Page 16 of 30
Posted: Sat Oct 07, 2023 4:23 pm
by Cavaliere
as I replied by email, everything was resolved for the images, is the problem still in the GDPR section?
Then I wanted to ask you if it is possible to have a layout with an additional 3 blocks or if the existing one could be personalizable?
A thousand thanks
Posted: Sun Oct 08, 2023 8:15 pm
by weatherist34
hi , im not seeing the same issue here is a screenshot of your admin panel .. sorry im not so active just very pre occupied ...brian
Screenshot at Oct 08 21-12-59.png (148.37 KiB) Viewed 90727 times
Posted: Sun Oct 08, 2023 10:00 pm
by Cavaliere
Ok brian thank you very much, then it will be a server side cache problem.
Posted: Mon Oct 09, 2023 6:20 am
by weatherist34
its not server side otherwise I wouldn't see the correct layout ..probably a browser issue try a different browser to see if you can eliminate it ..brian
Posted: Sat Nov 11, 2023 12:05 am
by grahamar
Cavaliere wrote: Sat Oct 07, 2023 4:23 pm Hi Brian,
A thousand thanks
I have same issue with the images "missing" - but GDPR is o.k.!
Is there a way to download the images I cant seem to find them in the zip files.
Thank you.
Posted: Mon Nov 13, 2023 7:51 am
by weatherist34
good morning i will release a Simple update sometime soon (should resolve the missing GDPR image in setup screen that said I cant replicate it) , some work in progress on a alternative (7th layout option but kind of not much more I can do to layouts think I covered most useable ways of implementing grid layouts unless anyone has someone inspiration,im all ears :-) ),forthcoming PHP 8.3 compliant just taking a bit of time so hopefully just an error free update :wink: .
teaser(incomplete) if you can spot the change ?
...brian
Screenshot at Nov 13 08-49-21.png (248.88 KiB) Viewed 90458 times
Posted: Tue Nov 14, 2023 12:33 pm
by ToTo
nice to hear from you. I have a small anomaly in the sun/moon module, I have no idea why it sometimes works and sometimes not.
Screenshot 2023-11-14 113015.png (27.57 KiB) Viewed 90421 times
Torsten
Posted: Tue Nov 14, 2023 6:54 pm
by weatherist34
hello toto
i tried replicating it in safari,chrome but too no avail im afraid , i have seen this before but it was many moons ago ( :D ) . at the moment i cant give you a solution , i do see some misalignment that can be adjusted more central ...
you have reminded me too update some of the lunar events for 2024/2025/2026..so thanks for that ..
brian ..
Posted: Tue Nov 21, 2023 7:21 am
by rolzan
Hello everyone,
can someone please explain me the structure of the cvs files for the daily charts?
Thanks in advance
Best regards, Rolf
Posted: Wed Dec 06, 2023 8:04 pm
by weatherist34
hello Im still around just very occupied but slowly finishing off next update which I guess is the last optional layout to use as mentioned before only so much you can do with grid layouts without becoming repetitive . so a few more modules to complete but this is as far I got with the new dynamic color coded circular gauges . update should be very soon ...
