please mark Solved***
~Bob~
Posted: Thu Oct 22, 2026 2:41 pm
by weatherist34
Open response after a couple of emails this morning which i had expected something. In relation to the world wide national media(BBC,CNN etc) news about PHP serious exploit being discovered in PHP and websites services being taken offline.
This is a matter for your hosting service provider or yourself if you run your own server .It is a server side fix not a template fix or solution. Go here for more information
https://www.php.net/archive/2026.php#2026-10-21-5
Sorry i do not get involved in server side fixes or any other server side related stuff. Really is a job for your host to apply the patch.
Brian
Brian
Re: Aurora 2026 Rev-4.4S Release
Posted: Wed Oct 28, 2026 7:25 am
by weatherist34
Simple-Update-October-2026-all-files
https://www.mediafire.com/file/c93c5nuh ... s.zip/file
Aurora-2026-Master-Install
https://www.mediafire.com/file/qxz07yi5 ... l.zip/file
1.PHP 8.6 RC3 verified
2.Meteor Shower module rephrased some of the Text outputs
3.Reworked Windchill module
4.Where supported the theme will change color of browser if light mode browser will be light, if dark mode browser will be dark
Simple update is a larger file than normal and has all files updated this year (2026) .
*** please note these updates are not compatible with any versions prior to 2026 so those using previous versions from 2025 (November) you would need to install 2026 master. please ensure you backup older installs locally on your computer because this will have your historical chart data .
if you need help in this process feel free to get in touch I can help with installing older historical charts or do for you if you provide FTP details and allow access.
- Screenshot 2026-10-28 at 08.20.34.png (97.9 KiB) Viewed 509 times
- Screenshot 2026-10-28 at 08.23.18.png (1.24 MiB) Viewed 509 times
- Screenshot 2026-10-28 at 08.22.39.png (1.49 MiB) Viewed 509 times
Brian
Posted: Wed Oct 28, 2026 10:02 pm
by snoop
Thanks for the update.
When looking at my historical charts, I don't have a button for 2020. I did verify that all the csv files for 2020 are in place. In the setup page, I entered my start date and "What year does your records in meteobridge begin" is set to 2020.
If I point my browser to consolecharts-2020.php manually, the barometer view is the only tile that appears. Looking at the web console, the following files are not present in my 2020charts/ directory:
yearhumiditymodule-2020.php
weather34-chart-yearmaxmin-2020.php
yearwindspeedmodulechart2020.php
yeartemperaturemodulechart2020.php
yeardewpointmodulechart2020.php
yearrainfallmodulechart2020.php
yearuvindexmodulechart2020.php
yearsolarmodulechart2020.php
I looked at the Master zip files for the last couple years and those files are not included.
All other years are working fine in the chart viewer.
How do I get 2020 charts working?
Thanks!
Posted: Thu Oct 29, 2026 5:04 am
by weatherist34
Good Morning
unfortunately chart data prior to 2021 is not supported in the 2026 version , the format is different and requires considerable change to align with later years . The reference you see in setup is really only a info point in the information screen pop up doesn't do anything or related to chart history.i have added cautionary note for next update to reference this in the setup screen.brian
- Screenshot 2026-10-29 at 06.01.24.png (120.59 KiB) Viewed 457 times
- Screenshot 2026-10-29 at 06.00.08.png (65.49 KiB) Viewed 457 times
Posted: Thu Oct 29, 2026 5:58 am
by snoop
No problem. Charts from 2021 are good enough. Thanks for the template and your efforts, Brian.
Re: Aurora 2026 Rev-4.4T Release
Posted: Mon Nov 02, 2026 8:05 am
by weatherist34
release this sometime this week Aurora 2026 Rev-4.4T Release just need to go through some various screens
1.adds new iPhone Duo support folded or open
2.adds iPad m5 screen size support
3.adds rain bucket relative indicators to rainfall and rain rate
4.slight change Davis forecast module descriptions
5.improved CSS across the template
6.minor changes to notifications
no changes required 18 Pro max screens
iPhone Duo apple Xcode simulator screenshots
- Screenshot 2026-11-02 at 09.02.09.png (1.22 MiB) Viewed 327 times
- Screenshot 2026-11-02 at 09.02.34.png (1.46 MiB) Viewed 327 times
Brian
Posted: Wed Nov 11, 2026 3:45 pm
by weatherist34
Release Removed see below or later post
Posted: Wed Nov 11, 2026 4:23 pm
by pwilman
Thanks for the update, in particular I really like the 2 new rainfall modules.
Just updated to the latest one, but the little chart icon at the bottom right of the new rainfall modeuls has disappeared. It means you cant open up the rainfall graphs from the main page. You can see this from my main site (
www.paulwilman.com). Hopefully an easy fix.
Paul
Posted: Wed Nov 11, 2026 5:00 pm
by lorenz1982
Thanks!!!
Before updating, I had an issue where the weather forecast module would occasionally disappear. Now I have to check if this problem has disappeared with the new version.
www.meteoborgo.it/Aurora/index.php
Posted: Wed Nov 11, 2026 7:39 pm
by weatherist34
I just went to your site all ok at present, when it happens again have a look at wuforecast.txt see if it has blank spaces I recall a few years sometimes api file was incomplete which tended to happen on free hosting or servers with low resources i.e causes a timeout when requesting the api.
Screen shot of your site just now
- IMG_0832.jpeg (184.26 KiB) Viewed 38 times