Hello everyone,
Thanks in advance
Best regards, Rolf
weather34-chart-end-of-day.php
csv end of day in the month and year csv files its structured like this also see file for same description
// meteobridge and chart position number
$weather34chartdata1 = date('j M',strtotime("yesterday"))."," // date chart position = 0
.$meteobridgeapi[82]."," //Max Temp chart position = 1
.$meteobridgeapi[84]."," // Min Temp chart position = 2
.$meteobridgeapi[52]."," // Max Dewpoint chart position = 3
.$meteobridgeapi[120]."," // Min Dewpoint chart position = 4
.$meteobridgeapi[100]."," // Rain Total chart position = 5
.$meteobridgeapi[94]."," // Wind Speed Max chart position = 6
.$meteobridgeapi[123]."," // Wind Speed Avg chart position = 7
.$notused."," // Not Used chart position = 8
.$meteobridgeapi[135]."," // Pressure Max chart position = 9
.$meteobridgeapi[137]."," // Pressure Min chart position = 10
.$meteobridgeapi[114]."," // UV Max chart position = 11
.$meteobridgeapi[107]."," // Solar Max chart position = 12
.$aqiweather["aqi24h"]."," // Purple Air 24 hour Avg chart position = 13
.$meteobridgeapi[184]."," // Davis Airlink chart position = 14
.$meteobridgeapi[171]."," // Wind Direction Avg chart position = 15
.$meteobridgeapi[167]."," // Max Humidity chart position = 16
.$meteobridgeapi[169]."" // Min Humidity chart position = 17
chartstoday.php
for the (current) day file
//meteobridge and chart position number
.$meteobridgeapi[2]."," // Temp 2
.$meteobridgeapi[10]."," //Pressure 3
.$meteobridgeapi[9]."," // Rain 4
.$meteobridgeapi[43]."," // UV 5
.$meteobridgeapi[40]."," // Wind Speed 6
.$meteobridgeapi[17]."," // Wind Speed Avg 7
.$meteobridgeapi[45]."," // Solar 8
.$meteobridgeapi[4]."," // Dewpoint 9
.$meteobridgeapi[8]."," // Rain Rate 10
.$meteobridgeapi[7]."," // Wind Direction 11
.$meteobridgeapi[22]."," // Indoor Temp 12
.$meteobridgeapi[23]."," // Indoor Humidity 13
.date('j M')."," // Date Month /Year 14 (not used)
.$weather['realfeel']."," // Real Feel 15
.$weather["lightningmax10"]."," // Lightning Total 16
.$weather["humidity"]."," // Humidity 17
.$aqiweather['aqindex']."" // Air Quality 18
hope that is of some help..brian
Posted: Fri Dec 08, 2023 9:35 am
by weatherist34
hello
nearing the release of this layout in next update just a few more modules to complete , if you have any requests that are beneficial please drop a reply here and I will endeavour to accommodate ..
progress :-)...brian
Screenshot at Dec 08 10-32-52.png (249.92 KiB) Viewed 89951 times
Posted: Fri Dec 08, 2023 7:07 pm
by ToTo
I don't know if I'll get used to this "racing look" :wink: with the dotted circles on almost all modules. Would it be feasible to display these circles around the module as a softly rising color gradient? I don't know if that would be more practical in terms of the look?
I would also like the compass color circle to be a little narrower and thinner.
Have a nice evening
Torsten
Posted: Sat Dec 09, 2023 8:01 am
by alexeysailman
Hi, Brian!
It seems to me that if you decided to make the entire dashboard in a "round style", then the strength of precipitation and their intensity can also be done in this style? It's just that these two modules stand out a bit against the general background. For example: let it be a circle of the same diameter, with the same intermittent bar, which will be filled from bottom to top. I agree, the compass also "stands out". Anyway, I like all your presets.
Posted: Sat Dec 09, 2023 9:53 am
by weatherist34
ToTo wrote: Fri Dec 08, 2023 7:07 pm Hi Brian,
Have a nice evening
Torsten
Hi Torsten/Alex
I did use gradient appearance at the beginning
(/* Use  color gradient for stroke */ stroke: url("#linear-weather34temp-gradient");
but it was very time consuming applying/compiling the code to balance those across metric vs non metric not just temps but all sensors and the overall difference wasn't that great or clear in appearance , again this layout is purely optional it is not fixed you still have all the others from previous installs.
Id rather take the easy route and apply solid colors , easier to maintain and adapt to various sensor data.
I will adjust the compass , also will try out the rain accumulation and rate ..let you know how it goes ..
thanks for the feedback..
tweaking the appearance it grows on you :-)
Screenshot at Dec 09 10-44-52.png (57.42 KiB) Viewed 89808 times
Screenshot at Dec 09 10-45-06.png (50.37 KiB) Viewed 89808 times
Posted: Sat Dec 09, 2023 11:36 pm
by garybridge
weatherist34 wrote: Sat Dec 09, 2023 9:53 am
Have a nice evening
Torsten
Hi Torsten/Alex
For what its worth Brian
I love it!
